Clinking sound...
Discussion in '1st Gen Tundras (2000-2006)' started by Kessel McG, Mar 5, 2021.
  1. Mar 5, 2021 at 12:02 PM
    Kessel McG
    Kessel McG [OP] New Member
    2005 Tundra Double Cab TRD Off Road - Phantom Grey Pearl
    Stock
    So, I’ve notice a clinking metallic sound when I back out of my driveway. Usually within the first 5-10 yards. I can also replicate this sound if I then put it in Drive and go forward about the same distance. Seems like it just happens once and is then gone. Any ideas?
  2. Mar 5, 2021 at 2:03 PM
    Probably a heat shield or the brake backing plate. Double check underneath for loose shields or if you need to bend back the backing plate for clearance.
    Edit: Missed that you stated it stopped. Might be something else.
  3. Mar 5, 2021 at 2:14 PM
    Professional Hand Model
    Fred
    Hand Protectors
    How does the sound go?
  4. Mar 5, 2021 at 2:16 PM
    It’s part of the abs system I believe, it only happens in the morning and only once right?
    Mine does something similar for the last 10’ out of my driveway, then about 5-10 into drive as I’m turning and scooting away
  5. Mar 5, 2021 at 2:16 PM
    Kessel McG
    Stock
    Just one clink/ting in reverse and then sometimes one when I put it back in drive. Not really a clunk. How do I post a video?
  6. Mar 5, 2021 at 2:21 PM
    Fred
    Hand Protectors
    Situation Normal.
  7. Mar 5, 2021 at 2:22 PM
    Kessel McG
    Stock
    @FrenchToasty yeah that sounds about right. It only happens once but not only in the morning. Can happen once each time I start reversing or once when I start driving forward. Dealership said it might be brake pads shifting a bit.
  8. Mar 5, 2021 at 2:23 PM
    Could be brake pads, the slide pins and pads are easy enough to take off and throw sil glide on.
    Jack McCarthy likes this.
  9. Mar 5, 2021 at 3:21 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    I bet it's the pads. Nothing serious I bet.
    Let's clink for something better.
    Jack McCarthy and Kessel McG[OP] like this.
  10. Mar 5, 2021 at 5:38 PM
    Kessel McG
    Stock
    Thanks y’all. OCD in check!
    bleach and FrenchToasty like this.
