Replaced front shock/springs, now 4hi4lo traction control and ABS ore on
Discussion in '2.5 Gen Tundras (2014-2021)' started by William C, Feb 15, 2021.
  1. Feb 15, 2021 at 10:59 AM
    William C
    William C [OP] New Member
    2015 Tundra
    I replaced my front strut assembly on both driver and passenger sides. Turn the vehicle on and the 4hi 4lo lights flash while traction control and ABS are steady. Didn’t disconnect them or anything. Any idea on why they are on/flashing?
  2. Feb 15, 2021 at 11:06 AM
    wv00097
    wv00097 New Member
    Wes
    AZ > GA
    2011 SR5 TRD OR
    BDS 7 w/ Fox 2.5 OME Dakar leaf pack CB +2 shackles 18x9 Method 308 +18mm 37x12.5 Toyo AT3 TRD intake/exhaust Infinity Kappa w/ Pioneer HU
    Check if you have a damaged ABS sensor wire. Sounds like it
    14burrito and Wynnded like this.
  3. Feb 15, 2021 at 11:09 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I second this FWIW, those wires are very delicate.
    wv00097[QUOTED] likes this.
  4. Feb 15, 2021 at 11:11 AM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Yup! wheel speed sensor and them little suckers ain’t cheap
  5. Feb 15, 2021 at 11:21 AM
    crabbymcnab
    crabbymcnab New Member
    2016 Inferno SR5
    Pull out your rear abs sensor on each side and check for build up or oil residue. If so, axle seal is probably bad and the diff fluid is leaking out. I just went through this last week.
    Dealer replaced the seal and bearing under the powertrain warranty. The sensor cleaned up
  6. Feb 15, 2021 at 11:45 AM
    William C
    2015 Tundra
    Can I drive it with those lights flashing and the ABS/Traction lights on steady?
  7. Feb 15, 2021 at 11:48 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Sure, but your ABS and traction control likely won't function.
  8. Feb 18, 2021 at 5:57 AM
    XSPman
    XSPman New Member
    Manny
    ON, Canada
    2007 XSP DC 4WD
    front levelling, 34" tires, billet grill, tonneau, Nova
    Are you in limp mode also, by that I mean limited power when accelerating? I had a similar situation a few months back, parked the truck for a couple of weeks while I was going to think about how to fix this. Went to start the truck one day, battery was dead, so I took it out of the truck to recharge it, stuck it back in, limp mode was gone and all unwanted lights disappeared. No problems since! So you could try unhooking battery, make sure it's charged fully, and hook back up. At least it resets the electronics.
  9. Feb 18, 2021 at 6:29 AM
    William C
    2015 Tundra
    I was not in limp mode. It ran and drove fine, just having those lights blinking was driving me crazy. I got it fixed now. It was the wheel speed sensor like what was suggested above. Thanks for the advice though, I truly appreciate it
    XSPman, Black Wolf and Wynnded like this.
