2.5 Gen Bumpers!
Discussion in '2.5 Gen Tundras (2014-2021)' started by FlashCulprit, Dec 14, 2016.
  1. Feb 24, 2021 at 6:07 AM
    #481
    HighonFirewood
    HighonFirewood Everything can be fixed with a hammer.
    Stage Left. Colorado
    2019 Tundra
    equin likes this.
  2. Feb 24, 2021 at 7:29 AM
    #482
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    I am looking at getting the same bumper in the future. You said with skid plate added, is that a filler until the RCI skid shows up? Or will they work together?
  3. Feb 24, 2021 at 7:40 AM
    #483
    HighonFirewood
    2019 Tundra
    (Should) Work together..I haven’t seen what I’ll receive from extreme terrain..but it’s off the bumper to the factory skid. The RCI will replace factory so I assume it will work. Hopefully if it’s an issue I would only need a longer threaded bolt to remedy.
  4. Feb 24, 2021 at 8:52 AM
    #484
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    I look forward to seeing how it goes for you, hopefully they fit well together.
  5. Feb 26, 2021 at 8:54 AM
    #485
    Hugemoose
    Hugemoose New Member
    Philly
    2016 Tundra Crewmax
    Not enough....
    I am curious to see how that skid plate they sell lines up with an aftermarket skid plate. I have the P&P engineering skid plate which utilizes the factory tow hook bolts, and wraps up the front a little bit. It looks like this one mounts using the tow hooks bolts too, but it just fills the gap in-between that and the lower part of the bumper.
    It doesn't look too bad for the price!
  6. Mar 2, 2021 at 10:11 AM
    #486
    Discovered this today if you are looking for Road Armor bumpers or products....
    DO YOU GUYS OFFER MILITARY DISCOUNTS?
    YES WE DO, 30% OFF, SOMETIMES OTHER PROMOTIONS CAN BE GREATER. IF YOU WISH TO USE THIS DISCOUNT PLEASE USE CODE MILITARY30
  7. Mar 3, 2021 at 9:13 PM
    #487
    Vang530
    Vang530 New Member
    Got my CBI bumper installed after waiting 4 months.
    95JRGosGX7D2arWZfNIwLh0GZ-vZwou1UpzOaOKL_2e27a3a4d7ae36655840bae62b2d4a719034ed1c.jpg
  8. Mar 4, 2021 at 12:03 AM
    #488
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    Mine just showed up.
    How was install?
    Saltyhero13 likes this.
  9. Mar 4, 2021 at 4:44 AM
    #489
    Vang530
    Vang530 New Member
    Not too bad, but a little DIY and ingenuity involved for sure more than I thought it would for a bolt on bumper. It took me and my brother 5 hours taking our sweet time removing stock bumper and installing everything.
    1. Had to use a lot of washers as spacers for the light bar mount since I didn't use a Baja Designs one, just an Amazon special.
    2. They never included the stock fog light brackets with mine for the new bumper and CBI support was pretty horrible in my experience. I ended up just getting some Diode Dynamics SS3 fog lights and it needed a couple washer spacers to bring it up to fit in the fog opening since again, these were designed for Baja Designs lights.
    3. They never included sensor plug covers with the bumper to cover the holes and my truck never came with them...so I ended up ordering some 23mm amber LED marker lights to fit in there with some washers.
    4. I had a trim a little gusset off the core support with a Sawzall so that my Smittybilt X2O winch soldenoid box would fit since I didn't want to relocate it under the hood.
    5. The bumper had a little bit more of a gap than I would have liked once installed on the stock tow hook location where you bolt it back on. The factory tow hook bolts were too short and you're gonna need new longer bolts and some washers/spacers to cover that gap or you'll bend the bumper in that area a little bit snugging it up from the bottom. I had to order new M12x1.25x50mm bolts and washers on McMaster-Carr so I can put my stock tow hooks back on.
    Overall, I like the bumper and quality. CBI customer service was non-existent and ignored and ghosted about 4 of my emails. I am happy I ordered through TruckBrigade though as they were my advocate for the long lead times and kept me updated and I do like CBI products and will be ordering skids and sliders through TruckBrigade again, not CBI directly. I will say, I did order bare steel, and it came powder coated for me so that was kind of a nice surprise and free upgrade lol.
  10. Mar 4, 2021 at 6:42 AM
    #490
    Hightide
    Abalama
    Magic School Bus
    Good info. Thanks!
    @Truck Brigade is the way to go.
    They hooked me up on a number of items.
    I found it is best to call CBI, their email responses are slow.
    Ordered mine bare as well.
    Thought I got the powder coating hookup when I called to check status.
    They said it was in powder coating and about to ship.
    It came bare... oh, well.
  11. Mar 4, 2021 at 6:56 AM
    #491
    Hightide
    Abalama
    Magic School Bus
    I have the Diode Dynamics in round and square.
