  1. Mar 9, 2017 at 7:17 AM
    #61
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    :worthless:
    dak13 likes this.
  2. Mar 11, 2017 at 11:40 PM
    #62
    shaw0531
    shaw0531 New Member
    Jake
    2006 Spectra Blue Mica Tundra SR5 2WD DC
    Hauled about 1400lbs of hickory wood today
  3. Mar 14, 2017 at 8:36 AM
    #63
    Hasteen
    Hasteen To be continued...
    Justin
    Providence, RI
    2004 DC SR5 Texas edition 2016 CM 1794 edition
    1ST GEN Toytec 3/1 lift kenda 33s on 17x9 RockTrix RT107 BruteForceFab front bumper ----------------------------------- 3RD GEN rough country 6" Toyo 35's on 22x10 Fuel Assault TRDPro Grille
    New carrier bearing and u joints :bananadance:
    Jbickel and tacoguybill like this.
  4. Mar 15, 2017 at 9:00 PM
    #64
    donaldp83
    donaldp83 New Member
    2001 TRD Off Road
    Last weekend I replaced the radiator, hoses, thermostat and housing, serpentine belt, reattached an O2 sensor after the nuts rusted off, and changed the fuel and air filters. I was pleasantly surprised at how simple it all was. Then...
    On Sunday I heard a clunking, and realized the back fuel tank strap had broken (rusted) and was getting smacked around by the driveshaft. So I drove for a week with a ratchet-strap holding it up until the new straps arrived...
    kenomouth64 likes this.
  5. Mar 19, 2017 at 11:07 PM
    #65
    AaronK
    AaronK New Member
    Aaron
    2002 White Tundra AC SR5 4x4
    New steering rack bushings...Pretty easy job!.
  6. Apr 3, 2017 at 5:03 AM
    #66
    Hasteen
    Justin
    Providence, RI
    Where is the location where I can relieve the fuel pressure so I can take off the filter?
  7. Apr 3, 2017 at 5:08 AM
    #67
    Cfincke
    Cfincke Mall Crawler but capable
    San Antonio
    2014 Tundra 1794 CM 5.7 4x4 sunset bronze
    5.29s, Auburn LSD, 37x12.50R18, Icon coilovers and shocks, SPC UCA's, Tech 12 Volts sound system, Enve Grill
    I replaced the radiator this weekend due to a leak in the plastic
  8. Apr 3, 2017 at 5:31 AM
    #68
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    When I changed the fuel filter out on my 2000 I just popped the lines off. Didn't have to bleed pressure off. It did leak the whole time so be prepared!
  9. Apr 3, 2017 at 6:28 AM
    #69
    Hey Justin fixing to do same on my T100 is it hard to do? Any info or pics greatly appreciated
    FirstGenTundra likes this.
  10. Apr 3, 2017 at 3:16 PM
    #70
    merve101
    merve101 New Member
    05 DC
  11. Apr 3, 2017 at 3:18 PM
    #71
    merve101
    merve101 New Member
    05 DC
    Here is the before photo
    LaaMahTundra likes this.
  12. Apr 3, 2017 at 5:19 PM
    #72
    Mike Tread lightly.
    south carolina
    2003 tundra sr5 4x4 stepside....
    yep bank account is running low from it..
    Let it sit over night if you don't want to get sprayed with fuel and loosen you gas cap to relieve tank pressure.
    Hasteen[QUOTED] likes this.
  13. Apr 3, 2017 at 6:42 PM
    #73
    Hasteen
    Justin
    Providence, RI
    d
    Get an impact and rent the u joint/ball joint tool at oreilly auto parts. i had to loosen my ujoints at front and and mid place to get my intermediate shaft off, once i had that off and the support bearing unbolted i stood it up i literally pulled the whole thing off pried off part of it and installed the new one. and i also looked at many youtube videos.
    i spent 7 hours working on it with my dad we aren't mechanics but we have some basic knowledge. so unfortuneatley no pictures:(
  14. Apr 3, 2017 at 6:48 PM
    #74
    Took about 2 hrs on mine unbolted main shaft by double cardan joint unbolted center carrier bearing then unbolted smaller shaft by tranny carrier bearing came right off i rented puller but didnt need used impact gun to take off nut in center center bearing slid off cleaned up greased slipped new one oneIMG_20170403_120835.jpg
  15. Apr 3, 2017 at 6:53 PM
    #75
    Hasteen
    Justin
    Providence, RI
    i used the impact to take the u joints out.
