Westcott Designs and Wheel offset
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by gamecockgrad1215, Jan 20, 2021.
  1. Jan 20, 2021 at 6:22 PM
    gamecockgrad1215
    gamecockgrad1215 [OP] New Member
    2023 TRD PRO
    Westcott Designs TRD PRO lift
    I just installed the Westcott designs lift and my tires got smaller somehow :). I want to buy 17in method mr312s (+0 offset) wrapped in 35s. How bad will I rub with the Westcott designs lift? Bmc and bumper shims required?
  2. Jan 21, 2021 at 2:38 AM
    Bad Cow
    Bad Cow GOD Bless The USA
    Georgia USA
    2019 TRD PRO - SUPER WHITE
    Leather Steering Wheel, +1.5" Shackles
    Looks great to me the way it is. You don't want to eat up all your fender well space with tire. That space gives you room to play with.
    baron and tttrdpro like this.
  3. Jan 21, 2021 at 8:58 AM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    Your baby needs a bath, but otherwise looks perfect to me. what size tires are you running now?
  4. Jan 21, 2021 at 8:59 AM
    gamecockgrad1215
    2023 TRD PRO
    Sure does! These are 305/65/18 BFG K02.
  5. Jan 21, 2021 at 9:25 AM
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    I was thinking about going with the Wescott lift on my Pro but thought my 275/70’s would look small. Those 305’s are basically the same diameter as my 275’s and it looks really good in my opinion. Did you use the block in the back or shackles? Do you have any other pics from different angles?
  6. Jan 21, 2021 at 9:34 AM
    gamecockgrad1215
    2023 TRD PRO
    I put a one inch shackle in the back.
    One inch shackle on rear.
    Bad Cow and FISHN43[QUOTED] like this.
  7. Jan 21, 2021 at 10:10 AM
    Bad Cow
    Georgia USA
    Smart choice sir. :thumbsup:
  8. Jan 21, 2021 at 3:20 PM
    Weavin Pro
    Weavin Pro New Member
    2020 Army Green TRD PRO
    I have 35x12.50x18 on mine with the Coachbuilder shims...a bmc and little heat gun to the front fender well and it’s fits just fine. I had the bumper shims which made it super easy...but when I added the SSO winch bumper I had to remove them. If you had the shims you would not have to use the heat!
    Patch999 likes this.
  9. Jan 21, 2021 at 5:56 PM
    gamecockgrad1215
    2023 TRD PRO
    I'm surprised you needed a BMC - must have been close! Thanks for the info. Your truck is sick.
  10. Jan 21, 2021 at 6:15 PM
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    I feel like I messed up getting the +3 CB shackle as I don't want too much rake. Getting my Westcott installed on the 1st.. wondering if I should order a +2 instead :monocle:
  11. Jan 21, 2021 at 6:23 PM
    gamecockgrad1215
    2023 TRD PRO
    My one inch shackle actually gave me
    About 1.5 inches which still gives me a slight rake.
  12. Jan 21, 2021 at 6:25 PM
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    CB's site says the +3 gives an actual 1.75" of height. I've seen on this site that Westcott gives an actual 2" of lift in the front.. figured it would work out. Oh well, guess we'll see! Truck looks great!
    robertz81 likes this.
  13. Feb 18, 2021 at 7:38 PM
    robertz81
    robertz81 New Member
    Robert
    Upland, California
    2020 Tundra TRD Pro
    Current Mods. Gtechniq Ceramic Coating - Shine Detailing Xpel PpF Full front Clip - Premier Armor Xpel Prime XR Plus 5% All Around & 70% on Windshield - Premier Armor Nitto Ridge Grapplers 295/70/R18 - Americas Tire AJT Design Blacked out Steering Wheel Emblem AJT Design Army Green Alarm Fob Case
    I purchased the same +3 CB shackles. I also have the Westcott Design for the front. Ran some calculations and I should be 1/4 taller or flat once installed. I was actually looking to keep the nose high look but I’m good with a slight rake . Please post pics if you get yours installed before I do. Planning for next month.
    Thx.
  14. Feb 18, 2021 at 7:47 PM
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Had mine installed Feb 1st. You're pretty much right on the money! Very slight rake
  15. Feb 18, 2021 at 9:38 PM
    robertz81
    Robert
    Upland, California
    2020 Tundra TRD Pro
    Perfect stance. Thanks for sharing.
    V10Ace[QUOTED] likes this.
  16. Feb 19, 2021 at 3:59 AM
    FISHN43
    FISHN43 New Member
    Ohio
    I’m looking at the Wescott lift for my Pro. Yours looks awesome. What size tire did you go with? Do you have any other pics to share?
    robertz81 and V10Ace[QUOTED] like this.
  17. Feb 19, 2021 at 5:42 AM
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    What angles are you looking for? It's been raining nonstop but I'll see what I can do.
    Tires are 295/70 Cooper STT Max. Also using 1" Bora wheel spacers
    robertz81 and FISHN43[QUOTED] like this.
  18. Feb 19, 2021 at 6:28 AM
    Patch999
    Kyle
    2017 Bad@$$ TRD Pro
    Looks great.
  19. Feb 19, 2021 at 8:07 AM
    FISHN43
    FISHN43 New Member
    Ohio
    Maybe some pics from the front/back that are slightly angled, if that makes sense?
  20. Feb 21, 2021 at 9:24 PM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Has anyone checked the gas mileage after doing the westcott lift and bigger tires?
  21. Feb 25, 2021 at 5:34 PM
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Hopefully this helps. Haven't had a chance to go on any trips due to work, sorry about the parking lot pics
    MDJK, trekkar and PNWTundra2021 like this.
  22. Feb 25, 2021 at 6:07 PM
    FISHN43
    FISHN43 New Member
    Ohio
    Your truck looks awesome! Thanks! Love the look. Definitely adding the Wescott to my mod list.
  23. Mar 2, 2021 at 7:38 PM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    this is the westscott front with cb +2
  24. Mar 16, 2021 at 8:56 PM
    Mouax094
    Mouax094 New Member
    2016 Tundra Pro
    Not sure if this has been asked yet but is anyone running a diff drip for the Wescott front kit? I believe Coachbuilder includes the diff drop in their kits. Thanks!
  25. Mar 16, 2021 at 9:00 PM
    cctxquicksand
    I am running the carrier bearing drop kit... I actually have an extra one I didn’t realize the shackles come with it already and I ordered a spare
    Mouax094 likes this.
  26. Mar 16, 2021 at 9:01 PM
    MaxPower
    MaxPower New Member
    18 Tundra TRD Off road
    Are you interested in selling your Pro wheels, if so what's your location?
  27. Mar 16, 2021 at 9:02 PM
    cctxquicksand
    I already sold them
  28. Mar 28, 2021 at 10:37 PM
    Mf32
    Mf32 New Member
    2020 TRD Pro Super White
    What tires and wheels are those? Also it looks from the photo like the truck may be on a slight decline. Is it level?
  29. Mar 29, 2021 at 8:15 AM
    cctxquicksand
    I’m on gramlights with 295/70/19 ridge grapplers
    yeah looking again it does look like a small incline. Here’s a better pic
    LyonKing likes this.
  30. Mar 29, 2021 at 8:28 AM
    Mf32
    Mf32 New Member
    Looks nice and pretty level! What made you lean toward the +2 instead of the +3?
