Let's see 1st gen with Toyota Rims
Discussion in '1st Gen Tundras (2000-2006)' started by Lupe, Feb 19, 2019.
  1. Jan 15, 2021 at 12:00 PM
    #481
    speedtre
    speedtre New Member
    Inland Northwest
    Those look fantastic on that truck...
    Sampson and FrenchToasty like this.
  2. Jan 16, 2021 at 1:43 PM
    #482
    shoe07
    shoe07 New Member
    Ohio
    2004 Tundra Double-cab SR5 Tow pkg
    Ended up getting the GX460 wheels. Unfortunately the Lexus center caps are slightly different than Toyota. (Shorter and slightly smaller diameter.) I’m going to buy a cheap set of Toyota center caps, and take the chrome emblem off and put on these. Im happy with the look .though
    Hummer, Rex Kramer, speedtre and 3 others like this.
  3. Jan 17, 2021 at 4:46 PM
    #483
    tundrav82020
    tundrav82020 New Member
    T
    2006 Tundra DC XSP
    Stock XSP's which came with the truck
  4. Jan 25, 2021 at 12:38 PM
    #484
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    Can we see a profile shot of these? Those look good on your truck.
  5. Jan 28, 2021 at 5:43 PM
    #485
    FoCoCuso
    FoCoCuso New Member
    2004 Tundra SR5 DC
    Stoked!! Look what came today.... Time to throw some KO2s on these and mount them. Next up, suspension upgrade!
  6. Jan 29, 2021 at 7:33 AM
    #486
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    Those looks nice but I am not sure they qualify.
  7. Jan 29, 2021 at 2:54 PM
    #487
    shoe07
    shoe07 New Member
    Ohio
  8. Jan 29, 2021 at 2:58 PM
    #488
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    It looks like they might set just bit more inside than the stock wheels? What do you think?
  9. Jan 29, 2021 at 3:19 PM
    #489
    Professional Hand Model
    Fred
    Hand Protectors
  10. Jan 29, 2021 at 3:43 PM
    #490
    shoe07
    shoe07 New Member
    Ohio
    Yup, they’re +25 rather than standard +15 so sit in 10 mm closer
  11. Jan 29, 2021 at 6:48 PM
    #491
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Brutal
  12. Jan 29, 2021 at 8:07 PM
    #492
    TomG
    TomG New Member
    Thomas
    Lumberton, TX
    2020 (1794) & 2006 (Limited) Toyota Tundra
    Hummer, potoghi, tunyota and 3 others like this.
  13. Jan 30, 2021 at 6:01 AM
    #493
    Fred
    Hand Protectors
    I had Pizza Cutters on an 87 Toy P/u and they looked like this. I enjoyed those tires and they reminded me of Sponge Bob.
  14. Feb 5, 2021 at 12:10 AM
    #494
    Captain Tenneal
    Captain Tenneal New Member
    NNV
    2005 SR5 Double Cab Off-Road Package, Sunroof
    Bilstein 5100 - 1 groove up
    With the help of a Costco sale and much research, I finally got the tires to go with the wheels. Ended up with LT245x75x17 Bridgestone Revo 3 (4 lbs lighter than Michelin Agilis). Overall the weight of the wheels and tires are about the same as a stock setup. Went with the LTs to get extra protection on dirt and gravel roads. Skinny tires to minimize the hit on gas mileage. I'm surprised how 9/10s of an inch more tire diameter fills the wheel well. Slightly more feedback in the steering (good) and slightly stiffer ride (Costco inflated the tires to 45 lbs...maybe I should take out 5 lbs?), not bad at all. Full disclosure, the front end is 3/4 inch higher than stock.
    Amazing how a phone camera hides all the dirt and paint imperfections.
    Tundra Side New Wheels.jpg Tundra Rear Quarter New Wheels.jpg Tundra Front Quarter New Wheels.jpg Tundra Rear New Wheels.jpg
    Hummer, JasonC., Oldgray and 10 others like this.
  15. Feb 5, 2021 at 6:25 AM
    #495
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Looks good !
  16. Feb 5, 2021 at 7:13 AM
    #496
    speedtre
    speedtre New Member
    Inland Northwest
    I love skinnies (I run 255/80/17s on those same wheels). LT tires need to run higher PSI...I wouldn't run them lower than 45...I run mine at 50.
    https://www.tirereview.com/tire-typ...for-size, compared,to excessive heat build-up.
  17. Feb 5, 2021 at 3:35 PM
    #497
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 SR5 Tundra TRD Off Road
    Somebody may have posted similar, but I'm not sifting through 17 pages of posts...