    Do you think one would work better than the other?
    Would you happen to have a link to the 23mm lights?
    I like that!
    Do you have a pic with them lit up?
  12. Mar 4, 2021 at 7:03 AM
    #492
    Vang530
    Vang530 New Member
    Not sure if you have Tundra specific ones, but you'll need the universal style ones because they come with a different bezel that doesn't contour to the stock bumpers. I think the square works better? but I can't really compare since I don't have the round ones. The bumper opening is 3.5" and the SS3 squares are like 3.3" or so. The universal mounting brackets are just a little too short for the cut out hence the washers to stack it up a bit higher.
    Sorry, still not wired up yet, working on it this weekend. You'll need these in 23mm and some 3/8 washers front and back (I just spray painted the washers black to blend in). https://www.amazon.com/gp/product/B07CWQZ212/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8
    Hope this helps, I wish I knew this going in at the time lol.
    JCamvYQeY7fbucgB30jsRR4z0-cipPCAZQecphAn_090620d4c569715528cd628f5ce2414110be2aaf.jpg
    RERBuyzq3ocAjEad8L_f3Me_oqyulaJXnkcUw0xJ_7d74d7fdd20e42734ff88a20ae4553ac58acc082.jpg
    COTundra23 and Hightide[QUOTED] like this.
  13. Mar 4, 2021 at 7:08 AM
    #493
    Hightide
    Abalama
    Magic School Bus
    Thanks!
    Yes, I do have the universal rounds, but if the squares fit in the opening, I may go that direction.
    I’m really liking the 23mm lights.
    I’m excited to see them powered.
    Kind of a unique way to do some running lights without doing the raptor copycat.
    Saltyhero13 and Vang530[QUOTED] like this.
  14. Mar 4, 2021 at 7:13 AM
    #494
    Saltyhero13
    Saltyhero13 Throbbing Member
    The lights are a nice touch. I usually don't like these kinds of upgrades. These look like they belong.
    Hightide and Vang530 like this.
  15. Mar 4, 2021 at 7:35 AM
    #495
    Zero One Actual
    C4 Overland bumper
    Warn winch
    @Baja Designs LP-9, IR fog lights and 30 inch amber light bar
  16. Mar 4, 2021 at 9:53 AM
    #496
    itsmerh85
    itsmerh85 New Member
    Gilbert, AZ
    2020 Black TRDPro
    I'm eyeing this bumper, as well. Any issues with the TSS? How long was the wait?
  17. Mar 4, 2021 at 10:02 AM
    #497
    needsmoresalt
    needsmoresalt New Member
    Patrick
    2020 Tundra TRD Pro
    A few
    About 13 weeks wait. No issues.
  18. Mar 4, 2021 at 6:07 PM
    #498
    Zero One Actual
    As @needsmoresalt said. It is a great bumper and I have no issues as all with the TSS or anything.
    Terndrerrr and itsmerh85[QUOTED] like this.
  19. Mar 4, 2021 at 6:54 PM
    #499
    November Sun
    November Sun New Member
    Huntsville, Alabama
    2018 Limited Crew Max
    Pro Comp 7" Stage 1 Lift, 20" Fuel Wheels, Nitto Terra Grapplers, Bak Flip Tonneau Cover, King 2.5's, Custom Alcan Leafs, Coachbuilder Steering Kit, CBI Baja Front Bumper, NSV Light Bar, TRD Pro Intake, Southeast States Wireless Phone Charger Coachbuilder Plus 3 Shackles, Wheeler's Bumpstops, BAM 8" Exhaust, BAM Bomb Tip, Headlight Revolution LEDs everywhere, Warn EVO 12K Winch, Diode Dynamics SAE Fogs and Combo Light Bar
    I have the Baja bumper sitting in my garage, I've yet to install it because I've been waiting on a winch. Do you think that I could install a winch with the bumper already on the vehicle? Also, I'm not sure if I got any mounts for the stock foglights now that I think about it. I've also got a cheapo 30" no name light bar I want to put in too.
  20. Mar 5, 2021 at 8:50 AM
    #500
    Vang530
    Vang530 New Member
    There's no way you could do that UNLESS you don't have a hoop on your bumper impeding your grille like mine does. I think it might be possible if you can take the grille off and on easily. The winch kind of tucks under the grill a little bit, you can kind of see from my pic below and see the mounting brackets for my winch solenoid where it sits behind the lower portion of the grille. To mount the winch, you remove the built in skid plate on the bumper and get access to the mounting holes from down there. The fairlead is kind of a pain to install too, I had to find longer bolts since you sandwich it between two plates on the bumper. You'll see once you get there. It will make your life 100x easier to just wait to install everything on the bumper before putting it on.
