SRS Code Delete
Discussion in '2nd Gen Tundras (2007-2013)' started by kanger328, Feb 21, 2021.
  1. Feb 21, 2021 at 3:44 PM
    kanger328
    kanger328 [OP] New Member
    Anchorage, Alaska
    2012 DC 4x4
    So, I've been struggling with my 2012 Grade trim for awhile. I added leather leather seats from a 2012 Sequoia and the passenger seat wires didn't match up. I finally spliced the right wires, so the power seat works now. But the airbag lights have been on since I initially messed with the wires.
    Do I need to buy a SRS code reader to reset the airbag lights? Or is there a cheaper option? The yellow wiring harness fits just right, which I believe is the airbag wires (is this correct?). And with the power wire now hooked up, I'm guessing the airbags should work now. There are other wires that aren't hooked up...so there may still be an issue, but theoretically the problem should be solved. Appreciate any input.
  2. Feb 21, 2021 at 7:58 PM
    TechWrench
    TechWrench New Member
    Gary
    Hawley, PA
    '08 Tundra White, DC SR5 5.7, TRD Off Road Pkg
    Toyota Bedliner, Under Cover Bed cover, Oem back-up camera system.
    Can't say for sure, but if you had one or more air bag modules disconnected while power was on (battery connected), then it may have caused an SRS fault with the control computer because the disconnected units failed to communicate with the computer. It happened to me with a BMW X5, and I couldn't reset the fault without a special SRS diagnostic tool. A standard OBD II code reader/reset tool will not work. You may need a more advanced SRS tool, a TIS computer, or take it to a dealer for a reset.
    kanger328[OP] likes this.
  3. Feb 21, 2021 at 9:03 PM
    kanger328
    Anchorage, Alaska
    2012 DC 4x4
    Cool, that's what I figured. I did disconnect the airbag wires and run the truck. Thanks dude.
