  1. Feb 26, 2021 at 3:50 PM
    shoe07
    shoe07 New Member
    Ohio
    2004 Tundra Double-cab SR5 Tow pkg
    Got the rear diff fluid changed after work. Looked pretty grubby. Glad I decided to do it.
  2. Feb 26, 2021 at 6:29 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    After sitting in the garage for 2 weeks took it up to look for some deer antlers and now my Saturday is going to be spent getting the 100lbs of mud off the old girl.
    Voss, oscardog86, Darkness and 4 others like this.
  3. Feb 26, 2021 at 7:55 PM
    speedtre
    speedtre New Member
    Inland Northwest
    Living up to your name...:thumbsup:
    tye, oscardog86, FirstGenVol and 2 others like this.
  4. Feb 26, 2021 at 8:13 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Footwell LED's came in. Work great.
    Darkness and Filthyphil like this.
  5. Feb 27, 2021 at 10:09 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    I really dig the two tone look. Glad they worked out for you!
  6. Feb 27, 2021 at 10:15 AM
    Hny_Bdgr
    Hny_Bdgr New Member
    black 2000 toyota tundra sr5 v8 4x4
    If it fits it ships
    ordered parts and set up plans to get a prerunner tire gate off a chevy to modify to my tundra
    oscardog86 and speedtre like this.
  7. Feb 27, 2021 at 12:52 PM
    oscardog86
    oscardog86 New Member
    Southern California
    Made a little skid plate for my bumper today to just make things look a little neater. I think it came out pretty good but damn I wish California didnt make us have the front license plate as well. It looks so much worse. Also doesnt help that I got it on there a little crooked, haha. IMG_20210227_121518199.jpg IMG_20210227_121731514.jpg
    Voss, hammeron, Darkness and 8 others like this.
  8. Feb 27, 2021 at 1:29 PM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    Nice work!
  9. Feb 27, 2021 at 3:15 PM
    Slapped in some shiny. The old alt did have some rear bearing noise, and the clutch did have a slight wobble. The clutch was definitely a pain without a holder, but I improvised and got the nuts loose, but the WP shaft thingy was on there pretty good so it took some back and forth action with the painters tool, holding the pryed edge open with another flat blade, then working on the opposite side.
    Volt needle still dances, idle in D is still a lil stumbly. But at least I have some spares for some Mad Mo; Welcome to the thunder canyon, futuristic type stuff.....
    I’ll rebuild the alternator down the road.
    Voss, Filthyphil, Darkness and 7 others like this.
  10. Feb 27, 2021 at 3:40 PM
    Did you do a Denso reman?
  11. Feb 27, 2021 at 3:55 PM
    I did. All from the steeler. I’ve actually been dealing with “the guy” who does the Internet sales and he’s been super helpful! One of my vac hoses was on back order and he had like crib notes under his keyboard, and said it might be in but he’d have to go check a bunch of boxes. I’m like sure dude take your time!(it’s a long drive to this dealer that participates in the online program)
    It wasn’t, but it was nice that he remember and wrote it down and took the time, or acted like he went and looked for it.
    Darkness, speedtre, YardBird and 2 others like this.
  12. Feb 27, 2021 at 4:37 PM
    theblurry1
    theblurry1 ~
    Castle Rock, CO
    2001 Thunder Grey Tundra AC Limited 4x4 V8
    (Camper conversion underway.) Rebuilt engine w/265K miles, A.R.E. camper shell (w/cab pass-through, rooftop fan, and side windows delete), bedlinered steel ladder rack (w/wooden rooftop deck and hammock mount), all LED lights (red dash, 4" side floods, 32" rear bar), Android head unit, 1.5" lift from Bilstein 5100 struts, 32" DuraTrac tires on factory rims, 1.5" wheel spacers, Moog suspension parts, SuperSprings leaf kit, diff drop, Reese trailer brake control, GoRhino Hitch Step, debadged, F-150 rear bumper, Sequoia center console unit upgrade, partial rear bench seat delete, dashcam, aftermarket speakers, 50% sound deadening coverage, custom tools unit.
    Guys, I got the rebuilt engine in and mated to the bell housing. But the crankshaft won't turn. I have to turn it to bolt the torque converter to the drive plate. It turned fine when I had it on the stand to make sure everything was in time but now it's locked. What the heck could be making it bind? I'm so close to having this done.
