  1. Feb 28, 2021 at 10:22 PM
    BWPRO
    BWPRO New Member
    Bryce
    2021 Tundra TRD PRO
  2. Feb 28, 2021 at 10:31 PM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    Google CN Designs Tundra and his FB link will come up.
    Casey made his himself, but apparently he's some sort of mad scientist genius.
    Astom22 and RainMan_PNW like this.
  3. Feb 28, 2021 at 10:33 PM
    BWPRO
    BWPRO New Member
    Bryce
    2021 Tundra TRD PRO
    Yeah I've seen his build and it's crazy how he can rip apart his entire truck and then put it back together better than how he got it lol appreciate the info!
    RainMan_PNW likes this.
  4. Feb 28, 2021 at 10:34 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    No, just equal parts OCD and Autism with a splash of tourette’s. :thumbsup:
    Helps I’ve got access to a printer and the software, and I’m a grade-A geek.
  5. Mar 1, 2021 at 2:46 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Nice Rig, how do you like those Rhino RB20s??
    First time to see on a DC, most views on a CM. Well done.
  6. Mar 1, 2021 at 3:57 AM
    Jp-ProMamba
    Jp-ProMamba New Member
    Jp
    2020 Toyota Tundra Trd Pro
  7. Mar 1, 2021 at 4:27 AM
    CorsoTundra
    CorsoTundra This is the way
    North GA
    2021 Cement Trail Edition
    Toytec Aluma 3/1.5, Pro headlights, OEM LED fog lights, AJT chrome delete, interior/exterior LEDs, front TRD sway, 18x9 Method Roosts, 285/75/18 Toyo A/T 3, RCI engine skid,
    Not too bad. I bought the harness from accessorides and the switch panel from CN Designs.
  8. Mar 1, 2021 at 4:45 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    so i have a couple of things for tires. i use optimum power clean cut 4:1 in a spray bottle and I use a power drill brush like that. depending on what I have available to do in terms of time will determine what I use. i'll use CoverAll from O'reilleys if short on time. I bought it in a gallon jug and put it in a spray bottle. There is an aerosol, but after liking it, i just bought the gallon. If I have more time available to do a thorough job, i'll get it prepped really well then apply optimum's tire coating. IT'S A TIRE COATING! similar to a ceramic coating, you have to make sure you prep the tires and make sure it can bond well....then you apply the tire coating and you're good for a couple months. it's alot easier to apply on car tires that don't have an aggressive sidewall. i've done it with a microfiber cloth, but it takes more time and effort....so be prepared. look around in the detailing threads and you'll find alot of tire care stuff. hope that helps a bit
    carsonhudson[QUOTED] and jtwags like this.
  9. Mar 1, 2021 at 7:23 AM
    TelemarkTumalo
    TelemarkTumalo New Member
    Mark
    Bend, OR
    Thanks Seth. I labored over running boards and steps for several months. I'm not a fan of how running boards look, but function won over form in my case. The RB20's were the best looking boards I found. These are in the bedliner finish.
    Pro's:
    Traction is excellent. The finish is like 40 grit sandpaper. Various shoes and boots and none slip.
    Installation. Simple, although instructions were either missing, or my set included in the box were for a Dodge.
    Strong. No flex.
    Adjustable. You can turn them front to back and have a wider footprint to the front or to the back. Plus you can adjust them closer to the body or wider away from the body. Mine are currently adjusted outward for more width to prevent parking lot door dings.
    They catch dirt and rock sling from the tires very well
    Slots on foot boards drain water and snow very well.
    They function perfectly as intended. Wide platform and I use them every time I get in and out of the truck.
    Con's:
    Bed liner finish is $$$
    They look like running boards
    They stick out far enough that it makes reaching into the console awkward from outside the truck. I can do it, but a reach.
  10. Mar 1, 2021 at 8:33 AM
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    Love It! :thumbsup:
  11. Mar 1, 2021 at 8:46 AM
    RLHULK
    RLHULK Too many gamma rays in all that BBQ smoke.
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    Bigfoot tells people he had seen me but no one believes him
  12. Mar 1, 2021 at 11:00 AM
    Hcreager
    Hcreager New Member
    Glendale, AZ and Vail, CO
    2017 Black Tundra Platinum
    Winjet Tail Lights, TRD Intake, Magnaflo exhaust, Morimoto Head/Fog Lights, Upgraded LED's interior/exterior, Chrome delete interior, plati-dipped grill and hood bulge grill....hopefully many more to come
    Where did these bed lights come from...super clean looking install!!
  13. Mar 1, 2021 at 11:02 AM
    RainMan_PNW
    Casey
    Clark County, WA
  14. Mar 1, 2021 at 11:11 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Man, I'm at 8919 this morning; only had mine about 4 months too. What's your commute like? I was doing 100 miles to and from work from when I got the truck until last month.
