Squeak in front end
Discussion in '2.5 Gen Tundras (2014-2021)' started by JamieNavaro, Mar 11, 2021.
  1. Mar 11, 2021 at 11:10 AM
    JamieNavaro
    JamieNavaro [OP] New Member
    Jamie
    2015 Toyota Tundra TSS 4x4
    6” Lift, 20” Fuel Wheels, Nitto Ridge Grappler 35s
    I have a 2015 Tundra TSS CM with a 6” lift. My front end squeaks real bad on any little bump except for when it rains. Any clue?
  2. Mar 11, 2021 at 11:19 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Could be many things- check lift hardware torque, all bushings like shocks, UCA, sway bar, see if shocks are seeping. Do you have aftermarket bumper or other aftermarket components added anywhere in the front? Suggest you have someone drive the truck slowly over bumpy terrain while you walk beside the truck, see if you can better pinpoint where the sound is coming from.
  3. Mar 11, 2021 at 11:23 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Greasable UCAs?
    Vizsla likes this.
  4. Mar 11, 2021 at 11:47 AM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    Hard to say what it could be. My advice is get a buddy and bounce the front end up and down with the one of you listening to try and pinpoint the squeak.
    Had a annoying squeak and we found out it was the UCA. It was the bushings at the rear of the UCA. Sprayed them with lithium grease and the squeak went away. Spray, drive, spray and drive some more.
  5. Mar 11, 2021 at 12:27 PM
    typerlegend
    typerlegend Will work for Mods
    Will
    SoCal, North Orange County
    2020 Super White Tundra SR5 TRD Sport
    Kicker sound system. Kings 2.5 Adjustables Total Chaos UCA Total Chaos 3/4' Rear Shackles 17' Methods 703s KO2 35/12.5/17 Baja Design Amber Squadron Sport Fogs
    My Kings Suspension and Total Chaos UCA were installed 2 weeks ago. Squeaks at low speeds at well.
  6. Mar 11, 2021 at 1:00 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    Are your control arm bushings urethane? Squeaking has always been the biggest knock on using urethane for suspension components.
  7. Mar 11, 2021 at 1:03 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    ^ this.
  8. Mar 11, 2021 at 1:55 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    If you have skid plates tighten them up. If they're already tight then take them apart and check if it's rubbing on something - you'll find a worn out section if it is.
    Since you have a 6" lift you most likely have a chopped and dropped crossmember. Re-torque all of the bolts that are connected to the crossmembers. I had a crack on one of my crossmembers that squeaked like a b!tch, got it fixed recently and my truck is finally quiet up front.
  9. Mar 11, 2021 at 2:48 PM
    Vizsla
    Vizsla 2 = 2.5
    The bushings that hold the trans cooler and condenser at the top can squeak. Adjusted mine to stop, but some lube would probably work.
    joonbug likes this.
