Catalytic converter security
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2mchfun, Feb 28, 2021.
  1. Feb 28, 2021 at 7:22 PM
    2mchfun
    2mchfun [OP] Cool story, but did your new TTV6 tow a shuttle?
    Just had a thought and decided to share it. Thinking catalytic converter security and I know many are buying expensive skid plates. I don't like to trap heat, so I thought about warehouse shelf racks because I can buy them all day long for 35 cents per pound used. They typically have a couple channels welded to the wire mesh that could maybe be drilled to bolt up to the frame. I haven't looked at the location yet, but I can fab and weld anything that I can dream up so this is going on my to do list if it looks like a practical idea once I crawl underneath and take a good look. From experience, these cut okay with decent bolt cutters, however it would be challenging to do so under a truck! Plus very noisy with a loud snap on every cut. Just an idea to help those who like to harden targets. Screenshot_2021-02-28-21-08-23.jpg
  2. Mar 1, 2021 at 10:41 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    The thieves are using some form of cordless saw/cutting wheel. If they have the balls to make the noise to cut off the CC, then I would think they would make swiss cheese out of these shelf racks. I've cut these shelf racks before with a cutting wheel and it only takes a split second.
    Leo's first likes this.
  3. Mar 1, 2021 at 11:00 AM
    I agree. Buy the right stuff the first time!
  4. Mar 1, 2021 at 11:04 AM
    RLHULK
    RLHULK Too many gamma rays in all that BBQ smoke.
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    I had the same concern about heat build up. I was assured that there is plenty of area for ventilation and not to worry about it by my dealer.
    DE plate installed
    Tundra9880 likes this.
  5. Mar 1, 2021 at 11:05 AM
    2mchfun
    Actually on my 21 it is 5 bolts per side no cutting required. 3 bolts on each front flange 2 bolts rear flange front and rear cc seperated with an easily unbolted cross member. Almost no noise whatsoever.
  6. Mar 1, 2021 at 11:11 AM
    RLHULK
    Rich
    2022 Silverado LT.
    they will use a cordless recip saw and do not care about neatness
    they will slice right thru your flange then you are buying manifolds
    cut your sensor wires as well there’s more cost
    The plates are a deterrent. They won’t want to stick around and draw the attention they would get by extended loud noise.
  7. Mar 1, 2021 at 11:11 AM
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    I am thinking the same way, not really thrilled about adding a heavy skid plate since I tow and need every pound of payload I can get. I thought this was a pretty good idea. Member used tool steel that is hard to cut through and would dull a reciprocating saw pretty quick. He had a muffler shop weld it to the pipes so using a pipe cutter wouldnt work either, less than $100 total.
  8. Mar 1, 2021 at 11:20 AM
    2mchfun
    If I am not mistaken it looks like the cross member can be unbolted and then flanges unbolted and all welding was useless, whole assembly gone. Just my opinion, hard to see the rest of the tool steel behind the cross member.
  9. Mar 1, 2021 at 11:29 AM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    Good thing thieves have 4" cut bandsaws, at least that is what I would use.
  10. Mar 1, 2021 at 11:53 AM
    2mchfun
    Going to jail or getting shot anyway if caught, so why not just drop driveshafts and winch whole trucks on car hauler. Go big!
    jtwags likes this.
  11. Mar 1, 2021 at 3:11 PM
    Sh#@, with a 6,000+ lb truck, adding a 40 lb skid plate would be the least of my worries.
    2mchfun[OP] likes this.
  12. Mar 1, 2021 at 3:33 PM
    RLHULK
    Rich
    2022 Silverado LT.
    I put around 400 miles on mine this weekend after the install, mileage stayed the same 17 highway.
  13. Mar 1, 2021 at 3:45 PM
    Yep....no different than hauling a passenger lol.
  14. Mar 1, 2021 at 4:13 PM
    RLHULK
    Rich
    2022 Silverado LT.
    i almost wanted to run over something so I could grin as it bounced off that big hunk of flat plate steel lol