    Did a ton of traveling around the North East so that accounts for roughly 3-4k miles on the truck.
  15. Mar 1, 2021 at 11:24 AM
    RainMan_PNW
    Casey
    Clark County, WA
    I’m 60 miles round trip each day for commute, except for 1-2 trips to Seattle every month. One day a week to the ski hill (~140 miles round trip). And then day trips on the weekends. If I’m going somewhere, we’re going in my truck.
    TelemarkTumalo, Kung and CappyKD like this.
  16. Mar 1, 2021 at 11:29 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Hah, sounds about right. I've been taking 2-3 trips to NYC or Boston every month and to either Okemo or Mount Snow every 2 weeks or so.
    Fiance tells me to take her little Acura RSX, even though it'll save gas and keep me from freaking out with my mileage going up, I'd rather have her be comfortable than all bumpy with her RSX's suspension.
  17. Mar 1, 2021 at 12:55 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Definitely agree on this. Had rented an F250 last year and when driving that, the tow mirrors on those Fords are amazing.
    CappyKD likes this.
  18. Mar 1, 2021 at 12:56 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Haven't seen a DC TRD Pro in a while... looks beautiful!
  19. Mar 1, 2021 at 1:05 PM
    TelemarkTumalo
    Mark
    Bend, OR
    It appeared the DC Pro's were going away there for a bit. No Pro's at all in 2018, then no DC Pro's in 2019 or early 2020. Mine has a build date of Aug. 2020. I don't know if they were making them in winter/spring of '20. But, I've seen several of the Lunar Rock DC's in '21. And, I've yet to spot another AG DC Pro. Must be a rare bird?
  20. Mar 1, 2021 at 1:25 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    Converted my key and fob to a flip key. No reprogramming needed, moves the internal bits from the fob and and the chip inside the key to the new flip key housing. Only had to get the new key cut.
  21. Mar 1, 2021 at 2:33 PM
    War_Wagon312
    War_Wagon312 Puddle Dodger
    Rich
    2016 Pro MGM CM
    Toyo MT 285/70/R18, led's all around, Baja Design squadron sport fogs, spider trax 1.5 spacers, led foot well lighting, interior chrome delete, kc hilites 40inch light bar grill mounted, 20%tint all around, color lugs black lugnut caps, 2019 pro head lights, led lights all around, spyder co tail lights, DMX1057xr, super crew box with kicker 10” sub,jbl door speakers, factory amp bypass trd air flow accelerator with drop in filter, x3 battery, Toyota bed cover, swing case,
    Link? That thing is slick
  22. Mar 1, 2021 at 2:33 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Didn’t do anything to #belugathetundra today, aside from taking this nice photo of her!
    Glad I work in a warehouse so that all these parts I order later are cheaper for shipping with a commercial address.
  23. Mar 1, 2021 at 2:49 PM
    AZBoatHauler
    So.Arizona
    Received and installed RCI fuel skid. Anxiously awaiting the engine and trans skids.
    Ostrich, equin, 2020Platinum and 14 others like this.
  24. Mar 1, 2021 at 2:49 PM
    War_Wagon312
    Rich
    2016 Pro MGM CM
    No mods just kool looking pic.
    RBB, Ostrich, equin and 23 others like this.
  25. Mar 1, 2021 at 2:54 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    a few
  26. Mar 1, 2021 at 4:30 PM
    ryanryan34
    ryanryan34 "Its almost done"
    Olympia WA
    2016 Supercharged Overland Build
    Supercharger, Carven Cat-Back, Rough Country Heavy Duty Front and Rear Bumpers with grill insert, , BDS 3" Suspension Lift, 18x9 XD 820s, Kenda Klever 33x12.5, AJT Designs interior items, De-badged, Tuffskins custom door sills, RCI Skid plates. Victory 4x4 Bed rack and Stiffeners. Roofnest Condor XL RTT
    What parts did you use to mount your traction boards and what boards are those? Looks really good and pretty easy install
  27. Mar 1, 2021 at 4:49 PM
    ErikTRDTUNDRA
    ErikTRDTUNDRA New Member
    Erik
    2018 Tundra crewmax 1794
    M10 threaded rod and some electrical K line with the M10 bed rail cleats . Worked great and solid as a rock. Had to get longer M10 threaded rods today to finish it up.
    NewImprovedRon and mgm16trdpro like this.
  28. Mar 1, 2021 at 4:51 PM
    ErikTRDTUNDRA
    Erik
    TheBlackPearl likes this.
  29. Mar 1, 2021 at 4:52 PM
    Ltaco17
    Ltaco17 New Member
    NC
    2023 TRD Pro
    285/75/18 Falken Wildpeak R/T color matched handles and mirrors.
  30. Mar 1, 2021 at 4:52 PM
    BWPRO
    BWPRO New Member
    Bryce
    2021 Tundra TRD PRO
    Put on my rhino trailer hitch lock.
