  1. Feb 16, 2021 at 6:07 AM
    Knox_Tundy
    Knox_Tundy New Member
    Knoxville, TN
    Newbie here. Been lurking for a while. Figured I’d post the truck. Thx
    Cosmoblu, RBB, Ostrich and 50 others like this.
  2. Feb 16, 2021 at 6:10 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! Nice truck!
    Knox_Tundy[QUOTED] likes this.
  3. Feb 16, 2021 at 6:28 AM
    MogwaiBoogie
    MogwaiBoogie New Member
    Justin
    TEXAS
    2020 Tundra Platinum
    She's a Beaut' Clark!
    Knox_Tundy[QUOTED] and Astom22 like this.
  4. Feb 16, 2021 at 6:34 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Welcome!
  5. Feb 16, 2021 at 6:35 AM
    Welcome from NY.
  6. Feb 16, 2021 at 6:45 AM
    CappyKD
    CappyKD Older, grayer member.
    Kirk
    2025 Limited 4x4 TRD Off Road CC 6.5 Lunar Rock
    Welcome from SoCal! Nice truck!
  7. Feb 16, 2021 at 6:56 AM
    NoKenDo
    NoKenDo New Member
    Ken
    Grand Rapids MI.
    2018 Platinum 4x4 Mesquite Brown
    TRD Pro Suspension. Moonroof. Front window tint. Compustar Pro T11 remote starter. N-FAB running boards Bedrug Bedmat XLT DiamondBack HD Tonneau Weather Tech Window Visors
    Welcome from West Michigan.
  8. Feb 16, 2021 at 6:57 AM
    Black Dynamite
    Black Dynamite New Member
    2017 Toyota Tundra Limited Crew Cab
    Welcome from NoVA
    Knox_Tundy[QUOTED] and 1UP like this.
  9. Feb 16, 2021 at 7:02 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    +1 Welcome from NOVA (Northern VA)
    16 blue crewmax likes this.
  10. Feb 16, 2021 at 7:11 AM
    PonyMan
    PonyMan Old Man
    Central, Louisiana
    2021 Tundra CrewMax 4WD Limited Nightshade Special Edition MGM
    Welcome from La here(Louisiana)!
    KWC and Knox_Tundy[QUOTED] like this.
  11. Feb 16, 2021 at 8:15 AM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Kings, 5:29's, E-lockers on 37's
    Put my personalized plate on the other day and took a pic today. Its been on every truck I've owned since the early 90's. A side view just because
  12. Feb 16, 2021 at 8:22 AM
    TNTundra16
    TNTundra16 YOU BIG DUMMY!
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    Welcome from Middle TN!
  13. Feb 16, 2021 at 8:37 AM
    carsonhudson
    carsonhudson New Member
    What wheels are those?
  14. Feb 16, 2021 at 9:39 AM
    Long Duck Dink
    Long Duck Dink Nope
    North Salt Lake, UT
    2019 Super White 1794 Edition Tundra CrewMax 4x4
    3/2" Readylift, TRD Dual Exhaust, TRD Sway Bar, Line-X Bedliner, ArmorFlex Tonneau, ESP 3 bin storage, Amp Power-Steps, Driver Side Grab Handle, Ronin Antenna, Window Tint, ClearBra. Coming Soon: 20" Method MR305NV. BF Goodrich KO2 275/60/20
    Hit 9k miles while going 90mph on my way to St. George this weekend.
  15. Feb 16, 2021 at 9:47 AM
    Pangaea
    Pangaea New Member
    BC
    2021 Cement Tundra CM TRD Off Road Premium
    Nice truck! Really clean - I like it! Welcome from BC!
  16. Feb 16, 2021 at 10:32 AM
    kyle112006
    kyle112006 New Member
    Kyle
    Claim for what? This should be warranty correct?
  17. Feb 16, 2021 at 11:47 AM
    TampaRD Pro
    TampaRD Pro Cunning Linguist
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    Finally got around to installing my roof rack that I ordered around Black Friday. I went with the Victory 4x4 rack as I have a friend with the same rack and like the sturdy construction and the way it looks on a Tundra. I am aware of the controversy about the vendor and former install instructions that apparently led to damaged side curtain airbags with some members of this forum. Thanks to TwoWheels, the original poster of that thread, who brought this safety issue to light and as always for the good information this forum provides to the Tundra community. I took extra precautions when drilling my roof to prevent any possible damage to my airbags and have to admit it was daunting drilling into the roof of my truck for any reason. First, I marked the locations to drill the holes to mount the rack. Then I dropped the headliner around the sides of the truck so that I could inspect the clearance of the airbags and any wiring that might be in that area. Then I took a piece of 1/2" inch thick x 2" wide aluminum flat bar and laid it on top of the airbags beneath the drilling locations as I drilled each set of holes just in case I accidentally over drilled a hole. I used drill stops set to around 5/8" inch depth on the drill bits and carefully drilled the holes. By going slow I was able to control the drill pretty well and the stops "bottomed out" the drill bit without slipping and prevented any over drilling. I used an Astro Pneumatic Model 1442 RivNut Setter to properly set the rivnuts instead of the flimsy wrench tool provided with the rack. I filled the holes with marine grade sealant before setting the rivnuts. Then I bolted the rack to the rivnuts and added some more sealant on top of the bolts just for good measure. The rack is now very sturdily mounted to the the truck and is ready to mount my backordered CVT Hybrid Awning when it comes in.
