Tonneau cover with bed rack
Discussion in 'Tonneau Covers, Caps and Shells' started by jemnoriega, Dec 29, 2020.
  1. Dec 29, 2020 at 3:24 AM
    jemnoriega
    jemnoriega [OP] THANOS TUNDRA
    Migz
    Henderson, NV
    2020 Tundra Platinum CM
    STOCK
    I have a 2020 crew max and was wondering if there is a combination that will allow me to have a tonneau cover with a bed rack for a rooftop tent.
    my top choices for covers are :
    Lomax trifold
    Bakflip mx4
    Peragon sliding cover
    Retrax pro.
    I would like to run a KB Voodoo rack system or the new Billie bars for the strength capacity
    I love the lomax and Peragon because they are easy to remove just in case I need the full bed length.
    Any thoughts ?
  2. Dec 29, 2020 at 5:43 AM
    SamW
    SamW New Member
    Sam
    2020 Tundra TRD Pro
    Retrax with the yakima overhaul is a pretty good setup. I have it and put 2 paddleboards or a tent up there. really wanted one of the more traditional overland racks, but yakima did a great job this one.
    TheBlackPearl likes this.
  3. Jan 3, 2021 at 7:48 AM
    red arrow
    red arrow New Member
    2021 Gray Metalic Limited Off Road Tundra Crew
    lomax and adarac pro for me. installing the adarac this week...
  4. Feb 28, 2021 at 7:42 AM
    tobyjz
    tobyjz New Member
    Toby
    2014 Black Tundra Limited
    Flowmaster Super 44, Dick Cepak 20" wheels, running boards, tinted windows
    @red arrow and @SamW would you mind putting up a couple of pics? Interested in doing the same.
  5. Feb 28, 2021 at 8:14 AM
    cardinal
    cardinal New Member
    Central Ohio
    2021 SSM CM LTD TRD4x4
    This summer I'm going with the Diamondback HD and probably the Frontrunner rack accessories, although Diamondback says that adding any aftermarket rack does NOT void their warranty, so you could add anything you want to that.
  6. Mar 2, 2021 at 5:37 PM
    2020txtundra
    2020txtundra New Member
    Kelcy
    2020 black tundra
    4/2 lift with new Upper control arms 20" fuels wrapped in 35x12.50R20 Terragrapplers Backflip MX4 spray in liner.
    I am in the same boat I have the Bakflip mx4 I want some option for a rack and rooftop tent.
  7. Mar 2, 2021 at 5:42 PM
    13igtymer
    13igtymer New Member
    2016 toyota tundra crewmax limited
    Rci bed rack with their tonneau cover adapters. But you have to use a roll up style cover like bakflip revolver series or a canister style roll up.
  8. Mar 7, 2021 at 8:23 AM
    red arrow
    I took my rack off until it gets a little warmer, it only takes a few minutes to put it on or off. Left the bed rails in place. The bed rails run a little off from front to back due to the tundra bed, that may bother some folks. I'll try to get a photo. Happy with my set up so far. Nice to have the locked cover with the rack.
  9. Mar 7, 2021 at 8:36 AM
    SwampThing
    SwampThing New Member
    Thule’s TracRac SR and the rolling BakFlip tonneau covers are another option I’ve seen together.
  10. Mar 7, 2021 at 8:43 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I’m looking at making a modified base plate for the Yakima HD to work with my TCUSA roll up cover rails, or get the adapter brackets from either Voodoo or RCI and the matching rack.
    A friend at work has the VooDoo setup and it fits perfectly with his Diamondback tonneau.
  11. Mar 10, 2021 at 6:54 PM
    brown_subaru
    brown_subaru New Member
    Eastern WA
    2021 Tundra SR5 TRD
    I have a Truxedo Lo Pro tonneau with truxedo TS rails. I use old Yakima Control Towers and 78” round bars. I can’t roll up the tonneau with the rack on, but the rack comes off quickly.
  12. Mar 10, 2021 at 7:44 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    The VooDoos squeak like a bat out of hell.
    Take a look at the Vixtory4x4 rack. They have a short or tall option. Everything they make is solidly built. It also allows for a roll up tonneau.
  13. May 18, 2021 at 3:40 PM
    jupiter808
    jupiter808 New Member
    Jupiter
    2006 Tundra Double Cab LTD 4x4
    TRD Exhaust Peragon Bedcover TracRac SR with custom Niilight LED System
    @jemnoriega I'm running a Peragon cover with TracRac/Thule SR racks. I'm with you on the simplicity of the Peragon cover. More thoughts/opinions and pictures of the cover/rack setup at my IG post below:
    https://www.instagram.com/p/CLpe4-0nD5I/
    I'd like to see everyone else's setups please! I'm actually considering changing up my rack to something that's more of a "system" vice just being a rack so I can have more options of mounting accessories and such. Thanks!
