Rotated Rear TRD Sway Bar
Discussion in 'Suspension' started by matictundra, Mar 4, 2021.
  1. Mar 4, 2021 at 1:40 PM
    matictundra
    matictundra [OP] New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    For those who rotated the rear sway bar up 90 deg, did you grind the brackets for weld seam diff clearance?
  2. Mar 4, 2021 at 3:12 PM
    I did not and no issues with mine. :thumbsup:
  3. Mar 5, 2021 at 7:44 AM
    matictundra
    Franco
    AZ
    Do you have pictures, close up pix of the mounted brackets?
  4. Mar 5, 2021 at 7:56 AM
    20210305_105306.jpg 20210305_105302.jpg 20210305_105244.jpg 20210305_105233.jpg
  5. Mar 5, 2021 at 7:57 AM
    Yes it still performs the same.
  6. Mar 5, 2021 at 8:03 AM
    If you're just trying to gain length on the sway bar links why not just buy some Hellwig adjustable sway bar links. I have the Hellwig sway bar with a 6-in lift and it's put in there as it was designed to be and everything is straight with the adjustable links. Just an option.
  7. Mar 5, 2021 at 8:05 AM
    matictundra
    Franco
    AZ
    I'm doing it for this exact reason and to gain clearance.
  8. Mar 5, 2021 at 8:06 AM
    Gotcha.:thumbsup:
  9. Mar 5, 2021 at 8:06 AM
    matictundra
    Franco
    AZ
    Thanks. I will ask one more favor (maybe too much) but can you take pix the other way so I can see the other side and how it sits?
  10. Mar 5, 2021 at 9:15 AM
  11. Mar 12, 2021 at 7:20 AM
    OrlandoSR5
    OrlandoSR5 New Member
    Wow, I've seen some Rams with there sway bars indexed like that. Didn't know we can do that with Tundras.
    When I removed the SB from my 2013 and put it on my 2018, I noticed a couple of scratches from when I hit something with it. Been wondering if I could do this to prevent that from happening again and now I know, thanks!
  12. Mar 12, 2021 at 7:34 AM
    Megaman
    Megaman New Member
    2020 Tundra Limited DC 4X4 TRD Silver Sky Metallic
    I just put a new TRD bar on mine a couple days ago. I just followed the instructions that came with it and mounted the SB the normal way. - But I can definitely see mounting it this way above for extra ground clearance....
    BravoDeltaRomeo likes this.
  13. Mar 12, 2021 at 8:01 AM
    lakedrum03
    lakedrum03 New Member
    Seth
    2021 Tundra Platinum
    Working on it.
    Do you guys see a noticeable difference between the stock sway bar and the TRD sway bar?
  14. Mar 12, 2021 at 8:08 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    You should cut a c-notch in the bracket so it clears the weld on the axle.
  15. Mar 12, 2021 at 8:40 AM
    Black
    2014 Tundra Limited CrewMax
    Does anything need to be done to the endlinks?
  16. Mar 12, 2021 at 8:41 AM
    A-A-Ron
    A-A-Ron Done messed up
    Aaron
    Seattle
    2021 Ford F-250 Lariat Diesel
    Are you referring to the stock front away bar vs the TRD one? Most Tundras don’t come with any rear sway bar, I believe just the Pro and Sport models. Adding the rear sway bar makes a big difference. I’ve heard the upgraded front improves the handling some but not a drastic change.
  17. Mar 12, 2021 at 9:00 AM
    The Dude
    The Dude New Member
    Chandler, AZ, not anymore :(
    So if I wanted to install Coachbuilder +3 shackles, would rotating the sway bar in that way be enough for everything to line up?
  18. Mar 12, 2021 at 9:02 AM
    Rex Kramer
    Georgia
    Just make sure they are the appropriate length for what you are doing, mine are shorter than stock because I hung the leaf packs under the axle.
  19. Mar 12, 2021 at 9:15 AM
    OrlandoSR5
    IMHO, the TRD front sway bar made no real difference in the handling that I could feel. The rear made the difference.
    Rex Kramer likes this.
  20. Mar 12, 2021 at 9:18 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Florida trucks are so pretty underneath.
    Retched1 and BravoDeltaRomeo like this.
