Loving my 2013 Tundra in Florida
Discussion in 'New Member Introductions' started by stuk, Jan 13, 2021.
  1. Jan 13, 2021 at 1:41 AM
    stuk
    stuk [OP] New Member
    2013 Silver Tundra DBL Cab
    Viper alarm
    In June 2020, I bought a silver 2013 Tundra 2WD Double Cab. It has about 90K miles. We've already taken it camping, mountain biking on the Range and long-distance riding along the Coast. Last week I picked up a ton of firewood for our backyard fire pit and picked up a ping pong table and for free that someone was throwing away in the neighborhood.
    Only issue: in the winter (30's) I've discovered I have to drive it frequently so the battery doesn't run low. Otherwise, I have to charge it up with a battery tender. Does anyone else have the problem in the cold?
    What a blast!
    YardBird and Prostar 190 like this.
  2. Jan 13, 2021 at 1:50 AM
    Toptalktoyota
    Toptalktoyota New Member
    2020 DC SX
    You most likely need a new battery.
  3. Jan 13, 2021 at 2:43 AM
    Welcome from Ohio
  4. Jan 13, 2021 at 4:26 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! I 2nd the opinion that you need a new battery.
  5. Jan 13, 2021 at 4:32 AM
    Welcome from NY.
  6. Jan 13, 2021 at 7:01 AM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    Welcome from Ontario Canada.
  7. Jan 13, 2021 at 8:34 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  8. Jan 13, 2021 at 10:44 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Bilstein 5100 2.3/1.5, TRD sway bars ft/rr, Cooper Tires Discoverer AT3 XLT 295.70.18, Vision Manx 2 18x9 +12, APS side armor steps, TRD-Pro Grill and Bulge, de-chromed, blackout emblems, OEM mirror caps and flares, TRD shift knob, Leather wrapped steering wheel, All weather mats
    Welcome from PEI
  9. Jan 13, 2021 at 11:59 AM
  10. Jan 13, 2021 at 12:04 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  11. Jan 13, 2021 at 2:55 PM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    Welcome from Pennsylvania
  12. Jan 13, 2021 at 3:03 PM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    Welcome from Utah.
  13. Jan 14, 2021 at 8:18 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Welcome from the wet side of WA.
    Yup - get a new battery in there.
  14. Jan 14, 2021 at 8:21 AM
    Team4M
    Team4M New Member
    Anthony
    2016 - Tundra - 1794 - Black
    Bilstein 6112 / 5160 lift
    Welcome from the 813 area code!
  15. Jan 27, 2021 at 1:54 AM
    stuk
    Viper alarm
    So, the dealership installed a new battery in June 2020. It's a CARQUEST Silver, 750 CCA at 32 degrees F with a 2 year warranty.
    A few months ago, the battery started dying but I could recharge it. I thought the cold weather was causing it but it hasn't been that cold in Florida and sometimes I'd leave the radio on or something similar.
    Now, the truck is completely dead and it won't accept a charge. As a last resort, I jump started it and it cranked right up but an hour later it was dead again. Since the battery came with a 2 year warranty, I'm thinking returning to the dealership.
    Does this seem valid or am I screwed since I bought the truck "as is"? Has anyone else had this problem?
  16. Feb 20, 2021 at 7:50 AM
    sportrider
    sportrider New Member
    Stephen
    2017 White Crewmax Limited
    I personally would return to the dealership. Even buying as is, the battery carries its own warranty. Assuming the dealership has a receipt or record of the purchase to return it to the local carquest or advance auto(wherever it was purchased) they should gladly exchange it. I would make sure any aftermarket accessories, lights, stereo, etc are properly installed and have switches.
    Its been a few weeks, what did you end up doing???
  17. Feb 20, 2021 at 8:02 AM
    Tundra14Platinum
    Tundra14Platinum I love reading the CoC in my spare time
    2014 Platinum CM Sky Silver
    TRD PRO Grill/Headlights, Swaybar, Eibach
    2nd
    And welcome...
  18. Feb 21, 2021 at 9:24 PM
    stuk
    Viper alarm
    Yeah, the dealership said they'd cover the battery replacement, if needed. The local shop said I needed a new alternator so I paid for that, and they replaced the battery for free since it was still under warranty. Not sure if the alternator was OEM or not; truck has 90K miles. Anyone else have alternator fail ~90K miles? One website said the year 2013 Tundras had low maintenance issues.
  19. Feb 22, 2021 at 3:43 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    welcome from so cal
  20. Feb 22, 2021 at 4:05 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Welcome from New Hampshire!
