blower motor issue
Discussion in '1st Gen Tundras (2000-2006)' started by craig007, Feb 20, 2021.
  1. Feb 20, 2021 at 4:51 PM
    craig007
    craig007 [OP] New Member
    2017 tundra 1794 edition
    hey, my brother-in-law has a 1st gen tundra and is having a trouble with his blower motor and was just wondering what the most common problem is with the blower motor, is is the motor itself or the resistor, and what is the simplest test to do to check out the issue, and info would greatly be appreciated
  2. Feb 20, 2021 at 4:59 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Does he have some speeds and not others, or nothing at all?
  3. Feb 20, 2021 at 5:01 PM
    craig007
    nothing at all and he has already changed the blower motor
  4. Feb 20, 2021 at 5:09 PM
    TILLY
    Massachusetts
    Since he already changed the motor, next thing I would do is check to see if its getting power at the connector.
  5. Feb 20, 2021 at 5:12 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Yeah start at the fuse then go to the relay then connector....kiss
  6. Feb 20, 2021 at 5:14 PM
    craig007
    I believe he said he has power at the motor connector, on one of the wires
  7. Feb 20, 2021 at 5:21 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Probably the Blower Motor Resistor. Its located in the box next to the Blower. Remove the Harness Clip. Watch out for the Servo Cable thingie running in front. Two screws to remove the vertical shaped ‘Resistor’ cover thats attached to a Ceramic Block via Copper Prongs.
    Ohms test Resistor and go from there. They cost about $25 OEM.
    speedtre likes this.
  8. Feb 20, 2021 at 5:40 PM
    craig007
    ok perfect thanks I will let him know to check that out
    thanks very much
  9. Feb 20, 2021 at 5:55 PM
    Fred
    Hand Protectors
    Thank you. Report back!
  10. Feb 20, 2021 at 6:02 PM
    craig007
    sure will I will get him to check that tomorrow
  11. Mar 4, 2021 at 4:39 PM
    craig007
    the problem with the blower not working ended up being a loose connection in the connector that plugs into the blower motor, had taken connector apart tightened up the connection inside the plug, plugged back in and all was good , thanks for all the info and help
  12. Mar 4, 2021 at 5:16 PM
    TILLY
    Massachusetts
    Glad you got it straightened out. :thumbsup:
