  1. Feb 18, 2021 at 10:07 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Test fit the wheel spacers on one front wheel. Looks like I’ll just need to reform the rear of the inner liner.
    Voss and oscardog86 like this.
  2. Feb 19, 2021 at 3:46 AM
    Professional Hand Model
    Fred
    Hand Protectors
    I bought a 10 Pack of Crush Washers with my Yzzd-3 10 pack. Still using the same washer 2 years later and have 9 I can donate. :rofl:
  3. Feb 19, 2021 at 3:57 AM
    You can usually reuse the crush washers.
    Protip: loosen the fill plug first.
    Smack both fill and drain plugs with a drift or a hammer to help loosen the threads.
  4. Feb 19, 2021 at 10:26 AM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    Installed my retrofits from @SouthPaw. Love the the new lights like turning on the sun at night.
    I went with the morimoto harness and bulbs. This was a fun little project with a great outcome. I believe I still need to dial in the driver's headlight some more but the weather has been a drag.
    Ballasts are mounted with zip ties in the area above the headlight ( see red arrow in pic). The relay is the anodized orange thing in one of the pictures. That spot seemed a happy medium for reaching battery and having everything reach where it needed to.
    Got the tint to make the corners blend in some installed..not sure I like it but until I find smoked or a set to try and open and paint the inside...these will do.
    Polished the hood some too!
    Voss, SouthPaw, hammeron and 7 others like this.
  5. Feb 19, 2021 at 1:09 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Changed out the rear differential fluid in my '06 DC this morning. Picked-up 4 quarts of Señor Lucas 80/90 Gear oil & a 24mm impact socket from my local Mom & Pops parts joint. No problem getting the drain plug and filler plug off (both 24mm) w/ a breaker bar. The crush washers looked really bad super thin, and both had pretty nasty grooves in them. I jacked up the drivers side rear wheel and let it drain, while I took off in my other ride back to the parts store to pick up 2 new washers. Came back and cleaned both drain and filler plugs (minimal metal fuzzies on the magnetized drain plug). Tork'd the plug to 36 ft. lbs. and started filling. I got about 2 1/2 quarts in and put the filler plug back in semi-tight. Then pulled the truck out and drove around the block making multiple u-turns. Found an open lot, and did 3-4 figure 8 turns before returning home. Pulled the filler plug and kept filling till it started to come out the hole, gave it a quick little extra blast and put the filler plug back in. Torked to 36 lbs. and called it good. It took about 3 1/2 quarts . . . I may crack it open in a few days to double check the level . . . or not, seems like I put in the same amount I took out . . . or very close. Easy job, saved a few bucks doing it myself, and used what I feel is a good product in Lucas Oil.
    hammeron, KNABORES, NWPirate and 4 others like this.
  6. Feb 19, 2021 at 4:49 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Mom sent me these pictures today.
    Voss, oscardog86, NUDRAT and 4 others like this.
  7. Feb 19, 2021 at 6:27 PM
    I stopped at the gas station a few minutes ago to fill up and my gas door wouldn't unlock. Screwed with it a bit and gave up.
    Came home and was able to pry it partially open with a screwdriver. Then eventually it unlocked. Very odd. I'll have to mess with it in the daylight.
  8. Feb 19, 2021 at 6:42 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    My lock got seized and I had to break it to get fuel in my truck. Hence the broken fuel door. Which I have since replaced.
  9. Feb 19, 2021 at 7:22 PM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    05 DC SR5 / 06 SEQUOIA LTD
    Excellent advice! When I was in high school I drained TC oil in my 87 hilux before opening fill plug and couldn't get the fill plug out. Was without a truck for a few days working on that bugger! I'll never make that mistake again.
  10. Feb 19, 2021 at 7:32 PM
    Take it to a locksmith; they’ll take it apart and clean it up for $20. The first fix is to get a new key cut (if needed). Generally the rounding of the key edges only makes the condition worse getting it open.
  11. Feb 19, 2021 at 7:34 PM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    Just ordered rear Bilstein 5100s, wheelers AAL kit and stainless brake lines. Heard Bilsteins are hard to come by right now so hoping they aren't back ordered too long. Although it's winter still so I got a month before I'll realistically get to it
    At same time I'll be inspecting/adjusting my rear brakes. Front suspension and brakes have been done more recently.
  12. Feb 19, 2021 at 7:41 PM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    Is it an actual lock with a key, or are you talking the gas door release? If it's a keyed lock spray some graphite lube made for locks in the key hole. That usually works wonders for lock issues.