    2016 Tacoma TRD Pre-Runner wheels, 1.25" spacers, on 265/70-R17 BF Goodrich. Tires are just about flush with the stock fender flares.
    I'd love to have the 1st gen Tundra BBS 18's but those are out of budget.
  18. Feb 5, 2021 at 3:39 PM
    #498
    shoe07
    shoe07 New Member
    Ohio
    With th
    ose spacers they just bolted up with no modifications to the studs? What brand did you get?
  19. Feb 5, 2021 at 3:51 PM
    #499
    Riverdale21
    OTP ATL
    Can't remember the brand, bought them off Amazon for my 3rd gen 4Runner then swapped them over when I got the Tundra. No modifications to the hub, they're hub centric. The front studs on the Tundra are too short to have full depth engagement on the nuts, OEM stud ends about 3/8" from the outer lip of the nut, but I installed them with Loctite blue and a torque wrench. Rear studs are no problem, full thread engagement.
    I want to eventually put the 18" BBS otherwise I would put 10-15mm longer studs. Check nut torque every time I rotate the wheels and haven't had an issue. Manufacturer suggested checking torque after about 100 miles of driving after initial install.
  20. Feb 7, 2021 at 9:13 AM
    #500
    speedtre
    speedtre New Member
    Inland Northwest
  21. Feb 7, 2021 at 10:06 AM
    #501
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    T
    Those are my favorite Gen-1 Wheels.
    I was considering them, but to maintain the factory overall tire radius/diameter you have to go down in rubber size, so maybe ride / load carrying suffers?
    I would also guess 18" rubber is pricier than 17".
    They sure look cool though . . . decisions, decisions.
    speedtre[QUOTED] likes this.
  22. Feb 7, 2021 at 12:07 PM
    #502
    speedtre
    speedtre New Member
    Inland Northwest
    Yea, I'm still pissed I passed up a 17 inch set that came on FJ Cruisers. They were local and I didn't pull the trigger fast enough. I think the Ivan Stewart 16 inchers are my favorite FGT specific wheels...
    HBTundra[QUOTED], Darkness and abcinv like this.
  23. Feb 7, 2021 at 12:08 PM
    #503
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    Your setup is pretty nice; I wouldn’t trade out what you have!
    FirstGenVol and speedtre[QUOTED] like this.
  24. Feb 7, 2021 at 8:07 PM
    #504
    Riverdale21
    OTP ATL
    Yup, them's the ones. They are my dream wheels, but low on the priority totem pole right now. That's a very good price too. I just spent about that much on new tires for the 17's just a couple weeks back.
  25. Feb 8, 2021 at 12:29 PM
    #505
    GIN•OKUMA
    GIN•OKUMA Can’t get to SSEM from there. RGBA1
    Fish
    26.57°
    Noun; a machine, usually with wheels and an engine, used for transporting people or goods, especially on land
    Put some FJ/4runner rims on. The OEM ones were rotting out.
    Hummer, HBTundra, Darkness and 2 others like this.
  26. Feb 8, 2021 at 12:42 PM
    #506
    SCBobKat
    SCBobKat Lov'n the Tundra life.
    Rob
    Moss Landing, CA
    2017 BlzBlu CrewMax
    Grille w/LED Bar, Rolln'Lock Tonto. Yakima racks, UnderCover Swing boxes. AJT Interior upgrades.
    Was rolling my stock rims for 12yrs. They still looked good.
    Kinda sad I had to say good bye to her but my new-to-me 17 is so much nicer.
    HBTundra and Darkness like this.
  27. Feb 8, 2021 at 12:59 PM
    #507
    I still think these look great.
    treology, GavinG83, Sampson and 5 others like this.
  28. Feb 9, 2021 at 10:42 AM
    #508
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Those look good, and I'm a picky weirdo.
    GIN•OKUMA[QUOTED] likes this.
  29. Feb 11, 2021 at 11:06 PM
    #509
    A.Smitty
    A.Smitty New Member
    Alex
    2004 Tundra Limited 4x4
    Installed some 2020 Tacoma TRD Pro wheels!
    Riverdale21, speedtre and des2mtn like this.
  30. Feb 15, 2021 at 11:13 PM
    #510
    Negley6
    Negley6 New Member
    Evan
    2005 Tundra & Sequoia
    Dobinson Lift, Method Rims, KO2s
    Aloha,
    Here is my 05 Sequoia with the Method 701. I also have an 05 Tundra build going and will post soon too.
    However I thought some might like to see what the rim looks like since both are so similar!
    Mahalo!
