4 LO flashing, no 4 LO, engine light and TRAC light on too.
Discussion in '2nd Gen Tundras (2007-2013)' started by VTClass4Road, Feb 28, 2021.
  1. Feb 28, 2021 at 4:35 PM
    VTClass4Road
    VTClass4Road [OP] New Member
    2012 CrewMax with Boss V-Plow
    none
    I have a 2012 Tundra 4.6L Crewmax that I use for plowing. I made the usual .7 mile downhill light plow run, mostly idling/coasting, on the way down to the main road to run an errand, switched from 4HI to 2WD once I finshed plowing. I drove about 4 miles and parked for a bit more than one hour and when I started up the truck 3 lights came on. 4LO was flashing, check engine light, and the TRAC light. I messed around with switching from park to neutral and toggling the 2W 4W 4LO dial, turned off the vehicle and started it a few times, because that "fixed" a similar problem last winter.
    It sounds like the 4LO flashing can be an issue. Does anyone have any experience with this? I'm not a mechanic by any stretch of the word and am going to call the dealership tomorrow, but I'd like to have some idea of what I can try on my own first.
    I'd appreciate any advice.
    Thanks.
  2. Feb 28, 2021 at 4:41 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Prior to hitting the dealer, stop at the local auto parts store to see if they have the ability to get the codes that triggered the Check Engine Light.
    snivilous likes this.
  3. Feb 28, 2021 at 4:48 PM
    VTClass4Road
    none
    I wish I had a code reader at home! I'd check it out to see if it might be a bad idea to drive it. The truck is in great shape.
  4. Feb 28, 2021 at 4:58 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Very generally speaking, yellow dash lights aren't as worrisome as red dash lights.
    Black Wolf and snivilous like this.
  5. Feb 28, 2021 at 5:11 PM
    JeffMac
    JeffMac 2 Words, 1 Finger
    Jeff
    South Florida
    2015 Black Tundra OVTUNE
    Suspension: Bilstein 6150 Front Max Setting CB Shim 2x Driver 1x Passenger Bilstein 5160 Rear CB +3 Shackles Firestone Airbags w/ Daystar Craddles Engine: OVTUNE - 87 w/ Torque Modifier SABM w/ K&N Filter TB Coolant Bypass Fumoto Drain Plug Wheels/Tires: ProComp Bandidos 0mm Offset Nitto Exo Grappler AWT 285/70/18 Exterior: TRD Pro Grille Spyder Headlights/Taillights Ecoological Bumpershellz LED everything Tinted windows Bakflip MX4 Tonneau Cover K-Source Tow Mirrors Interior: Pioneer AVH-W4500NEX Radio 2x 10” Pioneer Subwoofers 1200W Pioneer Mono Amp 2000W Pioneer 4 Channel Amp
    It’s probably one of speed sensors. Either the cable ripped or water in one of them. My passenger one broke last year. Quick and easy fix.
    edit: I can’t remember if both lights were flashing or only one but hope this helps.
  6. Feb 28, 2021 at 7:13 PM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    TTund16 likes this.
  7. Feb 28, 2021 at 8:26 PM
    Paul_Tundra
    Paul_Tundra New Member
    I had the same thing happen last week to my 2007 5.7L tundra SR5. Codes were P0018 & P0021. Dealer cleaned cam filters, last 300 miles and codes returned. Second dealer (was traveling) said it was a ocv valve sticking open. Had it replaced and went 1200 miles with no problem
  8. Mar 1, 2021 at 12:56 AM
    ryanw4x4
    ryanw4x4 New Member
    South West Washigton State.
    2011 SR5 Trd OFF-ROAD
    Maybe a rat chewed some wires, that's what happened to me.
  9. Mar 2, 2021 at 5:06 PM
    XSPman
    XSPman New Member
    Manny
    ON, Canada
    2007 XSP DC 4WD
    front levelling, 34" tires, billet grill, tonneau, Nova
    I doubt you will hurt anything by driving it if it runs fine. I had similar lights come on but mine also went into limp mode, which for me it ran fine but if i had a trailer behind me, I would be lacking power to pass people. Anyway, I drove it for several days around town fearing what this fix was going to cost me at the dealership. Then one day it wouldn't start, so I threw in another battery and to my surprise, the lights were gone and my limp mode was gone. It's been good ever since. What I am saying is, an easy thing to try first, is disconnect the battery, leave it for half an hour to clear codes, hook it back up and see if the codes come back.
    Edit: in retrospect, it could have been that the voltage in the battery was low, causing activation of the codes.
  10. Mar 2, 2021 at 10:38 PM
    nwalnoha
    nwalnoha New Member
    Pennsylvania
    2013 CrewMax SR5
    • 3/1.5 lift : 3” Toytec/Eibach coil overs, Billstein 5160 rear shocks, Toytec 1.5” rear add-a-leafs, Wheelers bump stops, driveshaft carrier bearing drop, front diff drop. • 35” Atturo Trail Blade XT tires w/17”Method 305 NV Wheels • Alpha Rex Pro Series Projector Headlights, EAG Grille w/ Amber LED drls, LED taillight & turning signal conversions. • N-Fab MRDS front bumper w/ 40” curved Rough Country LED lightbar. • U-Pole Raptor Bedliner
    It sounds like an ABS issue to me. Could be from either a sensor, one of the harnesses, or a combination. Crawl under there and inspect the sensors for any breaks and feel along the harnesses for any damaged or pinched wires. If you can’t find anything obvious, run over to an auto parts store so they can scan your codes.
    Also, just speaking from experience.. if it ends up being a sensor, I’d check out rock auto or similar places first rather than going to the dealership or the parts store. I think AutoZone sells them for like $200+/- each!