    Not uncommon for locks to freeze up in winter. Which it seems a lot of the country is experiencing for the first time. Haha.
    oscardog86 likes this.
  13. Feb 19, 2021 at 8:00 PM
    It's an actual lock with the key that starts the truck. I think they gas doors stopped coming with a lock in 03 or around there.
    I'll look up this graphite lube you speak of.
  14. Feb 19, 2021 at 8:06 PM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    Try it. I have a bottle from forever ago, but I'm sure they still make it. Might look for lock deicer, has lube in it as well. Usually has a really small spray straw or nozzle so you can get it inside the cylinder.
  15. Feb 19, 2021 at 8:16 PM
    I’ve found the graphite in the lock to just be a temporary solution. If your lock is gunked up like mine you may need to have a locksmith take a look at it.
  16. Feb 19, 2021 at 8:46 PM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    If it's gunked up then I'd say you need to spray brake clean in first, then extra graphite lube second. Haha.
    Yeah could be messed up beyond lube fix, but any mechanical lock that has ever given me problems is usually just needing cleaned and lubed. Or the key is worn out and needs replaced.
  17. Feb 19, 2021 at 10:38 PM
    Thrussn
    Thrussn Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    My neighbor spent his life as a locksmith and he even helped me rebuild my tailgate lock. He told me that the graphite lube is good, but it's messy and doesn't last very long. Ignoring the worn key, it's absolutely worth investing in a can of triflow spray lube and spraying a little in the locks twice a year. He absolutely saved me quite a few locksmith expenses.
    If your lock is super gunked up, that triflow really helps. I'd recommend spraying some inside the keyway and then working the lock mechanism multiple times while wiping the key off each cycle/key insertion.
    It's super dusty, sandy, and windy where I am, so I definitely have had the opportunity to see how effective that stuff is.
  18. Feb 19, 2021 at 11:14 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    alee891 likes this.
  19. Feb 20, 2021 at 5:25 AM
    Fred
    Hand Protectors
    Soy Lube!
    Thrussn[QUOTED] likes this.
  20. Feb 20, 2021 at 5:47 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    What do you have there now?
  21. Feb 20, 2021 at 9:03 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Spent quite a bit of time yesterday afternoon and this morning playing around with the adjustment on the rod and I think I've got it dialed in now. Drove even farther today and the brakes are not dragging anymore. I put the truck in neutral at speed and it rolled down hills fine. Going to do some interior cleaning now and maybe go for a trail run this afternoon.
    Voss, Glock 40, NUDRAT and 4 others like this.
  22. Feb 20, 2021 at 1:35 PM
    Installed the Slyfox(from t4r.org and others I’m sure) AIP bypass today. It wasn’t to bad of a install, only took me a lil bit to find the ST relay that I needed to pull(pics didn’t match instructions perfectly)
    Started her up and I didn’t hear any pumps screaming “HOOVER” so I think I should be good!
    Voss, 912, NUDRAT and 3 others like this.
  23. Feb 20, 2021 at 1:39 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Those wire strippers are great! I've got a pair of old Klein ones from my grandfather that I use pretty frequently.
    NUDRAT likes this.
  24. Feb 20, 2021 at 1:41 PM
    Fred
    Hand Protectors
    Nice. I see that Sweet Hitachi MAF Sensor everyone was leery about ordering online. Hows its doing?
    fighthedude likes this.
  25. Feb 20, 2021 at 1:46 PM
    They are awesome! These are my personal pair; I need to get some for work for some of the small spaces we have to strip in.
    I used it heavily when I was turning “project boxes” (Hammond boxes) into high powered battery packs for Ecigs
    It had a variable voltage/variable wattage DC/DC converter with potentiometer switch to adjust volts. 120wmax output, I could do clouds for a day haha
  26. Feb 20, 2021 at 1:46 PM
    Haha it’s working great!
    It’s hilarious how they dremeled right where “Toyota” used to be......
  27. Feb 20, 2021 at 1:59 PM
    Fred
    Hand Protectors
    Proves its authentic!:rofl:
    Yeah. Saves about $100, too.
    Voss and FrenchToasty[QUOTED] like this.
  28. Feb 20, 2021 at 4:01 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Link? I havnt seen that mod yet
  29. Feb 20, 2021 at 4:22 PM
    Festerw
    Festerw New Member
    04 Tundra DC
  30. Feb 20, 2021 at 4:25 PM
    empty_lord
    05 rollover special
