Leaf Springs Question
Discussion in 'Suspension' started by UTAHRTK, Feb 16, 2021.
  1. Feb 16, 2021 at 4:39 PM
    UTAHRTK
    UTAHRTK [OP] New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    Looking for solutions. Anybody have these Deaver
    Tundra 2007-2020 2wd/4wd – 1 Inch Lift under – Shackle Required (Pair)
    or can recommend similar? I am nor sure which shackle to go with for these... Im looking to improve ride and sync rear with front on trails. Im on Billy 6112s and 5160s- 2" front stock rear. Don't want to go down a rabbit hole. Also, I plan to to run OEM King kit in a couple years once the Billy's are burnt.
  2. Mar 5, 2021 at 8:39 AM
    irishpride114
    irishpride114 New Member
    Travis
    2015 SR5 TRD Double Cab
    What did you find out?
    I read thread earlier about those needing a pretty specific shackle range. Mcm worked with deaver on the shackle and ads suspension. But I wouldn’t worry about your future kings. Wait till you get them
  3. Mar 5, 2021 at 7:27 PM
    UTAHRTK
    SOCAL
    Nothing... I quit.
