Infotainment Swap
Discussion in '2.5 Gen Tundras (2014-2021)' started by Erazo, Mar 9, 2021.
  1. Mar 9, 2021 at 7:59 PM
    Erazo
    Erazo [OP] New Member
    Is it possible to swap the 8inch screen from the 2020+ Tundras into the the 2019 one?
  2. Mar 9, 2021 at 8:11 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Better off going aftermarket
  3. Mar 10, 2021 at 3:47 AM
    heidson
    heidson New Member
    2017 White Tundra Limited 4x4
    Bilstein 5100's all around
    I have looked into this but not yet done so. I believe it is possible. From my understanding you have to get the matching JBL, non-JBL, nav, or non nav to what you have. Then will need a conversion harness. I reached out to autoharnesshouse.com and they were willing to make one. You will pay a premium over an aftermarket head unit but it’s up to you if the factory look is worth that. For me it likely will be whenever I decide to pull the trigger.
  4. Mar 10, 2021 at 3:54 AM
    Use search function as this has been discussed before. The connectors are completely different and the wiring pinouts and colors have changed as well. Its not as easy as them making a harness. The wiring colors even vary between the different trim levels in the 2020.
