2018 Tundra Sport 20" Wheels, tire recommendation.
Discussion in '2.5 Gen Tundras (2014-2021)' started by 18tundraMann, Feb 12, 2021.
  1. Feb 12, 2021 at 7:22 PM
    18tundraMann
    18tundraMann [OP] New Member
    Just got a 2018 Tundra Sport and will be getting exhaust and a 3 in lift done next week. I love the look the the 20in wheels and was looking for a tire recommendation. I'm looking to go between 33-34.5 in tire on the wheel, any advice would be greatly appreciated! ThPXL_20210208_211014523.jpg ank you.
  2. Feb 13, 2021 at 2:11 AM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    First off, welcome to the club from TEXAS! Second, you have given us little to no information about what you need in the way of tires, aside from a proposed size span. In order to give you any "advice" we need a lot more information. What is your budget? What type of driving will you be doing? Will you be hauling anything or doing any towing? What climate do you mostly drive in? What characteristics are important to you regarding tires (ie. aesthetics, off road performance, wet performance). Is tire weight an issue? Is tread noise an issue?
    Instead of you asking such a general question, start your research here:
    https://www.tundras.com/threads/official-tundra-wheel-and-tire-setups-pics-and-info.95/
    Once you have checked that thread out, and have narrowed down what you require, come back here and we will do our best to help you.
  3. Feb 13, 2021 at 2:59 AM
    InsaneAuto86
    InsaneAuto86 New Member
    SE PA
    2020 Tundra SR5 TRD
    I am running 275/60r20 (33.1") Atturo trail blade a/t @ about $100/tire
  4. Feb 13, 2021 at 3:15 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Welcome first off and congrats.. Wheels and tires section has all the answers...Good luck
  5. Feb 13, 2021 at 4:14 AM
    maxdriver
    maxdriver New Member
    ‘23 GRolla, sans ‘19 Tundra
    Well you got the best color truck! Good luck with the tire search.
  6. Feb 13, 2021 at 11:26 AM
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    I just got cooper AT3 XLT
    Sizes:
    - 275/55/R20: $230 Stock 32"
    - 275/60/R20: $270 I got this, 33", fits with plenty of clearance
    - 285/60/R20: $330 33.7" would easily fit
    - 275/65/R20: Didn't check price, but it was less than the 285. 34", would still fit at least on my truck (5100 shocks on lowest perch in front)
    Crunch527 likes this.
  7. Feb 13, 2021 at 4:57 PM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    275/60/20s will rub when at full deflection...
  8. Feb 13, 2021 at 5:06 PM
    BrakeDust
    Hill Country, TX
    Not for me, mostly stock Tundra. Not even close.
    Everyone needs to try before they buy, if possible. As your local tire shop for a demo.
  9. Feb 13, 2021 at 6:09 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    275/65-20 only rubbed my skid plate when I was at stock height.
    If I kept my 20s, I’d go with 295/65s.
  10. Feb 15, 2021 at 2:27 PM
    bunz559
    bunz559 New Member
    2020 SR5 TRD Sport
    Running 275/65/20 BFG's. Great tire and no rubbing at stock height20200921_112736.jpg .
  11. Feb 15, 2021 at 2:33 PM
    ZPhilip
    Philip
    West Chester, PA
    No modifications to stock skid plate?
    bunz559[QUOTED] likes this.
  12. Feb 15, 2021 at 2:36 PM
    68 RS/SS
    68 RS/SS New Member
    MIke
    New Hampshire
    2020 TRD Sport DC
    I have 275/60r20 duratracs on my sport
    bunz559 likes this.
  13. Feb 15, 2021 at 2:48 PM
    bunz559
    bunz559 New Member
    2020 SR5 TRD Sport
    None what so ever. I full lock my steering wheel all the time and have never run into any issues. Before I purchased, I did read somewhere that in 2018 or 2019, there was a slight skid plate redesign that removed the winglets that people were rubbing on. Mine is a 2020 so I assume mine has the update skid.
  14. Feb 15, 2021 at 2:52 PM
    ZPhilip
    Philip
    West Chester, PA
    Odd, I had same tire and wheel setup and rubbed skid at full lock. Only had to bend it up about 1/2” to clear. I’m wondering if the newer Tundras have a revised skid plate.
  15. Feb 15, 2021 at 4:25 PM
    Stanman9
    Stanman9 New Member
    This is a 3" readylift spacer with 1.5" rear, 1.5" wheel spacers and 275/65/20. They barely rub on full lock.
