Woodworkers' BS Thread
Discussion in 'Sports, Hobbies & Interests' started by Fishman57, Dec 19, 2018.
  1. Feb 18, 2020 at 9:06 PM
    #151
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Have you checked to see if your blade is square with your fence?
  2. Feb 19, 2020 at 2:47 AM
    #152
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Might be an arbor issue, also double check that your blade is staying tight and is not warped. Extend the blade all the way up, turn it on, and sight down the blade front to back. You can usually see it wander. I also have my table saw rigged with 3 featherboards - one to keep the material pushed against the fence and 2 to keep it pushed to the table when the material enters and exits the blade. But I agree, if you've never had an issue before, your arbor may be the culprit.
  3. Feb 19, 2020 at 4:04 AM
    #153
    Njmike13
    Njmike13 New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    Tried again last night with a feather board. Same thing, if I stop feeding the cut is visibly wider. I ran the saw with the blade at full hight and don't see any wobble. Removed the blade and reinstalled. Will try again later today.
  4. Feb 19, 2020 at 6:29 AM
    #154
    saybng
    Gary
    Ventura CA
    What is the model # of your saw? Theres a way to check just this to make sure it's not your fence , I'll take a pic of my saw when I get to my shop on how to do this, a little tricky but youll get the idea. I have 3 table saws, my delta unisaw has a slight wobble, but the the cut is always true. My little dewalt job site saw had an issue like your describing and it was the fence..hopefully it is just the fence because its an easy fix.
  5. Feb 19, 2020 at 10:14 AM
    #155
    Njmike13
    Njmike13 New Member
    2021 PRO Lunar Rock
    I will check the saw when I get home tonight. Thanks
  6. Feb 19, 2020 at 2:38 PM
    #156
    Kerch71
    Mechanicsville VA
    That makes me wonder if your fence is moving. Keep us posted!
  7. Feb 20, 2020 at 11:09 AM
    #157
    Njmike13
    Njmike13 New Member
    2021 PRO Lunar Rock
    The model is Jet JBTS-3
    Thanks
  8. Feb 20, 2020 at 12:06 PM
    #158
    saybng
    Gary
    Ventura CA
    I'll message you.
  9. Feb 20, 2020 at 1:32 PM
    #159
    Fishman57
    Fishman57 [OP] New Member
    Wayne
    Bucks County, PA
    I saw that deal on Amazon. Looks pretty good. Just have to decide if I want to spend the $$ right now.
  10. Feb 20, 2020 at 2:03 PM
    #160
    Viking
    Viking New Member
    Jerry
    2007 metalic brown double cab Tundra
    The grain lines in the wood look like the Myrtle wood we have around here, I've seen Cottonwood have those lines as well, but cottonwood is often very hard to work with and often jambs up a chainsaw with fibers while cutting them down. I've seen beautiful furniture built with Myrtle wood.
    Rex Kramer[QUOTED] likes this.
  11. May 30, 2020 at 6:50 PM
    #161
    stangless40
    stangless40 New Member
    Alberta Canada
    17 Platinum
    lots
    After 40 years of working on mustangs, the past 5 years been building furniture and decor for customers. You can click on photos to browse.
    Spaceiscool, Kerch71 and RangerBP like this.
  12. May 30, 2020 at 7:25 PM
    #162
    Kerch71
    Mechanicsville VA
    Exceptional quality! Very impressed! :thumbsup:
  13. Nov 7, 2020 at 8:53 AM
    #163
    Spaceiscool
    Spaceiscool Something something.. danger zone?
    JL
    Ontario
    2008 White Tundra CM TRD
    Spray painted rims
    I haven't been posting much lately as I've been busy with my woodworking and carpentry business i started. Coveislandcustoms. Organizing and setting up my shop the past month and a half with the odd carpentry job on the side. I really love dining tables of all types so that's what I'm focusing on when I can. This table i built out of 130 yr old framing hemlock i salvaged in my house when i took out a few walls. The tundra has been a huge help, I've had it loaded up to the brim nearly everyday. If any of you guys frequently post your projects on Facebook or Instagram shoot me a message at my coveislandcustoms pages. I really enjoy seeing others projects or shop photos its all inspiring and a great community. And for those wondering i run all my power tools off originally 4 solar panels without a hitch. Now I have 10 with a big battery setup so will be insulating and running heaters off the solar as well. :yes:
  14. Nov 7, 2020 at 1:55 PM
    #164
    Kerch71
    Mechanicsville VA
    Great shop setup! That table is awesome! Nice work! :thumbsup:
    Spaceiscool[QUOTED] likes this.