  16. Apr 3, 2017 at 6:55 PM
    #76
    Got grease zerks on mine greased em up
  17. Apr 3, 2017 at 6:57 PM
    #77
    Appreciate info:thumbsup:
  18. Apr 9, 2017 at 5:16 AM
    #78
    Golfmiester
    Golfmiester New Member
    Mark
    2005 Toyota Tundra double cab
    Toytec adjustable coilovers , bamuffler cat back afe cold intake 265/75/16 Goodyear authority wranglers
    Changed out my all old bulbs in my exterior to led lights much more brighter like it a lot
  19. Apr 19, 2017 at 9:41 PM
    #79
    Hasteen
    Justin
    Providence, RI
    upgraded to LED headlights love the bright white, plugged in the fog lights but they wont turn on. trying to check the fuse but its damn near impossible to pull out... update coming soon but here are the headlights.:drool::drool::drool::drool:
    Update: I flipped the connection on the fogs apparently Japanese vehicles like to use the ground wire as power, forgive me if I didn't know. Lol
    tacoguybill likes this.
  20. Apr 25, 2017 at 5:30 AM
    #80
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I replaced the glass door on my LEER hi top after the automatic carwash used & abused the original.04.19.17.jpg
  21. May 2, 2017 at 3:40 PM
    #81
    chunk
    chunk New Member
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    And today, i went to my local smog check man and got my certificate of compliance $44.95 and another $193.00 for California DMV, I'm good for another year. Chunk.
    Sampson, kenomouth64 and Jsena like this.
  22. May 2, 2017 at 3:41 PM
    #82
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    $45 is expensive for smog.. $193 is cheap.. Must be nice lol
  23. May 2, 2017 at 3:48 PM
    #83
    chunk
    chunk New Member
    They're both kinda pricey really, I've got 5 vehicles to keep on the road, but it's the price i pay to live in So Cal i guess.
    The smog check now is nothing more than the state computer downloading the data from the trucks obd II, and if there are no error codes, it's a pass. Takes about as long as it takes to download a couple of songs. Chunk.
  24. May 2, 2017 at 3:49 PM
    #84
    Mike Tread lightly.
    south carolina
    Holy crap at the price.
  25. May 2, 2017 at 4:02 PM
    #85
    chunk
    chunk New Member
    If you mean expensive, i agree, that red motorcycle in my avatar to the left is 40 years old and cost $93.00 per year for DMV fees, and California just added an additional 12 cent gallon gas tax and a DMV per vehicle sur charge of up to a maximum of $175.00 per vehicle, per year to start next year. But I'm sticking out out here, the weather is to nice to go elsewhere. I like sun and surf. Chunk.
  26. May 5, 2017 at 9:15 PM
    #86
    banta4x4
    banta4x4 New Member
    Josh
    2006 Tundra Double Cab TRD 4x4
    285/70R17 BFG All Terrain KO2 17 x 8.5 Stealth Custom Series Stealth 6 Bilstein 5100/5150 F/R
    Hey, I am having the same issue... flipped the connection? As in swapped the red and black wires?
  27. May 6, 2017 at 4:27 AM
    #87
    Hasteen
    Justin
    Providence, RI
    @banta4x4 Noooooooo flip the bulb 180* degrees
  28. May 27, 2017 at 7:34 AM
    #88
    merve101
    merve101 New Member
    05 DC
    1.5" wheel spacers
    4XFamily06 and Hasteen like this.
  29. May 27, 2017 at 8:27 AM
    #89
    Hasteen
    Justin
    Providence, RI
    I have the same size on mine
    merve101[QUOTED] likes this.
  30. May 27, 2017 at 3:39 PM
    #90
    Hasteen
    Justin
    Providence, RI
