Upper control arm NEEDED?
Discussion in '1st Gen Tundras (2000-2006)' started by allmotor, Mar 6, 2021.
  1. Mar 6, 2021 at 8:52 PM
    allmotor
    allmotor [OP] New Member
    tim
    2000 Tundra Access Cab TRD Limited
    Wheels
    So i'm researching the need of upper control arms with a 3" front and 2" rear lift ... is it needed and if so what brand is best without breaking the bank?
  2. Mar 6, 2021 at 8:55 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Generally Two inch lift in the front is all the OEM UCA wants to handle.
    @Darkness will be able to help more than I can. My lunch is almost over.
    There are a few options. If you live in a salty area, or grimy in general consider SPC upper control arms.
    If you dont care, or live in a Generally dry, salt free area you can go with a uniball like a camburg setup.
  3. Mar 6, 2021 at 8:56 PM
    allmotor
    tim
    Wheels
    what is a safe lift with stock everything? I read 3inch front with 2inch rear was a safe OEM lift lol.. maybe not?
    I live in washington state... so not salt roads... truck was born in NY hence the frame being replaced.. my luck =0)
  4. Mar 6, 2021 at 8:58 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    The general consensus I found with the gurus here was 2 inches is livable for a short while in the front. Anything above that you will want an aftermarket arm with more adjustment.
  5. Mar 6, 2021 at 8:59 PM
    allmotor
    tim
    Wheels
  6. Mar 6, 2021 at 9:01 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    That's a uniball. What year is your truck?
    You're posting things for a 2ND/3RD gen, but your profile icon shows 2000 model truck which is first gen.
    Those won't fit.
  7. Mar 6, 2021 at 9:02 PM
    allmotor
    tim
    Wheels
    sorry the link is so weird.. when you go to the site it has a drop down for the 1st gen...
  8. Mar 6, 2021 at 9:12 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    On my end of the internet it just shows "tundra" generation isn't specified.
    These are two examples of what you can use. Personally, I used SPC when I raised mine 2 inches.
    Pics are now links.
    Darkness likes this.
  9. Mar 6, 2021 at 9:12 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I bought my lift kit from camburg so it came with camburg UCA. Saved a little money buying one of their packages, plus got 15% off on Black Friday.
    GoldenGoon89 and Tundra2 like this.
  10. Mar 6, 2021 at 9:12 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Or do this.
  11. Mar 6, 2021 at 9:42 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    RustyShackle323 and Tundra2 like this.
  12. Mar 6, 2021 at 9:52 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    If salt matters go with SPC. You don't really want uniballs if you drive on salted roads.
    Tundra2 likes this.
  13. Mar 7, 2021 at 4:26 AM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    This is a great site!
