Trail Edition Hangout/Confirmed Fit Tonneau Covers
Discussion in 'Tonneau Covers, Caps and Shells' started by LarryDangerfield, Feb 11, 2021.
  1. Feb 13, 2021 at 3:59 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I love AG but not enough to shell out an extra $30k for a 2020 Pro or an extra $10k for a 2021 Trail.
  2. Feb 13, 2021 at 4:55 PM
    AtomicToyo
    AtomicToyo New Member
    Ontario, Canada
    I hear ya. As much as I’d like a pro the price premium seems hardly worth it. Trail edition vs trd off road was a tough call, but I’d rather dump some options just to get the AG colour since I plan to mod anyway.
  3. Feb 13, 2021 at 4:56 PM
    LarryDangerfield
    LarryDangerfield [OP] Yo! Lemme get a honk off of that bobo Staff Member
    Tyler
    Northern Wisconsin
    You just wait
    You'll have to change your profile pic :D
    AtomicToyo[QUOTED] likes this.
  4. Feb 13, 2021 at 4:57 PM
    AtomicToyo
    Ontario, Canada
    Thanks! Trail edition here comes with no box anything, just bare :(
  5. Feb 20, 2021 at 11:03 AM
    indydieselnut
    indydieselnut New Member
    2021 CM 4x4 Trail Edition in super white
    Just things to protect it...
    Beautiful truck! Can you tell me more about the Faux Pro Grill - parts and install? I'd like to eventually go that direction. Thanks!
    CorsoTundra[QUOTED] likes this.
  6. Feb 20, 2021 at 11:04 AM
    indydieselnut
    Just took delivery of mine yesterday! Your pictures are inspiring me!
  7. Feb 20, 2021 at 12:11 PM
    CorsoTundra
    CorsoTundra This is the way
    North GA
    2021 Cement Trail Edition
    Toytec Aluma 3/1.5, Pro headlights, OEM LED fog lights, AJT chrome delete, interior/exterior LEDs, front TRD sway, 18x9 Method Roosts, 285/75/18 Toyo A/T 3, RCI engine skid,
    Thanks.
    I got the grille from mcautoparts.com
    Came with the sensor garnish. Biggest pain was unclipping the old grille off the surround. But everything works fine after a few thousand miles.
    indydieselnut[QUOTED] likes this.
  8. Feb 20, 2021 at 12:22 PM
    indydieselnut
    Awesome; thanks!
  9. Feb 20, 2021 at 12:33 PM
    CorsoTundra
    North GA
    Welcome
  10. Feb 28, 2021 at 6:51 AM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
  11. Feb 28, 2021 at 7:18 AM
    CorsoTundra
    North GA
    Doing well Tyler thanks. Hope you are well also. Weather in north Georgia will be in the hi 60s low 70s today so may wash it and do the rear window switch relocation. Still waiting on my C4 Overland front bumper to be finished at the powder coater's shop. He's been so backed up. Also waiting for Method Roosts to be back in stock at the end of November.
  12. Feb 28, 2021 at 7:28 AM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    '60s and '70s sounds fantastic right now. Your truck already looks great, that bumper will be icing on the cake! Also the switch relocation seems like a pretty good idea. I can't believe Toyota put it where they did.
  13. Feb 28, 2021 at 8:40 AM
    jonclark96
    jonclark96 Not so new member
    Jon
    Maryland
    2021 Army Green SR5
    All is well. Finally got to install my DD SS3 fogs yesterday.
  14. Feb 28, 2021 at 9:37 AM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    Worthwhile upgrade?
  15. Feb 28, 2021 at 9:45 AM
    jonclark96
    Jon
    Maryland
    2021 Army Green SR5
    Just got them installed yesterday and haven’t done any night driving yet, but just turning them on after dark last night, they are far brighter than the stock halogen low beams.
  16. Feb 28, 2021 at 9:47 AM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    Awesome, I look forward to hearing how they perform for you after some night driving.
    indydieselnut likes this.
