Basic suspension/tire size question
Discussion in '1st Gen Tundras (2000-2006)' started by Splashbrother13, Mar 9, 2021.
  1. Mar 9, 2021 at 8:12 AM
    Splashbrother13
    Splashbrother13 [OP] New Member
    Aaron
    AZ native
    2000 SR5 Tundra
    New to community about to upgrade suspension and tire size on my 2000 SR5.
    Planning on using it for mostly campouts/intermediate trails.
    Thinking about going w/ bilstein 5100s.
    Open to hearing selling points on 4600 or 6112 for the application.
    Planning on applying a 2-3 inch lift w/ 285/75 r16 tires.
    I’m really wondering what’s the biggest tire I could go without any rubbing or adding spacers or anything on a 2-3 bilstein lift. Thanks.
  2. Mar 9, 2021 at 8:34 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I’m running 285 17 ko2 on 6112 front with camburg uca. I had to do a lot of trimming to stop the rubbing, Specially when you are compressed. I only rub now at full lock to the left, and I have spacers on the way to fix that. Or look for a rim with more of a negative offset -10 or more. I went with 0 offset.
    if you are going with a bigger tire I would recommend new Toyota lower ball joints
    Splashbrother13[OP] likes this.
  3. Mar 9, 2021 at 8:37 AM
    jskeyes2
    jskeyes2 New Member
    Jeff
    Carlsbad, CA
    2005 Limited AC
    ADS Shocks 35” Yokahama M/T
    I have zero offset too, and rub a bit when in reverse. 285/70/17 Toyo
    What size/kind spacers you getting?
  4. Mar 9, 2021 at 8:45 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I would keep planning on 285/75/16. That's been the magic number for a few of us on here.
  5. Mar 9, 2021 at 8:57 AM
    Wheel spacers to fix the rubbing on the frame? You'll likely start rubbing on the fender liner then.
  6. Mar 9, 2021 at 9:00 AM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I rub only on the frame full lock to the left.
    I ordered the below because they are hubcentric, very popular spacer for current Tacoma gen. Tons of YouTube videos about them. I also ordered the below lugs for more bite as recommended from another user.
    https://www.1stgenoffroad.com/store/p842/SpidertraxHubcentricWheelSpacers.html#/
    and what’s a post about wheel and tires without photos
  7. Mar 9, 2021 at 9:10 AM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Fender liner and pinch welds have been cut and folded back. It’s not pretty or factory but it works. I even had to cut because the new UCA after my alignment or once the Suspension settled. It was making contact
    these are some quick parking lot fixes. It’s the only photos I had
    BravoDeltaRomeo likes this.
  8. Mar 9, 2021 at 9:16 AM
    Referring to the fender liner on the driver's footwell at the pinch weld / mud flap region. Adding wheel spacers pushes the scrub radius of the tire out and will make it travel closer towards this area.
  9. Mar 9, 2021 at 12:39 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I rather have the tires rub on plastic that I can cut back than on my frame.
  10. Mar 9, 2021 at 3:08 PM
    Cummins3500
    Logan
    @jerryallday
    You get you spacers in yet?
    curious about the lugs you linked above, I thought those were only needed if running the 1.5 spidertraxs?
  11. Mar 9, 2021 at 5:12 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Not yet, I ordered them, just in case. I Will keep you updated, Iv never run spacers so just want to make sure I do it right
  12. Mar 9, 2021 at 6:09 PM
    I've got the deepshank lug nuts on my spacers, short studs on these Tundras. A normal lug won't engage enough threads on the stud. The deepshank reach down farther in the mounting hole to engage more threads. Then my wheels use a washer style flat surface lug. The spacers have longer studs on them, did not require deep shank on them.
  13. Mar 9, 2021 at 6:16 PM
    Let us know how that goes. If it's not rubbing there now, be curious to see how much rubbing, if any, adding the spacers causes. I have 265/75/16's on 16x8 with 1.25" spacers and they rubbed the flaps even with 2.25" of front lift. Had to do some mild trimming of the plastic, but no pinch weld modding. Still get a little rub with the appropriate articulation and steering angle in reverse. Zero rubbing there without the spacers.
  14. Mar 11, 2021 at 5:03 PM
    Cummins3500
    Logan