    I installed a 4" wide 3M "clear bra" over the windshield to prevent the rubber trim on the bottom of the fairing from chafing the paint. (It's kinda hard to see.)
    I measured and marked the hole locations, and installed drill depth stops on the drill bits to be used.
    Dropped the sides of my headliner to inspect and have access to the side curtain airbags,
    This is the 1/2" thick x 2" wide aluminum flat bar I laid over the top of the airbags prior to drilling the roof.
    Astro Pneumatic Model 1442 RivNut Setting Tool and 3M marine grade sealant. Holes drilled and rivnuts set.
    Finished results.
    RBB, Ostrich, vanthesupreme and 27 others like this.
  18. Feb 16, 2021 at 12:54 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    Not much of a mod but I made the final payment.
  19. Feb 16, 2021 at 12:54 PM
    KingsAustin
    KingsAustin Grey Goose II
    Morgan County, AL
    2021 Limited Night Shade
    BakFlip MX4, Gator All Weather mats, Console Safe, Ceramic Tint, Roadmaster Active Suspension, Interior/exterior LED conversion, Wireless console charger, AJT designs.
    One of the best mods!
  20. Feb 16, 2021 at 12:59 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    Yes sir, I got very aggressive this past year and I am liking the feeling.
  21. Feb 16, 2021 at 1:01 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Congrats! I'm doing quadruple payments till it's gone. Sucks for now, but it'll be paid off this October if I keep it up.
  22. Feb 16, 2021 at 1:02 PM
    Catmann1972
    Catmann1972 New Member
    Greg
    Rhode Island
    2020 TRD Sport
    Can he confirm that with actual dates. Just doesn't seem right to me. Hard to believe that Mice moved in to his truck that quickly.
    Astom22 likes this.
  23. Feb 16, 2021 at 1:05 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    Thanks brother! There were definitely months it sucked but keep to that goal...
    WILLINH and Terndrerrr[QUOTED] like this.
  24. Feb 16, 2021 at 1:10 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    :yes::muscleflexing:
    Oey12[QUOTED] likes this.
  25. Feb 16, 2021 at 1:20 PM
    Knox_Tundy
    Knoxville, TN
    Thanks for the warm welcome everyone.
  26. Feb 16, 2021 at 1:58 PM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    nice truck ! what lift do you have ?
    Long Duck Dink likes this.
  27. Feb 16, 2021 at 2:27 PM
    Finally got my TPMS sensors to register to the truck after 200 miles and several days of pushing the reset button. I don't even remember how I did it. Now that the light is out, I assume this is where I do the drive cycle for it to read the pressures. I pushed and held the reset until the light flashed 3 times, and then drove about a 4 mile trip home from Lowes. Do I have to do the same hold process every time I drive it until the pressures show or will it automatically look for them as I continue to drive it?
  28. Feb 16, 2021 at 2:44 PM
    jefroshm0
    jefroshm0 New Member
    Elk Grove, CA
    2018 Cement Tundra Crew 4x4 SR5
    Ran to Home Depot today to pick up some mounting plates for my MicTuning rock lights (8 piece). These lights are meant for under body. I have another 8 piece kit for the wheel wells.
    bending the mounting plates, drilling holes for light mounting and install took about an hour or less. Had to create my own wiring harness again because I will be running two sets of lights off one switch.
    Not going to place them under the truck till it’s dark and I ran power. Want to maximize the available light for each piece. Another weekend project I’m assuming.
  29. Feb 16, 2021 at 2:52 PM
    CappyKD
    Kirk
    Chewed wiring is not a Warranty item unfortunately.
    NewImprovedRon and lonedrake like this.
  30. Feb 16, 2021 at 2:58 PM
    CappyKD
    Kirk
    It is confirmed, hence why I posted the last reply that the dealer only had the truck for 2 days before I bought it. It is a no win battle and not worth fighting imo. I had the truck for 3 weeks without issue. Now it throws codes immediately after clearing them. Pretty much no way it could have been chewed on the dealers lot.
    Thanks,
    Kirk