  17. Feb 28, 2021 at 2:31 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    Welcome to the thread!
  18. Feb 28, 2021 at 3:28 PM
    2mchfun
    All is well, hope all is well with all others! Finally finished up my seat covers. Very happy with the quality, color and fit. Also finally received the right dashmat from coverking. Like that too. Hitched up my travel trailer this morning and the Sumo springs are wonderful, very minimal squat with about 1500 lbs on the ball. Dropped about 1-1 1/2 inches. Barely noticable in my opinion and when I actually tow the weight on ball will be closer to 1k due to different load set up so the sag will be very minimal. No major mods going to happen unless I find a money tree. It is too much of a trap where 1 leads to 5 others and it becomes endless. Plus I need to keep small diameter tires for best results from the powertrain while towing close to 8500 lbs. It is a pretty good truck stock, thinking about the cam tower leak issue a little bit. Might consider adding a sealant bead to the existing excess sealant that is oozing while the surfaces are still oil free just to see if maybe it will prevent a leak from ever forming. Just a thought, haven't really looked at it too much yet to determine access points for such an endeavor. Still want to throw some tools in waterproof containers and store them inside the spare tire well too. Out of sight out of mind thing! Plus a little added traction, not much, but anything helps especially on wet roads. Also got to get around to the trans oil cooler sitting in my garage. When I do those things, my method is to always fill the components with water then pour it out and push it out with compressed air into a container so I can get a measurement of total oil volume. Next, blow dry completely prior to install. Next, install and fill oil by adding volume equal to water volume. Lastly, check fill level, should be close to perfect. Still debating factory steel and rubber hose combo lines or just straight rubber hoses to minimize number of potential leak points. Really pissed off that Toyota purposely cheated all Tundra buyers to save $$$. It has been proven that they would spend less replacing a few transmissions vs. adding a factory oil cooler to every truck because so many are basically grocery getters. Plus they can hook up tech stream and say well your trans hot light was on and you still drove it hot, so no warranty coverage! I have so many technical names for those corporate "Richards"! Really makes me question so much about the rest of their product line and the company. Rock on ladies and gentlemen! Life is short!!
    LarryDangerfield[OP] likes this.
  19. Feb 28, 2021 at 3:39 PM
    CorsoTundra
    North GA
    Which seat covers did you go with? I'm thinking of possibly doing the clazzios.
  20. Feb 28, 2021 at 3:59 PM
    #50
    2mchfun
    EKR custom fit seat covers in grey and black from Amazon. Really thick and durable material fit like factory. Had doubts about headrest covers, they are really difficult to get on. I had to bring them in on the living room floor and compress the headrest with quite a bit of pressure to squeeze them into the openings. However, they fit well and very soon i will be ordering another set for my 4Runner. Wish the color option was a little different for the 4Runner, they need a slightly darker beige available, but I am very happy that the 3rd row is included! Good luck with your choice!
  21. Feb 28, 2021 at 4:32 PM
    #51
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    If you don't mind I would love to see some pictures of the seat covers
  22. Feb 28, 2021 at 4:50 PM
    #52
    2mchfun
  23. Feb 28, 2021 at 4:54 PM
    #53
    2mchfun
    A console cover is also included, it wasn't on yet in these photos, it does fit well and has cut out for the tray
  24. Feb 28, 2021 at 7:20 PM
    #54
    heidson
    heidson New Member
    2017 White Tundra Limited 4x4
    Bilstein 5100's all around
    Anybody know what the color is of the Trail wheels? I’m really thinking to have some stock TRD wheels powder coated this instead of black.
  25. Feb 28, 2021 at 7:23 PM
    #55
    2mchfun
    Like Metallic Charcoal Grey
  26. Feb 28, 2021 at 7:24 PM
    #56
    heidson
    heidson New Member
    Would you say it’s a matte or gloss finish? Looks more matte from what I can tell
  27. Feb 28, 2021 at 7:24 PM
    #57
    2mchfun
    Gloss
  28. Feb 28, 2021 at 7:25 PM
    #58
    CorsoTundra
    North GA
    Toyota's description is dark gray TRD off road wheels.
  29. Mar 1, 2021 at 6:46 AM
    #59
    indydieselnut
    92198064-F2E5-47FC-BB0A-315E73FBF0B9.jpg Just gave him his first bath yesterday - first day that was warm enough here in central Indiana. Put my Agricover tonneau on and the new-style Weathertech mats. Krown rust protection on Friday and Llumar Platinum paint protection film on front and hood next Monday. Install Predator steps after that and wait on my Covercraft seat savers.
    Then I guess I’ll just drive it...
  30. Mar 1, 2021 at 7:03 AM
    #60
    FUTRBLD
    FUTRBLD New Member
    South Florida
    2020 MGM Tundra Limited
    Does anyone know the part numbers for the Trail wheels & caps? I tried searching a few places but no luck.
