Kings VS ICON (sorry in advance)
Discussion in 'Suspension' started by YotaBro, Mar 10, 2021.
  1. Mar 10, 2021 at 6:32 AM
    YotaBro
    YotaBro [OP] This forum will make me broke
    Calvin
    FL
    2017 Cement Grey Tundra TRD PRO
    Lots of shenanigans.
    Currently running stock TRD PRO suspension, love it but noticed when on the trails that it is pretty stiff.
    I'm sure it's somewhere on here but what're y'alls thoughts on the two? Prefer people with experience running them but any input is appreciated!
  2. Mar 10, 2021 at 6:36 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    King > Icon, but I'd send out your fancy shocks to get worked instead of swapping brands and getting the same or worse ride quality. Use all that fancy shock tunability goodness! Probably just need a rebuild, or while at it have them valved softer.
    P.S. - SRQ Fabrications in Sarasota makes a lot of stuff for Toyotas and could probably hook you up.
    RRR1C0 and YotaBro[OP] like this.
  3. Mar 10, 2021 at 6:50 AM
    Ace402
    Ace402 New Member
    2011 Tundra 4x4 SR5
    ADS 2.5 RR front and rear. MCM UCA & Shackles
    I would bet both King and Icon would be stiffer than the Pro suspension
    YotaBro[OP] likes this.
  4. Mar 10, 2021 at 6:56 AM
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    I wasn’t aware you can rebuild the bilstein pro shocks? Or do you have Fox pro shocks?
  5. Mar 10, 2021 at 6:58 AM
    BluegrassPro
    BluegrassPro New Member
    Jeff
    2021 TRD Pro
    This is exactly correct!
  6. Mar 10, 2021 at 6:59 AM
    YotaBro
    Calvin
    FL
    My knowledge when it comes to suspension parts is pretty minimal.
    I have the bilstein shocks. Would they still be able to do a rebuild? I was thinking of adding a UCA to hopefully smooth things out
    any suggestions on what to do?
  7. Mar 10, 2021 at 7:04 AM
    YotaBro
    Calvin
    FL
    I was looking at the total chaos UCA or ICON delta joint UCA
  8. Mar 10, 2021 at 7:06 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    A UCA isn't inherently going to smooth out your ride. Surprising to hear that your experience is "stiff" while offroad. Is this slow-speed where you feel the stiffness, or higher speed?
    YotaBro[QUOTED][OP] likes this.
  9. Mar 10, 2021 at 7:09 AM
    Ace402
    Ace402 New Member
    2011 Tundra 4x4 SR5
    Bilstein Pro’s are not rebuildable. The Fox pros are.
  10. Mar 10, 2021 at 7:12 AM
    YotaBro
    Calvin
    FL
    Maybe stiff wasn't the best description but I've noticed that when I go down a rut that it isn't bouncing as much as I would expect it. This is compared to other buddies trucks that I have ridden in.
    Also, mainly during slower speeds. Im not hitting the trails very fast.
  11. Mar 10, 2021 at 7:13 AM
    Ace402
    Ace402 New Member
    2011 Tundra 4x4 SR5
    Icons will be stiffer on the slow stuff than Kings.
    I have ADS on my Tundra and Kings on the wife’s Sequoia. Kings are smoother on the Sequoia. However, the Sequoia has a supercharger and metal tube bumper so the extra weight on the front end may contribute to the smooth ride. My Tundra is stock
  12. Mar 10, 2021 at 7:24 AM
    memario1214
    Colton
    Missoula, MT
    So... A proper suspension won't be "bouncing around".
    Ex - Hopefully this lets you watch it.
  13. Mar 10, 2021 at 12:20 PM
    Mill72
    Mill72 New Member
    California
    2021 Tundra DC 4x4 TRD
    It’s all about valving. I don’t know if you can re-valve the Pro Shocks, but different ball game with Kings, Icons, Fox, ADS shocks. I don’t see nothing special about the Pro shocks.
  14. Mar 10, 2021 at 12:27 PM
    TheBeast
    TheBeast The Beach
    what about tire pressure ? what are you running ?
