Crew Max ESP under seat storage install
Discussion in 'ESP Truck Accessories' started by Phrog Driver, Feb 27, 2021.
  1. Feb 27, 2021 at 12:18 PM
    Phrog Driver
    Phrog Driver [OP] New Member
    2021 Silver Sky Crew Max TRD Off Road
    My son dropped by today and we installed the ESP under seat storage box. It went completely according to furnished instructions and looks beautiful. I was a little worried about the smart key wiring in the center section but it was no issue. My linoleum knife is about 100 years old, so we ended up using a handled hack saw blade to go through the insulation. Worked like a champ. Thanks ESP for a great product. ESP box install 1.jpg ESP box install 2.jpg ESP box install 3.jpg ESP box install 4.jpg ESP box install final.jpg
  2. Feb 27, 2021 at 12:19 PM
    havasubud
    havasubud Owner ESP Truck Accessories Vendor
    Earl
    Corona, California
    2022 Tundra CrewMax Limited TRD OR 4x4
    Factory Tube Steps, TraiFX tri fold tonneau cover
    Looks great. Glad you like it
    Phrog Driver[OP] likes this.
  3. Feb 27, 2021 at 12:21 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Strong fan of the setup, how deep (inches) is one of the pockets to the seat? Should've been just under $200, right.
  4. Feb 27, 2021 at 12:30 PM
    Phrog Driver
    It looks like 3+ inches, OH. Yes, I had a promocode and it was right about that price.
  5. Feb 27, 2021 at 12:39 PM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    -IO! couldn't resist. Looks so much deeper looking at your photos, I need this type of storage. Never understood why it wasn't standard, I actually told my salesman about it. Surprised he didn't know about it.
  6. Feb 27, 2021 at 1:54 PM
    havasubud
    Earl
    Corona, California
    The two outside bins are 4 1/2", and the center is 4"
  7. May 11, 2021 at 6:56 AM
    JMS0068
    JMS0068 New Member
    2015 Tundra TSS Off-Road
    Does this mod increase the noise level in the cabin?
  8. May 11, 2021 at 9:18 AM
    havasubud
    Earl
    Corona, California
    I have had one in my truck since I designed it in 2014. Removing the foam does not increase noise levels as the foam is just a filler to hold the carpet up, not an insulator.
  9. May 11, 2021 at 9:23 AM
    JMS0068
    JMS0068 New Member
    Thanks! Much appreciated.
  10. Mar 26, 2023 at 8:35 AM
    SwitchThrottle
    2021 Barcelona CrewMax
    For anyone with keyless that's worried about the center pocket and the wiring, the front cut is about 3" in from the driverside, and about 5" in from the passenger side, and about 2" down from the top.
    The wire routes down the passenger side, so I started on driverside until I connected with the plastic housing. I then cut a 3x6 cube out in the front driverside so I could see where I was cutting.
    Posting here as I couldn't find any overhad pictures with measurements for keyless trucks.
    HoustonCoMo, bulldog93 and ATV25 like this.
  11. Mar 26, 2023 at 4:35 PM
    Florida AF
    Logan
    North Florida
    Well done!
  12. Oct 19, 2024 at 8:24 AM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
