Does the rubber fit
Discussion in 'Wheels & Tires' started by Crewmax-Lurch, Apr 1, 2017.
  1. Apr 1, 2017 at 7:03 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    I'd be more concerned with the width than with the height. with a stock wheel offset you may get some rubbing on the UCAs.
  2. Apr 1, 2017 at 8:21 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    On a serious note. I am running 305/65/18 on a +12 wheels and 3" lift. Just had to remove flaps and trim front liner.
    Crewmax-Lurch[OP] likes this.
  3. Apr 1, 2017 at 10:48 PM
    Crewmax-Lurch
    Crewmax-Lurch [OP] New Member
    So what I'm guessing from the post is they will fit but possibly some trimming . Thanks :thumbsup:
    Bear and joonbug like this.
