Show your Tonneau cover
Discussion in 'Tonneau Covers, Caps and Shells' started by G-manCO, Nov 13, 2017.
  1. Oct 7, 2020 at 10:05 AM
    #301
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Pretty slick. Nice video
  2. Oct 10, 2020 at 10:43 AM
    #302
    Heath423
    Heath423 New Member
    Heath
    Chattanooga, TN
    2020 Magnetic Gray CM SR5 4WD
    Console tray/dividers, Interior LED's
    @Okrunman When I installed my Flex (post 297) I was going to try and utilize the track system as you did. For me it appeared that the Flex bed cover rails sat higher than the 1/8" (per install instructions) above the bed rail due to it sitting on top of the adjustable cleats (the black adjustable knob was removed). Therefore, I removed the cleats before installing the cover. My question is did your cover sit a little higher than the 1/8" above the bed rail due to sitting on top of the cleats? If so, have you had any issues such as leaks? Side note with my current install I am getting some leaking on all 4 corners. I expected some at the corners near the tailgate but none up front.
  3. Oct 18, 2020 at 12:46 PM
    #303
    Tao Zero
    Tao Zero New Member
    2021 Black Tundra Platinum
    Does this tonneau use the factory bed rail system without having to relocate them?
  4. Oct 25, 2020 at 6:43 AM
    #304
    pop's
    pop's 1794
    Michael
    North Aurora IL
    2017 Tundra 1794 Blue Pearl / 1995 T100 4x4 DX
    $7500 in upgrades
    I went with Diamondback
    Tamutundra and Tundra pi like this.
  5. Oct 28, 2020 at 12:32 PM
    #305
    wlbjr
    wlbjr New Member
    West TN
    2020 Tundra SR5 TRD Sport
    Looks great- just ordered one of these. Hope you're still liking it! :)
  6. Oct 29, 2020 at 6:35 AM
    #306
    ZandrT
    ZandrT New Member
    Zandr
    Greenville, SC
    2017 Silver Tundra Limited CrewMax TRD
    BFG KO2 - 275/70/18 Bilstein 5100's front (middle setting) RCI Aluminum Front Skid Undercover Ultra Flex Tonneau GoRhino RB20 Running Boards Bully Dog GTX - Premium Download TRD Rear-Sway Bar TRD Intake Flow Accelerator aFe Drop in Filter Flowmaster Super 50 CravenSpeed Stubby Antenna WeatherTechs TRD Center Caps
    I installed an UnderCover Armor Flex Tonneau Cover (Line-X coating over aluminum panels) around 6 months ago. Love it so far and took only an hour to install to factory rail system. Very durable and I like that it can be folded / flipped all the way up or 3/4 up. Let me know if you have any questions and hope this helps!
    CoachJ and Skew12 like this.
  7. Dec 1, 2020 at 7:09 AM
    #307
    AZboiler
    AZboiler New Member
    Tony
    2020 TRD Sport in MGM
    Lomax Tonneau, TSS 20" Wheels, Wildpeak AT3s
    After reading several of the reviews on here and on YouTube, I went with the Lomax. Couldn't be happier with my choice! I've driven through heavy rain, and tested with the pressure washer at the car wash. Only about 1-2oz of water at most coming in from tailgate. I bought the tailgate seal from Lomax, but have yet to install. With bed mat now, zero water would touch anything in the back.
    LVTundra2024, Skew12 and Orracle like this.
  8. Dec 7, 2020 at 12:22 PM
    #308
    ConspiracyOfOne
    ConspiracyOfOne New Member
    Raymond
    Husdon Valley NY
    2021 TRD Sport MGM
  9. Dec 21, 2020 at 9:58 AM
    #309
    Orracle
    Orracle New Member
    Canton, GA
    Tyger Auto T3 Soft Tri-Fold $219 on Amazon
    JerryH likes this.
  10. Dec 31, 2020 at 9:48 PM
    #310
    Minarets
    Minarets New Member
    Nashville
    2021 TRD PRO
    putting one on next week. I like the idea of the stance better than their regular offering.
  11. Jan 9, 2021 at 12:34 PM
    #311
    beerreason
    beerreason New Member
    2010 CrewMax TRD Off-road (purchased 2020), 2002 Access Cab (owned 2002-2020)
    For Christmas, I got this on Amazon, about $431. Another seller shows the exact same item as a "Deebior" brand for $445.
