Grill light help (Advice needed) 2017 Platinum
Discussion in 'Lighting' started by throughitalldude, Feb 27, 2021.
  1. Feb 27, 2021 at 5:28 PM
    throughitalldude
    throughitalldude [OP] New Member
    Jeff
    Southern California
    2017 Platinum
    3/1 Lift |TSS 20" Wheels | 35 Cooper AT3 XLT | Flowmaster 40 Series Exhaust
    Lighting gurus need your help with this. I scored a set of headlights for my truck as mine were hazing due to weather and sun damage. I had the headlights with the Drl led strip in the light and now have ones without. I wanted to somehow use the unused Led harness that connected to the headlights to run some grill amber lights. I am just unsure which wire on the harness runs power when the truck is on. That wire I will connect to the black wire on my amber light. Anyone have any ideas the colors on the harness are Red black and coral.
    UPDATE figured it out
    Inquiringone likes this.
  2. Feb 27, 2021 at 6:34 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Pull out a volt meter and start checking for 12v when on.
    BlueCrushSC16 likes this.
  3. Mar 1, 2021 at 9:07 PM
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    So I got everything squared away and figured out. Have everything running on the stock DRL harness. I want the lights to be amber so I will eventually either paint them with stain glass paint or a amber film of some sort. I made it pretty hidden when the lights are off it’s hard to see them tucked back in the grill.
  4. Mar 2, 2021 at 1:55 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Looks killer.. Well done
    Tundra14Platinum likes this.
  5. Mar 2, 2021 at 8:05 AM
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    Thank you! :thumbsup:
    toyofan87[QUOTED] likes this.
  6. Mar 6, 2021 at 2:29 PM
    18DCTRD
    18DCTRD New Member
    Dave
    Dracut, MA
    ‘18 DC TRD Off Road
    Nice and clean, I’m a fan!
  7. Mar 8, 2021 at 5:51 PM
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    So I hate the bright blueish white led look got some amber tape and turned them amber.
  8. Mar 19, 2021 at 10:57 PM
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    I’ve lost control now.
  9. Mar 19, 2021 at 11:01 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Very unique look. :thumbsup: Great job.
  10. Mar 19, 2021 at 11:26 PM
    AZ Red Nek
    AZ Red Nek Native of the Valley, Bowl, Basin, ETC...
    Chuck
    2016 White SR5 Crew 4x4
    Hidden 1200# Waren winch, Baja Desgins lights, Switch Pro switch and controller, S&B air box and in bed tool box.
    Looks great!
  11. Mar 20, 2021 at 6:47 PM
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    Thanks guys I like it for now may change it after I get sick of it lol
  12. May 14, 2021 at 12:38 PM
    scout495
    scout495 New Member
    What lights did you use for the grill ambers? Thanks!
  13. May 17, 2021 at 10:49 AM
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    They are called LED HiLITZ
    scout495[QUOTED] likes this.
  14. May 18, 2021 at 5:39 AM
    scout495
    scout495 New Member
    Can you provide a pic of the mounting and wiring with hood open if it isn't asking too much. I like this look better than the Yotaleds option. Thanks!
  15. May 18, 2021 at 8:47 AM
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    I actually took them off and went a different direction but let me know if I can hunt something down for you from my previous photos.
  16. May 18, 2021 at 9:07 AM
    scout495
    scout495 New Member
    I really appreciate it. My local Walmarts have them in stock for $12.88 but only in white. Did you put a film on them to make them amber and if so what did you use? Also, it is hard to tell from the pics if you doubled them up one on top of the other or that is reflection? Lastly, before I go any further down this rabbit hole, did you take them down because they malfunctioned, didn't like the look, too bright etc.? Thanks alot!
  17. May 18, 2021 at 4:29 PM
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    I did put a film on the just some clear orange tint tape did the trick. I wired them into RDL light harness and I took them off cause I went a different direction they work great and I may actually put them back on. I only did one i did not stack them.
  18. May 18, 2021 at 4:34 PM
    scout495
    scout495 New Member
    Last question:
    - your lights look like stock amber bulbs, really nice job. Do you remember the product you used to cover them with tape?Thanks again!