  15. Nov 8, 2020 at 11:29 AM
    #165
    Navi
    Navi New Member
    2019 CrewMax Limited
    Solar power.. very nice. Have not seen a shop that runs 100% off of solar. Congrats on the new biz, the projects look great.. and nice dog too
  16. Nov 8, 2020 at 7:36 PM
    #166
    Spaceiscool
    JL
    Ontario
    Spray painted rims
    Thanks, the pup is my dads, actually the shop is at my parents but they don't use the space for the most part. I'm grateful I can have access to it as our home doesn't have a shop or garage I can set up in. I think they also like the company haha. And I was surprised by the solar too. I've run my dewalt bench planer for a couple hours straight without a hiccup and that's drawing more heavily than my mitersaw or table saw. The shop has hydro but might as well use the free stuff when you can.
    Navi[QUOTED] likes this.
  17. Nov 11, 2020 at 6:07 PM
    #167
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Where do you guys get wood from? I've bought wood from Home Dept many times and I'm tired of digging through piles for straight boards that aren't hacked up. 2x4s or 1x6s, or really any size is always like I'm digging through crap.
    Is wood at lumber suppliers better in that way?
  18. Nov 11, 2020 at 6:44 PM
    #168
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    I usually order my wood from ebay. You can find pretty good prices on walnut, cherry, maple, spalted maple etc etc I usually buy about 40-40 bf at a time just keep an eye out for independent hardwood suppliers sometimes they will give great deals on off cuts and peices with “character”
    Darkness likes this.
  19. Nov 11, 2020 at 6:49 PM
    #169
    cctxquicksand
    It’s hard to find lumber around me, bigger city’s will have hard wood suppliers small cities usually only have Lowe’s or Home Depot. Depending on what part of the country your in they may stock local species, for example in my area besides the normal southern yellow pine and cedar they have they usually have a decent selection of red oak edge and planed ready to go. If you have a wood working store by you I’d try there as well, something like woodcraft
  20. Nov 11, 2020 at 7:17 PM
    #170
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    For general rough frame materials my experience is they all have roughly the same materials. Building material lumber hasn’t been the same quality “it used to be” for the better part of my life time... most of it is hybridized quick-growth tree farm raised pole trees that are barely big enough in diameter to get a 2x12 out of the dead center. The spring wood is most of the tree, and it’s unstable as soon as it starts to dry. On top of that, they don’t bother to kiln dry most of it (which can have its own issues, but at least the wood is drier/more stable) so the lumber shows up at the yard (HD or otherwise) damn near still dripping water. Bring it home and as soon as it’s in the shop it starts to buckle and twist on you.
    When it comes to non-framing lumber - your hardwoods, true pine (at least in the PNW, where most framing lumber is fir), and finish plywoods, you need to go to a true lumber or specialty wood store. Home Depot will carry S4S pine, poplar, red oak, and maybe maple in 3/4 thickness at ridiculous prices... if you’ve got a table saw you don’t need S4S (though I would recommend a planer to be able to thin stock to your exact needs). A specialty or lumber supplier will have S2S and S3S in about any species you can imagine and in thicknesses from 4/4 to 8/4 or more for a fraction of the price and you can find just what you need.
    I will hit Home Depot if I need some electrical parts, basic plumbing supplies, a sheet of sheet rock, and a couple 2x4’s and the Mrs. wants to look for a couple pavers for the yard or a flower pot all in the same trip. Otherwise, I’m headed to the local specialty suppliers.
    </rant>
    :amen:
    I should also add that checking out local ads (Craigslist or local papers in small towns) you can often find small mobile sawmill operations that can often give you a lead on small quantities of really odd stuff. Where I grew up, there were several small local mills that did specialty cutting that we got a lot of stuff from for projects around the house from big timber framing beams to a whole load of blued white pine that I think my dad still has some boards left over after 40 years.
  21. Nov 12, 2020 at 11:42 AM
    #171
    Navi
    Navi New Member
    Yes, wood at lumber suppliers is a lot better than what you find at the box stores. Craigslist can be more productive than you might think, small family sawmills still exist in most places but that might depend on where you live. If you can a friend (or two) want to get a log sawn-up, a high value tree like walnut, you might also search for tree companies that have portable bandsaw mill. You're going to end up with a lot of wood and you need a good dry place to store it but if you get a high value tree, that's something i've done before
  22. Jan 2, 2021 at 10:27 AM
    #172
    IBeam
    IBeam New Member
    Southeast Texas
    2021 SR5 CM 4x4 Trail Edition, bed-mounted M2
    Amazing. You could make duplicates and sell on Etsy or wherever.