    Puermto 5.5'/66.7" Hard Quad-Fold Black Aluminum Rails Waterproof Tonneau Cover For 2007-2021 Tundra Crewmax Cab Pickup
    As it turned out, I ended up with a second identical one that I need someone to take off my hands. It has minor dings from shipping on the first hinge that don't show when the cover is closed. Otherwise it's in perfect shape, but they said not to bother shipping it back when they sent me a replacement. Any takers? Make me a reasonable offer! :)
    My replacement one (shown above) arrived on Dec 26, and got it installed in no time. The perimeter weatherstrip is pretty much like you have on a car door (but bigger) - very heavy duty with a hollow channel for compression. Laterally along every hinge joint, there's also a thin rubber strip that's compressed when the thing is unfolded. We took it on a road trip over the holidays but didn't encounter any real rain. This past week, however, we've gotten a lot of rain, and the inside of the bed has stayed nice & dry.
    Compared to a lot of the other options, this is a more budget-friendly choice. On my 2002 Tundra, I had an Extang soft vinyl cover with the snaps around the perimeter. It kept things dry, but it was a bear to put on if it was remotely cold outside and the vinyl stiffened up. It also provided zero security if someone wanted to slash it to see what I had inside. I was determined to get some kind of hard cover this time around, and so far I'm extremely happy with my selection.
  12. Jan 9, 2021 at 3:24 PM
    #312
    Nighthawk
    Nighthawk New Member
    Keith
    Frederick Md.
    2018 Tundra Limited crewmax
    linex bed Truxedo Pro F-15 Tonneau,Weathertech mats,TRD exhaust,Matt Geckco bed lights,hood light,shorty antenna, all LED lights inside, Fomoto oil drain valve,
  13. Jan 9, 2021 at 3:36 PM
    #313
    Nighthawk
    Keith
    Frederick Md.
    TruXedo Pro X15 has a Fabric surface like a convertable.Also the 15 stands for 15 degree angle. I have ot on for 2 yrs so far so good.best thing it only cost $450 to my door.
  14. Jan 13, 2021 at 12:41 PM
    #314
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Got a great deal on a used Bakflip G2. I should replace the seals but thats only $25 or so.
    It's off a 1st gen DC but fits my AC.
    abcinv likes this.
  15. Jan 13, 2021 at 1:10 PM
    #315
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    Not the greatest picture but I just wanted to show potential buyers what not to buy...Bakflip MX4. Nick name:Bakst!$. ...utter garage...
  16. Jan 13, 2021 at 1:59 PM
    #316
    McCrapper
    McCrapper New Member
    Whats the issue here?
  17. Jan 13, 2021 at 2:27 PM
    #317
    Oey12
    Oey12 New Member
    Joey
    New York
    The panels leak like hell, not the rails that attach to the bed of the truck. The rubber bushings between the individual panels are horrendous. During rain storms the entire bed is wet. My bed is filled with those Rubbermaid 5 gallon totes because nothing stays remotely dry. All covers leak at the coroners, I would have been thrilled with that!
    The plastic buckle fell off along with the rubber feet that are attached for when you fold the cover up against the bed. And Bakflips answer was just to get me to send more pictures...I sent them over 30 pictures and it wasn’t enough to get it replaced under warranty. At the time I owned it only three weeks.
    Additionally they wanted me to send a videos and pictures of me running my hose because the rain storm pictures weren’t enough. I refused the hose videos because I am not wasting water and water is expensive where I am. I was so angered at the time I wanted to sent the cover back filled with dog S$&! because that how I was treated as a customer...lucky was wife talked me down.
    I literally open and the cover once maybe twice a week since May of 2020. It’s a second vehicle. Ohhh and the latch’s are loose...I feel used but ultimately they won. I have a horrible product they they have my 850 bucks.
    :annoyed:
    Bakflip=garbage
    Gunship Guy likes this.
  18. Jan 23, 2021 at 4:32 AM
    #318
    Willard
    Willard New Member
    2024 F250
    I had almost the exact same experience with Bakflip on an mx4. Super difficult to deal with their (lack of) customer service.