    Darkness likes this.
  15. Mar 10, 2021 at 12:28 PM
    SC_TRD
    SC_TRD Big BASTRD 4x4 Enthusiast
    Colin
    Round Rock, Tx
    2012 CrewMax & 2008 Sequoia
    If you decide to go with new UCAs get Total Chaos over the Icons, definitely a brand favorite here.
    TheBeast likes this.
  16. Mar 10, 2021 at 12:32 PM
    SC_TRD
    Colin
    Round Rock, Tx
    I had Icons in my truck when I bought it.. night and day difference when I moved to adjustable King 2.5s in the rear.. softest setting was like floating on a cloud... to be fair these were just the standard Icon 2.0 shocks and a completely different price point and shouldn’t really be comparable anyways..
    I liked the Icon 2.5 coilovers enough in the front, no real complaints there.. just didn’t like how much preload was required to get the lift height I wanted. I enjoy my Fox 2.5s now and am very happy.
  17. Mar 10, 2021 at 12:38 PM
    Ace402
    Ace402 New Member
    2011 Tundra 4x4 SR5
    You are correct. I think the Pro suspension would be valved the softest. The progressive Kings would feel softer than the digressive Icons at slow speeds
  18. Mar 10, 2021 at 1:03 PM
    memario1214
    Colton
    Missoula, MT
    I actually just ordered a set of Icon Delta Joint UCAs to go with my Elka setup. I'm curious to see how I like them given that I have only ever had uniball setups in the past.
    TXTundra2722 and YotaBro[OP] like this.
  19. Mar 10, 2021 at 1:07 PM
    SC_TRD
    Colin
    Round Rock, Tx
    I think you will like the low maintenance of the delta joint. The issue they I know about the icons Delta joint UCAs is all about the geometry, I believe they come with a lot of Caster dialed in and make it more difficult fitting larger tires and getting a good alignment unless you have the heimmed joint version.
  20. Mar 10, 2021 at 1:11 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    go blue or go home. done. end of story.
    i had icons on my old fj. road manners better than dirt manners. i have kings on my tundra. dirt manners better than road manners. i prefer the kings.
  21. Mar 10, 2021 at 2:30 PM
    YotaBro
    Calvin
    FL
    Last time I went I was running the dealership Michelin so I didn't bother adjusting the PSI. I am running Falken Wildpeaks now and will adjust it next time to see the difference.
    Ok, thanks for the info!! How do you think the total chaos would run with the Bilstein TRD PRO coilovers?
  22. Mar 10, 2021 at 2:42 PM
    Kelvin
    Kelvin New Member
    I’ve owned all kinds of Icons and they all squeaked. 2.0, 2.5, bypasses, etc. Go on Tacoma world and you’ll see most go from Icon to King but never the other way around.
  23. Mar 10, 2021 at 2:44 PM
    memario1214
    Colton
    Missoula, MT
    Lol hang out on TW and you see everyone go from Icon to King to ADS nowadays
    Kelvin[QUOTED], SC_TRD and TheBeast like this.
  24. Mar 10, 2021 at 3:31 PM
    Kelvin
    Kelvin New Member
    That shock body coating they have makes all the difference huh.
    It wasn’t too long ago Icon had some severe weather coating too which was half the reason most people even bought their crap.
  25. Mar 10, 2021 at 3:39 PM
    memario1214
    Colton
    Missoula, MT
    Living up north here that’s why I’m going with Elka. Greater travel over stock, and should be more resilient against the elements. We shall see!
  26. Mar 10, 2021 at 4:17 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Research progressive vs digressive.
    Icon, Bilstein = di
    Everyone else = pro
    First figure out the ride quality and performance you want (valving wise) then start looking at mfgs.
    @state48overland will be happy to spend some time with you on the phone helping you narrow down based off performance and price point.
  27. Mar 10, 2021 at 5:01 PM
    Kelvin
    Kelvin New Member
    Even better. On my aluminum coilovers for my Lexus I waxed and sealed them for extra shininess. Not sure if it helped tbh.