    Pulled the starter in case that was stuck and it wasn't. Plugs are out. Tried in neutral and park.
  13. Feb 27, 2021 at 4:43 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Squirt some Deep Creep in the Spark Plug Holes? Maybe the pistons rings are bound up from sitting? I don’t remember you pulling them so maybe the Mojo is seized.
  14. Feb 27, 2021 at 5:05 PM
    theblurry1
    theblurry1 ~
    Castle Rock, CO
    Will do, they weren't pulled but I did put assembly lube on them.
  15. Feb 27, 2021 at 5:11 PM
    Azblue
    The Dirty T ( ^_^)_且
    Which of our local dealers does online stuff? Would be good to know if I need some parts, I usually go to Desert cause I live on the east side.
  16. Feb 27, 2021 at 5:16 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    Punch in your zip code here. https://parts.toyota.com/ Precision and Desert are the closest (not that close) participating dealers to me.
  17. Feb 27, 2021 at 5:20 PM
    Azblue
    Nice, didn't know both local dealers participated, might save a few bucks for routine maintenance items.
  18. Feb 27, 2021 at 5:47 PM
    I thought it was only desert toy last time I checked, they are far from me. I’ll check if pre toy participates too
    Azblue[QUOTED] likes this.
  19. Feb 27, 2021 at 6:32 PM
    Cummins3500
    Logan
    Replaced the little bumper bolt cover things. Had one go MIA49837987-BD5E-4304-8748-DA2A39E6E603.jpg
    struck out on google trying to figure out what size sway bar bushings I have. Best I can tell it’s a 27 mm bar
    Filthyphil likes this.
  20. Feb 27, 2021 at 7:37 PM
    peanut
    peanut making uneconomical choices about my truck
    2001 Tundra 4x4 V8 Access cab 222k miles
    On the stand did you rotate it more than 4 times around? Are you turning the crank bolt? Clockwise or counter clockwise? Seems strange its not going around.
    theblurry1[QUOTED] likes this.
  21. Feb 27, 2021 at 9:16 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Looks like they're getting more dealers signed up. There's actually one close enough to me to be bothered with.
    Maybe I'll get that airbag recall done & pickup some spark plugs while I'm there.
  22. Feb 27, 2021 at 9:35 PM
    jImmegart
    Jonah
    California
    2003 Tundra TRD Sport
    I never got mine :/
  23. Feb 28, 2021 at 5:12 AM
    Lil Steve
    Gilbert, AZ
    I have 9 dealerships within 35 miles of me, none of them participate in the online program. The closest one to me is about a 100 miles away so not worth the drive for picking up parts in person. Luckily I haven't needed much directly from Toyota.
  24. Feb 28, 2021 at 5:39 AM
    None of the valley dealerships participate? That sucks!
  25. Feb 28, 2021 at 5:54 AM
    theblurry1
    theblurry1 ~
    Castle Rock, CO
    I turned it twice or thrice on the stand and it stayed in time, I am trying to turn the bolt clockwise. I will try again later today but I am concerned, it feels more like a mechanical siezure than needing a little oil. Might tap the flex plate in the right direction too with a mallet or pop a timing cover (but it's not at TDC so idk how I'd line up anything).
  26. Feb 28, 2021 at 5:56 AM
    speedtre
    speedtre New Member
    Inland Northwest
    Did you go stock Tundra or Sequoia 150 amp?
  27. Feb 28, 2021 at 6:00 AM
    Fred
    Hand Protectors
    @empty_lord
    theblurry1[QUOTED] and Tundra2 like this.
  28. Feb 28, 2021 at 6:11 AM
    Same here. Closest dealer is 85 miles round trip and their prices are still higher than the other online dealers I order from. I'm hoping more dealers will get added to that program as time goes on.
    Lil Steve[QUOTED] and speedtre like this.
  29. Feb 28, 2021 at 6:20 AM
    speedtre
    speedtre New Member
    Inland Northwest
    I have 2 Toyota dealers within 10 miles from me....I just check the nearest online participating dealer , get their price from online and usually one of the non-participating dealers will match it over the phone. Also, FYI, if you are a Costco member, in addition to their auto buying service, has a discount parts/service program where you get 15% off any part/service....if you ever need it. Both my local Toyota dealers participate.
    https://www.costcoauto.com/parts_and_service/default.aspx
  30. Feb 28, 2021 at 6:25 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Are you putting in a 150 amp alternator?
