20x12 wheels on a 17 tundra
Discussion in 'Wheels & Tires' started by Dacfleming, Feb 17, 2021.
  1. Feb 17, 2021 at 2:33 PM
    Dacfleming
    Dacfleming [OP] New Member
    I got a 2017 tundra and I'm looking to put 20x12 on the truck. I was told by a tire shop that this won't fit on the truck. I see this is a common set up, although is any major cutting required? This truck is factory ride height. Sorry if this is repeated question
  2. Feb 17, 2021 at 2:39 PM
    GNTundra
    Gino
    2013 White
    Welcome to the forum. I run 20x12 -44 offset with 7" of lift. What kind of offset you looking at? Are you willing to lift your truck?
  3. Feb 17, 2021 at 2:45 PM
    Dacfleming
    I'm not looking to lift, if anything I'd like to lower some, so would a 20x12 -44 fit stock/lowered?
  4. Feb 17, 2021 at 4:16 PM
    Dacfleming
    I was thinking 305/55/20
  5. Feb 17, 2021 at 4:45 PM
    Dacfleming
    What would be an ideal set up then?
  6. Feb 17, 2021 at 5:49 PM
    Blazing Blue
    Blazing Blue New Member
    I don’t think they would fit without a lift.
  7. Feb 17, 2021 at 5:55 PM
    Blazing Blue
    I run 22x12 -51 on 3.5 lift aggressive bmc pinch weld and still rub at full turn.
  8. Feb 17, 2021 at 7:20 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    OP, there is a subforum on here called Wheels. These subforums are used to keep like minded posts together so they are easily found/read/browsed. . Welcome to the forum, remember to search first and good luck shoe shopping.:thumbsup:
    @Squatting Pigeon- should be moved.
  9. Feb 19, 2021 at 1:18 PM
    Fastlane47
    Fastlane47 New Member
    Maryland
    24 TRD Pro
    I'm running a 20x12 wheel with a -44 offset, 305/50/20.......going to a 22x12 this spring with a 305/40/22
