2020 Crewmax doors won’t close
Discussion in 'General Tundra Discussion' started by Jhawkins32, Feb 27, 2021.
  1. Feb 27, 2021 at 7:24 AM
    Jhawkins32
    Jhawkins32 [OP] New Member
    Jay
    2021 Crewmax SR5
    2020 Crewmax doors won’t close. Cab is air tight because I can open another door and they shut fine.
    What is the fix. Should I take it back to the dealer.
  2. Feb 27, 2021 at 7:27 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Are you taking about having to just make sure you give the door a good firm shut to close (especially the rears)? I have the same thing in my 21, but have gotten in the habit of just making sure to be firm when I shut them
  3. Feb 27, 2021 at 7:28 AM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    I'll bite. Your truck isn't airtight unless the USN built it. Try rolling a window down partially to test your theory. Regardless, a dealer visit would be recommended. Maybe some insulation/rubber molding is off kilter.
  4. Feb 27, 2021 at 7:28 AM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Shut the door a little harder. Every Tundra I have had if there is not a window down then they do not shut with a touch of the index finger. I am on the wife all the time to stop slamming the doors! I explain that when a door is open already or a window is down you do not have to Hulk the door shut!! Doors should be fine that is just the way new vehicles are or can be.
  5. Feb 27, 2021 at 7:39 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    There are flapper vents in the rear of the cab who's sole job is to vent cabin overpressure when closing doors or if the airbags deploy.
  6. Feb 27, 2021 at 7:39 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Take it back.... check your dash and your door trim. waaaay back in 07 I started having similar issues with the driver door needing a little more motivation in closing, then I started noticing scratches where the door meets the dash as it was completely discolored on both sides. they had to realign both front and back doors on the driver side, as well as touch up both dash and door trim.
    Sunnier likes this.
  7. Feb 27, 2021 at 8:21 AM
    Nomoredomestics
    Nomoredomestics New Member
    GA
    2023 TRD Sport 4x4
    Knocking out a window would help :boink:. .. lol. . Kidding . . Honestly, I think it's normal for these trucks . My 19 and my 21 are the same way. Seem to be a little harder to shut than most trucks. .maybe it's the weight, maybe it's sealed better. . ..but I don't see it as an issue.
    Black@Blue19 likes this.
  8. Feb 27, 2021 at 9:09 AM
    Sunnier
    Sunny
    San Diego, CA
    I always have to Hulk the door shut. :D
    Black@Blue19[QUOTED] likes this.
  9. Feb 27, 2021 at 7:05 PM
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    How is this even a problem? My 2021 is the same way, but it tells me my truck is well sealed rather than something that requires a dealer visit.
    Close the door a little harder.
    Terndrerrr and Black@Blue19 like this.
  10. Feb 27, 2021 at 8:12 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    Both the old 2014 and the current 2020 are hard to close when the truck is closed up. Different story when a door is open.
  11. Mar 2, 2021 at 6:22 AM
    Kung
    KG, VA
    Same. I can tell the truck is 'sealed' better than the last 2 trucks I've owned for sure. I see it as a good thing.
  12. Mar 2, 2021 at 6:29 AM
    bsktball55
    bsktball55 New Member
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    Could just be the weather stripping being new too. I had a deer hit me on my driver's side last winter and they had to reskin both doors. They put new weather stipping on them and it took a while to get them to close all the way without significant force.
