Sway Bar
Discussion in '2.5 Gen Tundras (2014-2021)' started by T-Dog, Feb 27, 2021.
  1. Feb 27, 2021 at 8:06 AM
    T-Dog
    T-Dog [OP] New Member
    Hector
    2015 tundra
    What is the difference between a stock sway bar and a TRD sway bar?
  2. Feb 27, 2021 at 8:07 AM
    The front stock sway bar is hollow and weighs 17 lbs. The TRD is solid and weighs 29 lbs.
    toyofan87 and clarkritchie like this.
  3. Feb 27, 2021 at 8:20 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Big difference between the two, TRD bar is more heavy duty and works better. And if you are considering the front, definitely look into adding the rear bar. It makes a large improvement in handling for about $200.
  4. Feb 27, 2021 at 8:48 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    The TRD bar is also bright red vice black of the OEM.
  5. Feb 27, 2021 at 9:15 AM
    greg8765
    greg8765 New Member
    Grant
    Utah
    2021 Cement Tundra
    do you recommend adding both at the same time? or will one or the other do the trick?
  6. Feb 27, 2021 at 9:16 AM
    T-Dog
    Hector
    2015 tundra
    Will the PTR62-OC180 TRD front sway bar fit a Tundra 2015?
  7. Feb 27, 2021 at 9:22 AM
    frichco228
    Frank
    Virginia
    toyofan87 likes this.
  8. Feb 27, 2021 at 12:25 PM
    T-Dog
    Hector
    2015 tundra
  9. Feb 27, 2021 at 2:02 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Add the rear first. Drive it a thousand miles. Then add the front.
    I have both TRD's and love the handling. Note: I don't off road on trails or rocks.
    Saltyhero13 and toyofan87 like this.
  10. Feb 27, 2021 at 6:19 PM
    greg8765
    greg8765 New Member
    Grant
    Utah
    2021 Cement Tundra
    I don't off road either. I'm planning on getting a travel trailer this summer and think these will help.
  11. Feb 27, 2021 at 6:34 PM
    T-Dog
    Hector
    2015 tundra
    frichco228- Why is it that when I look at the web site it tells me it won't fit on my truck?
  12. Mar 1, 2021 at 4:12 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    I have both and they are great upgrades. Hellwig makes a rear I believe is even stiffer than the rear TRD bar.
  13. Mar 1, 2021 at 4:14 AM
    Professional Hand Model
    Fred
    Hand Protectors
    coTony likes this.
  14. Mar 1, 2021 at 4:52 AM
    maxdriver
    maxdriver New Member
    ‘23 GRolla, sans ‘19 Tundra
    Both TRD sway bars are part of the Sport package. I don't off-road and love the setup for the street. The lack of body roll in a vehicle this size as a result is impressive. As others have said, the rear bar will make the most noticeable improvement in handling.
    Megaman and Saltyhero13 like this.
  15. Mar 2, 2021 at 6:31 AM
    Megaman
    Megaman New Member
    2020 Tundra Limited DC 4X4 TRD Silver Sky Metallic
    I have a '20 Tundra Limited TRD off road DC. I've noticed that there's a LOT of body roll in my truck, and after reading through this thread for the first time, I looked under the rear of my almost new Tundra to discover that there's no sway bar at all!! I've not looked at the front yet.
    Is it common for these trucks (the non sport packages) to not have a sway installed from the factory at all? I'll be at least ordering the rear TRD sway bar, and most likely the front later on. The truck will not normally see any use off road.
  16. Mar 2, 2021 at 6:36 AM
    You will have a front sway bar from the factory. It is hollow and is 17 lbs. The TRD is solid and weighs 29 lbs. Only certain trims (Sport and higher) had the rear sway bar from the factory.
    maxdriver and Megaman[QUOTED] like this.
  17. Mar 2, 2021 at 6:51 AM
    Megaman
    Megaman New Member
    Thanks! So is it common for the Off-Road packages to have a hollow front sway bar on the front and none at all in the rear?
  18. Mar 2, 2021 at 6:54 AM
    That is correct. All Tundra models from 07 and up have a front sway bar.
  19. Mar 2, 2021 at 6:55 AM
    Megaman
    Megaman New Member
    - And no sway bar on the rear....Thanks again!
  20. Mar 2, 2021 at 6:59 AM
    JerryH
    JerryH Gravy Boatin, I don’t park I dock.
    SOMD
    2020 Crewmax Limited Cement
    I put the TRD rear sway on my 20 Limited and it is a noticible difference for sure. Noodling over putting the front one on or putting money towards other mods.
  21. Mar 2, 2021 at 8:23 AM
    Saltyhero13
    For me, the upgraded front sway bar made about 25% difference compared to how adding the rear sway bar made about 75% overall difference. It is noticeable just not as dramatic of an improvement as compared to adding the rear. Note I'm running the offroad package shocks (not the PRO shocks)
  22. Mar 2, 2021 at 8:33 AM
    JerryH
    SOMD
    Thanks, I like your %’s. I’m running stock limited shocks. Might throw the front on while the free shipping deal is still on.
    Saltyhero13[QUOTED] likes this.
  23. Mar 2, 2021 at 8:36 AM
    Saltyhero13
    I think its worth it as long as your aren't doing heavy off-roading where articulation is needed.
  24. Mar 2, 2021 at 8:47 AM
    JerryH
    SOMD
    Just occasional Summer beach driving, nothing heavy. Looking into a travel trailer in the next couple years so it should definitely help with towing also. Appreciate ya
  25. Mar 3, 2021 at 5:36 PM
    T-Dog
    Hector
    2015 tundra
    Has anyone installed a part no. PTR620OC180 front sway bar on a 2015 Tundra? Wondering if it'll fit before I purchase one.
