HELP: Trying To Decide On A Lift
Discussion in 'Suspension' started by cdavi060, Mar 10, 2021.
  1. Mar 10, 2021 at 5:26 PM
    cdavi060
    cdavi060 [OP] New Member
    Virginia Beach, VA
    2017 Super White Tundra Platinum CM
    285/70r18 NITTO RG | Method NV 18x9 | Bilstein 6112 @2.5" w/CB shims, SPC UCA, 5100 & CB +3 Shackles | Entune 3.0 Swap | 2018+ Platinum grille + Pro LED Headlights
    Been crawling around here for a few months now in attempt to decide what I want in a lift, but am still not 100%.
    I found this truck online, and is pretty much what I want to go towards:
    D90DE99F-802A-47B2-BBD3-596A59167E60.jpg 32917A83-F573-4899-A31D-AE1534B8DDD6.jpg 2795799B-D293-4CC1-96C3-9BD9EC5410DD.jpg
    That truck has a 3” Ready Lift on Method NV 18x9 wheels (+25) wrapped in Nitto Ridge Grappler 285/75/18s. Issue being they state it rubs some at full lock.
    Questions I have:
    -Anyone have experience with this configuration?
    -Will the 6112/5100 setup provide any additional lift over the 3in Ready Lift or will it be the same?
    -Is there a tire size one size smaller but same ratio as the 285/75 that would eliminate rubbing?
    if anyone has experience with this or a similar setup, I would love some details and photos! Thank you.
    UPDATE:
    Think I have narrowed it down to:
    -Bilstein 6112 front @2.5" w/ CB shim on each side
    -Bilstein 5100 rear w/ 1.5" shackle
    -Method NV 18x9 wheels
    -285/70/18 Nitto Ridge Grapplers
  2. Mar 10, 2021 at 6:07 PM
    Mhenders1069
    Mhenders1069 New Member
    Mn
    2019 tundra Trd on king suspension
    4.88 Nitro Gears. King coil overs and rears with remote resi and a pedal commander throttle control. AFE cold air intake. RSI Smartcap and GFC supernate 50.
    Offset makes a huge difference. Its probably rubbing on the skid plate/front sway bar, probably not at the body mount. A bora wheel spacer or a wheel with 0 offset probably solves this. Look up the @Coachbuilder1 ted pro upgrade kit too. It pushes the bumper out 1/2" and creates more space in the front of the fender.
    TheBlackPearl and cdavi060[OP] like this.
  3. Mar 10, 2021 at 6:18 PM
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    I have installed ReadyLift Leveling kit 3.0 front 1 rear. I also installed Spidertrax WS 1.25 in. I posted some pics and detailed install videos on my build thread link below. It doesn't have all answer you are looking for but a least can give you an idea on the lift kit DIY install. I have no issues so far with the lift kit. The only issue is that I want to see it higher now. :)
    Build Thread:
    https://www.tundras.com/threads/diy-1794-ed-build.82488/#post-2102432
    D4x4TRD and cdavi060[QUOTED][OP] like this.
  4. Mar 10, 2021 at 6:37 PM
    cdavi060
    Virginia Beach, VA
    But the question is if 285/70/18 Nitto Ridge Grapplers would be the best fit here? To remove chances of rub and no bumper mounting kit this seems like the same tire ratio as the pictured 285/75/18, just 1 inch shorter.
    BravoDeltaRomeo likes this.
  5. Mar 10, 2021 at 7:04 PM
    biebs96
    PA
    You can run 285/75 on the stock 18s with no spacers and no rubbing with some 5100s up front on the middle setting.
    Megaman and cdavi060[OP] like this.
  6. Mar 11, 2021 at 3:56 AM
    cdavi060
    Virginia Beach, VA
    Thanks man! Unfortunately I have the 2017 20in gray highlight Platinum (not even the 2018+ black highlight) wheels, so to move over to TRD wheels, it is about the same cost as aftermarket.
  7. Mar 11, 2021 at 4:15 AM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    Bumper shims, you have a few options to choose from.
    I have Toytec 1/2" bumper shims and 20x10 with -24 wheels with no rub anymore on full lock with these shims.
  8. Mar 11, 2021 at 4:52 AM
    biebs96
    PA
    lots of people sell them as take offs. I saw a set locally sell for $250 with tires. At that point it’s a matter of a tire change.
    cdavi060[QUOTED][OP] likes this.
  9. Mar 12, 2021 at 10:25 AM
    cdavi060
    Virginia Beach, VA
    Think I have decided:
  10. Mar 15, 2021 at 5:27 AM
    redhat
    redhat Leadfarmer
    Jacob
    Sacramento
    2019 TRD PRO
    Nothing but good stuff.
    Sounds like a good choice.
    Megaman likes this.
  11. Mar 15, 2021 at 7:39 AM
    cdavi060
    Virginia Beach, VA
    Is that what you have done? Yours looks great.
  12. Mar 15, 2021 at 10:49 AM
    ckkone
    ckkone New Member
    SLC, UT
  13. Mar 15, 2021 at 12:15 PM
    cdavi060
    Virginia Beach, VA
    Humm, never heard of Dobinson. Can you elaborate on "don't be a dummy and try to get a 3"+ lift"?
  14. Mar 15, 2021 at 12:30 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Many here LOVE that combo of lift/level. shocks/shackles.
    I'm sure you'll be fine.
  15. Mar 15, 2021 at 7:13 PM
    redhat
    redhat Leadfarmer
    Jacob
    Sacramento
    2019 TRD PRO
    Mines a pro with different leafs in the back but the front is stock.
  16. Mar 16, 2021 at 4:40 AM
    cdavi060
    Virginia Beach, VA
    I assume you are referring to the Bilstein setup?
  17. Mar 16, 2021 at 4:55 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    Yes.
  18. Mar 22, 2021 at 10:35 AM
    cdavi060
    Virginia Beach, VA
    Coming from a Tacoma, we had the Taco lean, and driver side needed a shim to level out. I see some Tundra guys do this as well, but some don't. Is it required/recommended? Is it just per truck?
  19. Mar 23, 2021 at 5:18 AM
    Blkdmax
    Blkdmax New Member
    Tennessee
    2021 Cement CrewMax 4x4
    Just my two cents. I had 6112s on a 2017 tundra I had that got totaled. I’m now waiting on my 2021 to be delivered and I will not be going with 6112s with the new truck. They are well made but they are a rough ride no doubt.
  20. Mar 23, 2021 at 5:36 AM
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    So the Dobinsons are supposed to be a much smoother ride? Is that what you’ll go with?
  21. Mar 23, 2021 at 5:38 AM
    Blkdmax
    Blkdmax New Member
    Tennessee
    I’m looking mostly at fox.
    Maybe I’m petty, but I despise that ugly yellow on the dobinson stuff lol.
  22. Mar 23, 2021 at 5:59 AM
    CCLJ03
    Craig
    Hahaha oh I feel you on that. I just have a hard time justifying paying that much for suspension when the off-roading I do is relatively mundane. It gets a little western on the way up to elk camp, but other than that I’m on relatively well maintained dirt roads or pavement.
    Blkdmax[QUOTED] likes this.
  23. Mar 23, 2021 at 6:02 AM
    Blkdmax
    Blkdmax New Member
    Tennessee
    Same for me. I’m honestly leaning towards fox 2.0, they seem like they’ll be enough for me. And still stay under $1000.
  24. Mar 23, 2021 at 6:29 AM
    cdavi060
    Virginia Beach, VA
    I Had a Bilstein setup on my 2001 Tacoma and had no issues with it. My 2016 Tacoma had OME. It was stiffer than stock but was fine. It is a truck.
    Where are you finding Fox for 1000? And doesn't the Fox 2.0 coilover setup only do 2in?
  25. Mar 23, 2021 at 6:39 AM
    Blkdmax
    Blkdmax New Member
    Tennessee
    2.0 are $900. They come at 2” but from what I’ve read you can get 2.5” which is all I’m wanting.
    cdavi060[OP] likes this.
  26. Mar 23, 2021 at 8:27 AM
    cdavi060
    Virginia Beach, VA
    Are the UCAs a requirement or a recommendation for this lift (2.5-3in)? I see some guys do fine without, and some go with.
  27. Mar 23, 2021 at 8:40 AM
    Blkdmax
    Blkdmax New Member
    Tennessee
    Last truck had 6112s on top setting and my truck alignment was great without ucas. 3”+ I would definitely get ucas
  28. Mar 23, 2021 at 9:39 AM
    cdavi060
    Virginia Beach, VA
    Wheels weren't toed in? No darting around on the highway?
  29. Mar 23, 2021 at 9:53 AM
    Blkdmax
    Blkdmax New Member
    Tennessee
    No not at all
