Light connection for trailer
Discussion in 'New Member Introductions' started by Capt chuck, Mar 2, 2021.
Brake and turn light on right sight of trailer don’t work thru the 7pin connection
  1. Color
    0 vote(s)
    0.0%
  2. Tired
    1 vote(s)
    100.0%
  1. Mar 2, 2021 at 11:18 AM
    Capt chuck
    Capt chuck [OP] New Member
    Chuck
    2013 tundra
    2013 tundra
    Right brake and turn light don’t work thru the 7 pin connector
    YardBird likes this.
  2. Mar 2, 2021 at 11:21 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Welcome
  3. Mar 2, 2021 at 11:31 AM
    AZBoatHauler
    So.Arizona
    That is pin 6 in the diagram above. Note the notch for orientation. Put a digital multimeter on pins 1 and 6 and have someone press the brake while you check for voltage. If you get voltage, the problem is with your trailer harness and not the truck.
    P-Factor, Prostar 190 and JohnLakeman like this.
  4. Mar 2, 2021 at 11:35 AM
    Capt chuck
    Chuck
    2013 tundra
    Hi there
    No power from the truck side
    Connection
  5. Mar 2, 2021 at 12:10 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! You check the applicable fuses?
  6. Mar 2, 2021 at 12:16 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Repeat the digital meter test at the harness connector where Pin 6 connects. You may have a bad connection inside the receptacle.
    If you have nothing at the harness connector either, then your next stop is going to be at the flasher relay. The brake (stop) signal goes into flasher relay on one terminal, comes out as trailer turn/stop on two other terminals (right and left).
    Failure2comply and AZBoatHauler like this.
  7. Mar 2, 2021 at 1:00 PM
    Welcome from Ohio
  8. Mar 2, 2021 at 3:07 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  9. Mar 2, 2021 at 3:09 PM
    Welcome from NY.
  10. Mar 4, 2021 at 3:30 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Welcome from the wet side of WA.