    Even installing the 30" light bar would be a huge pain in the ass to do with the bumper on. Use the included light bar brackets they gave you (I hope they even gave you them) and grab some bolts and washers and it should work. My 30" Nilight light bar was a little short on the mounting brackets and I ended up using nuts/washers as spacers, no biggie and its totally fine.
    Be ready to have a bunch of washers to use as spacers for various fitments and make trips to the hardware store for longer bolts for multiple items. There's no way I could find out how you could install the OEM fog lights on without a special bracket made for them even though CBI markets it as a feature... it's really set up on the bumper for Baja Squadron lights, but I made the Diode Dynamics SS3 work just fine. Maybe some other CBI bumper owners can chime in on this, but yeah, no brackets here too, but it was an excuse to upgrade the fogs so oh well.
  21. Mar 5, 2021 at 4:23 PM
    #501
    November Sun
    Huntsville, Alabama
    Thanks, guess I’ll wait til I get a winch and BD Squadrons and who knows what else. Probably a TRD Pro grill to relocate the sensor. Money pit. Lol
    Vang530 likes this.
  22. Mar 6, 2021 at 4:07 AM
    #502
    HighonFirewood
    2019 Tundra
    Got skid plate #1. I’ll post a pic, I dig it. Works with factory tow hook. Didn’t work with location where factory skid plate attaches. So I’m not sure of the next problem, but when I pick up the RCI skid plate I’m gonna probably head over to my local guy at liquid power jet and have him just cut the Barricade skid if needed.
  23. Mar 6, 2021 at 5:58 AM
    #503
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '25 Limited TRD-OR
    I'm intrigued.... Are you driving around with NODs on??
  24. Mar 6, 2021 at 6:23 AM
    #504
    Willard
    Willard New Member
    2024 F250
    You aren’t? ;)
  25. Mar 6, 2021 at 12:43 PM
    #505
    Zero One Actual
    Yes. That’s what IR lights are for.
    Saltyhero13 and Mallcrl[QUOTED] like this.
  26. Mar 6, 2021 at 12:56 PM
    #506
    YotaTruckLtd
    YotaTruckLtd Secret Squirrel
    2014 MGM Limited CM
    Bilstein 6112/5160 Boss 4x4 shims Boss 4x4 shackles Fuel Off-Road Vector wheels 20X9 Nitto Terra Grappler G2 35" tires SPC UCAs OEM TRD Pro Grille OEM 2020 LED headlights and OEM LED fog lights OEM color matched mirror caps and door handles OEM black exhaust tip Ecoological color matched front and rear bumpershellz V3 Go Rhino RB20 running boards XPEL Prime XR Plus ceramic tint 30% front 15% rear 70% windshield BAKFlip MX4 tonneau cover Dasaita 13in Vivid Headunit AJT interior chrome delete black kit AJT climate control black knobs AJT V3 shift knob TVD exterior emblem black inlays 3BMakers Yota hitch cover Husky front and back floormats K&N Select engine air filter GTR Lighting Armor Series LEDs Reverse lights Cargo lights 3rd brake light License plate lights
  27. Mar 6, 2021 at 2:35 PM
    #507
    Glennjermin
    Glennjermin New Member
    Glenn
    Virginia
    2014 Toyota Tundra SR5 Crewmax 4x4
    Icon Add A Leaf springs Bilstien 5100 shocks Freedom Off Road UCAs Snugtop rebel camper shell Prinsu Roof Rack Decked System
    I have not, but this looks interesting. I have been trying to find some decently priced bumpers.
    YotaTruckLtd[QUOTED] likes this.
  28. Mar 6, 2021 at 3:05 PM
    #508
    Glennjermin
    Glenn
    Virginia
    This is a beautiful build. Damn I love it.
    Krezz[QUOTED] likes this.
  29. Mar 7, 2021 at 8:02 AM
    #509
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    Thanks Glenn!
    Wife wanted in on the fun, so we hope this season to really enjoy it :fistbump:
  30. Mar 7, 2021 at 8:08 AM
    #510
    Vang530
    Vang530 New Member
    I have the rear Hooke Road. It needs modification, grinding and slight DIY to make it fit. It comes in 3 pieces. Quality is so-so mass manufactured in China, but for the price I really can't complain..it's half of what other bumpers are out there for. The free back up lights are meh since they are spot pattern and I prefer flood. I tried switching them out with some Amazon Nilight ones and they didn't fit because of the fins on the back. The step is great to have. The finish was good. I experimented with Rustoleum Smoke Gray spray paint to color match and it turned out alright. If you are expecting C4/CBI quality, this is not the one to get. For the money, its definitely okay.
    i82wqxyeT1JHEUx62RxJsQC85IFFlYYjngljUynX_caa9e4eb21ff03b2c91bf9529b0652b91613d857.jpg