  23. Feb 17, 2021 at 12:19 PM
    #173
    Kung
    KG, VA
    Here's my (meager) contributions.
    Bookshelves: These have special meaning, as they were the last thing my Dad and I built together before he passed. He did about 1/2 the work; I did the other half, and all the finish work. I forget the exact measurements - they're around 3' wide or so by 7' tall (they were made to fit in our master bedroom suite).
    Pantry: Much more boring and emphasis on the 'wood' and not so much the 'working.' LOL We had two dinky closets side by side (why in God's name the builder built them like that is beyond me); and it drove me nuts trying to figure out what to do with them. One day, wife said "Is there any reason we can't knock them down and make one big pantry or closet out of it?
    :facepalm:
    So we did just that; and once done, I put pine shelves in there. Wife wanted wire shelves; I said "no way." They're interlocked with the vertical support, with L-brackets tying them together in the middle. I did the flooring as well from some leftover stuff we had from our master suite addition.
    RainMan_PNW, KillaahCam, Navi and 2 others like this.
  24. Feb 17, 2021 at 2:51 PM
    #174
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Kings, 5:29's, E-lockers on 37's
    This came up in my FB memory's. We flooded in 2016 required a full gut of the house and I lost my job because they flooded and never recovered.
    My 62 yr old buddy thats a cabinet builder asked me to come work for him and help where we could. He and I built and installed 119 sets of kitchen cabinets that included bathroom vanity's, laundry cabinets, FP mantles etc. between Sept-Dec. 2016
    We worked like Hebrew slaves, mostly paint grade but a lot of old cypress, some ash or hickory
    ZappBrannigan and saybng like this.
  25. Feb 17, 2021 at 3:00 PM
    #175
    saybng
    Gary
    Ventura CA
    Made moms urn box last month, zebra wood, paduak and purple heart.:(
  26. Feb 17, 2021 at 3:40 PM
    #176
    cctxquicksand
    Some of my works
    Yellow pine 2x4s, some red oak on the vise clamps
    Gotta start with a work bench right?
    le mallet
    Splalted maple and black walnut
    the misses wanted a sewing table
    Top is red oak and black walnut
    upload_2021-2-17_17-34-32.jpgCabinets and island, actually everything you see besides the granite laying
    buddy of mine needed a quick study desk
    End grain cutting boards that were Xmas gifts
    eBay kit guitar my buddy wanted my to do for him
  27. Feb 17, 2021 at 4:36 PM
    #177
    Navi
    Navi New Member
    Great project and a very special meaning. sorry you lost your dad, i know he's proud of the work!
    KillaahCam likes this.
  28. Mar 14, 2021 at 10:34 AM
    #178
    Njmike13
    Njmike13 New Member
    2021 PRO Lunar Rock
    Making a long narrow table for the dining room. 10ft long 30in wide. Using some reclaimed hemlock. Still searching for the top. I would like 2 15in wide boards but haven't found something I like yet.
    Navi, RainMan_PNW and saybng like this.
  29. Mar 14, 2021 at 12:07 PM
    #179
    jwatt
    jwatt I heart men
    Jack
    Oregon
    Salsa Red 2007 Tundra DC @91k.
    7" BDS Coilover Suspension Lift/BDS UCAs/XB LED Headlights/Nitto trail Grappler tires on Black Rhyno Armory wheels
    I never pass up a chance to show what I used to do, albeit, I m not on the level that some of you folks are at.
    The majority of the cutting was done with this old Emco desktop cnc mill.This is how I got into cnc programming.
    Burkley, alb1k, tnmadness and 10 others like this.
  30. Mar 14, 2021 at 12:25 PM
    #180
    RainMan_PNW
    Casey
    Clark County, WA
    Beautiful, and carries so much more meaning than some store bought vessel.
    I did the one for my FIL. Tiger stripe maple with walnut dovetail splines. The defect in the top was on purpose... because he wasn’t perfect either. He’s sealed in there with his favorite cat, Andy, who had to be put down only a few weeks after he passed. When my MIL passes, I’ll be opening it back up to put her in there as well.