    Oey12[QUOTED] likes this.
  19. Jan 28, 2021 at 7:50 AM
    #319
    kobo1984
    kobo1984 New Member
    Does anyone use soft tonneau with Wilco adv bed rack?
    I need the cross bar of bed rack that should be move forward.
    Cause I need to load my dirt bike, I don’t have to remove the bed rack.
  20. Jan 28, 2021 at 6:48 PM
    #320
    I_Am_Thee_Walrus
    I_Am_Thee_Walrus New Member
    ‘21 Tundra TRD Off-Road
    Not the best picture but it’ll do. Added a Tonnopro Lo-Roll to the truck tonight. Had one on a previous Silverado and it can’t be beat for the money. I dig the low profile look and they’ve even made some improvements since the last one back in 2016.
    edgewardoe likes this.
  21. Feb 2, 2021 at 11:01 AM
    #321
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    Hoff and Big J like this.
  22. Feb 13, 2021 at 7:00 PM
    #322
    Velocity72
    Velocity72 New Member
    Upstate SC
    2021 Platinum
    Headed in the Ultraflex Armor Flex direction. It has the LineX on top, which will keep it looking good for a long time. The interrupted surface is actually not as hot in the sun than a flat smooth surface. The engineering on this one looks well done. I need the flexibility of using the full bed (minus the 8” at the top that it takes up when it’s vertical) without having to remove a tonneau. I had a Retrax on a former Tundra, and liked it. It leaked at the tailgate like most, but I got tired of the space that the box took up.
  23. Feb 16, 2021 at 6:42 AM
    #323
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    Dropped a Retrax onto her within two weeks of picking her up. Live in California so hail isn't an issue.
    Installation was a snap and after three nice storms, it's dry inside.
    For my purposes it's real functional so let's see how it holds up over the next year.
    BTW, my unit is the manual one.
  24. Feb 16, 2021 at 9:38 AM
    #324
    Tundra9880
    Tundra9880 New Member
    2019 Cement CrewMax SR5
    Leveled, wheels and tires, Line X on the grille surround and bulge, Line X in the bed, Retrax rolling Tonneau cover, Flowmaster Outlaw cat back exhaust.
    Bought one of these a month ago myself. Love it.
  25. Feb 22, 2021 at 3:51 PM
    #325
    racerex
    racerex New Member
    Will
    Westchester County, NY
    2021 Limited CM TRD Off-Road
    Smooth Diamondback SE. Very happy with it.
    Tamutundra likes this.
  26. Feb 22, 2021 at 5:00 PM
    #326
    Nowhereman
    Al
    Monterey Bay area
    Looks clean.
  27. Feb 28, 2021 at 11:58 PM
    #327
    Occidentalis
    Occidentalis Out Snakin'
    North Florida
    2015 Inferno TRD Pro
    This is my top choice for sure. How do you like the coating on it?
    Any thoughts from any Diamondback owners on heat being an issue with the black finishes vs the reflective unfinished aluminum? FL Sun is brutal and contents being cooler rather than warmer would be a plus.
  28. Mar 1, 2021 at 6:26 PM
    #328
    racerex
    racerex New Member
    Will
    I really like the coating. I only just installed it, so I can't speak to any heat issues. With the underside of the cover being raw aluminum, I don't see any reason why you couldn't install some automotive flexible thermal insulation to the underside to control radiant heat in the cargo area. I've used light-weight combo sound deadener and heat barrier mat on a few of my vintage muscle car interior floor pans to control heat from the engine and headers/exhaust system.
  29. Mar 1, 2021 at 6:46 PM
    #329
    Occidentalis
    North Florida
    That's a really good idea. I was planning on running some light wires in there with leds for lighting in the bed and scene on the outside - I could just wire everything up and take it and have icynene sprayed in haha!
  30. Mar 13, 2021 at 4:32 AM
    #330
    cardinal
    cardinal New Member
    Central Ohio
    2021 SSM CM LTD TRD4x4
    That looks really sharp: I think your choice of smooth the smooth finish looks great. I'm interested to hear what you think of it after having owned it for a while. I'd really like to get one with the tool tray in the front, but I also use the entire bed of my truck a decent amount. How easily removed is the Diamondback?
