DFW Shop That Rebuilds Shocks?
Discussion in 'Texas' started by equin, Nov 29, 2020.
  1. Nov 29, 2020 at 10:51 AM
    equin
    equin [OP] Texarican Tundra
    Ed
    DFW, TX
    Hi All,
    Anyone know of shops in the DFW area that can rebuild shocks? I know places like Southern California have plenty of shops that do that. I’d rather not ship my shocks and prefer to use someone local if they have the know-how and experience, though. Anyone have their shocks rebuilt here in the DFW area?
    Thanks in advance for any info!
    g6t9ed likes this.
  2. Nov 29, 2020 at 11:51 AM
    RobertD
    Robert
    DFW, Texas
    Maybe call 4wheelparts or SummitRacing? If they don't do the work the might know a place that does. I haven't had to deal with this so that all the advice I have. Good luck :fingerscrossed:
    equin[OP] likes this.
  3. Nov 30, 2020 at 8:17 AM
    The Patriot 1776
    The Patriot 1776 Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    There's a guy on TW that lives north of Denton that rebuilds them.
  4. Nov 30, 2020 at 8:51 AM
    equin
    Ed
    DFW, TX
    Thanks, RobertD and Patriot 1776. Lake Vista is kind of far, but at least its in Texas and much closer than So Cal. I called the Dallas 4WP office. They’ve always been friendly and helpful to me in the past. Just as friendly this time, but they’ll only refill with nitrogen if you buy the shocks from them. They also require to R&R them just for the refill at your cost of labor.
    Texas Motorworx, which appears to specialize in Ford Raptor builds, will refill nitrogen at $20 per shock as long as it has a schrader valve. Apparently, the 2.5 bodies have them, but not the 2.0’s. They don’t do rebuilds, though. Instead, they ship them to a shop down the street from Fox that does all their rebuilds.
    I’ll keep looking and will report back on what I find. Surely there are others in the area with rebuildable shocks that have had them done locally? Supposedly they’re supposed to have the oil and seals changed every so often. Otherwise, I guess I’ll have to try to learn to rebuild them myself and then take them to TX Motorworx for the nitrogen refill.
  5. Nov 30, 2020 at 9:02 AM
    equin
    Ed
    DFW, TX
    Dang, I almost forgot! I also asked on Facebook and got a response that Tribe 16 in N Richland Hills rebuilds shocks if you supply the parts, which I assume is the rebuild kit (shims, seals, etc.). I’ll have to follow up on that to confirm.
    g6t9ed likes this.
  6. Feb 13, 2021 at 6:29 PM
    the_midwesterner
    the_midwesterner New Member
    Luis
    2016 Tundra TRD Pro - Quicksand
    None, yet....
    I know this is a little old, but if you are still looking for shock rebuilders, I just moved into the DFW area and do it on the side. I am experience doing most of the big name brands and get parts from them directly. If you are still looking for someone, shoot me a DM. I am just east of McKinney on a handful of acres in Princeton, TX.
    L5Pete and equin[OP] like this.
  7. Feb 13, 2021 at 6:38 PM
    Do them yourself. From those prices, after one rebuild the tooling will pay for itself.
    https://www.tundras.com/threads/king-shock-rebuild-pic-heavy-get-beer-s.36345/
    equin[QUOTED][OP] likes this.
  8. Feb 13, 2021 at 6:52 PM
    the_midwesterner
    Luis
    None, yet....
  9. Feb 13, 2021 at 6:54 PM
    Dude, I was just going to link your intro to this. :fistbump:
  10. Feb 13, 2021 at 6:55 PM
  11. Feb 13, 2021 at 7:09 PM
    And we need to change your site name. Maybe the_texan. Lmao
  12. Feb 13, 2021 at 7:40 PM
    the_midwesterner
    Luis
    None, yet....
    I don’t actually hate that. Ha.
  13. Feb 13, 2021 at 7:43 PM
    That site name hasn’t been taken yet....FYI. Let me know via pm. :D
  14. Feb 15, 2021 at 7:23 PM
    equin
    Ed
    DFW, TX
    Thanks, Luis. Not too old at all. I haven’t even installed them yet. But when I do, the time will come eventually to get them rebuilt.
  15. Feb 15, 2021 at 7:28 PM
    equin
    Ed
    DFW, TX
    Thanks. Yes, I read through your thread. Very informative, and I appreciate the time you put into it. I’ve also only found a few rebuild videos on youtube that are helpful, mostly King shocks, though. Mine are Fox 2.5’s, and I’m guessing they’re all the same? I’m surprised I haven’t found more videos, but I may not be searching that well.
  16. Feb 15, 2021 at 7:40 PM
    Fox are similar. If you have RR, you have to set reservoir piston depth.
    https://www.kartek.com/parts/all-ge...-depth-gauge-works-on-fox-or-king-shocks.html
  17. Feb 15, 2021 at 8:28 PM
    equin
    Ed
    DFW, TX
    Good to know, and cool little tool from Kartek/German Motorsports. Thanks!
    The fronts do have RR, so reservoir piston depth will need to be set. Still haven’t decided what to do for the rear, though. Fox doesn’t seem to offer just a 2.5 OD rear without RR, just a 2.0 OD, at least not that I can find. From what I’ve read on here, 2.0’s may not be sufficient, or at the very least they may not keep up with the bigger fronts?
    While I’ve swapped out my share of bolt-on suspension parts on various vehicles over the years, I’m new to running the somewhat higher quality suspensions like the Fox 2.5’s coilovers I just got. Very anxious to try it all out once I get everything installed.
  18. Feb 16, 2021 at 6:13 AM
  19. Feb 16, 2021 at 10:28 PM
    equin
    Ed
    DFW, TX
    Yeah, I had been looking at those. Main reason would be cost and simplicity, but I’m new to these kinds of higher performance shocks and learning.
    Right now I’m running 6112s and 5160s. They were great when I got them 50K miles ago, but now I can tell they’re feeling a little worn, as if their damping capabilities aren’t what they used to be. I’m hoping the Fox’s will be a noticeable improvement, and it helps to know I can get them rebuilt, rather than replaced, when worn.
