OEM rotors?
Discussion in '1st Gen Tundras (2000-2006)' started by DJS Tundra, Feb 4, 2021.
  1. Feb 4, 2021 at 7:57 PM
    DJS Tundra
    DJS Tundra [OP] Lots to learn
    South Alabama
    2002 White Lmt 4x4
    So do you guys go oem or aftermarket I can get a pair of oem front rotors from my dealer for about $134
    Or rock auto anywhere $45-$160 for a pair.
  2. Feb 4, 2021 at 8:02 PM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 DC SR5 Tundra TRD Off Road
    I run the Powerstop Z23 from Rockauto and am not disappointed. Have stainless hoses on the way too.
  3. Feb 4, 2021 at 8:08 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    $134 each or as a set?
    I replaced mine with NAPA’s premium rotors and I think their ALTROM brake pads. Smooth stopping for 17k miles and counting.
  4. Feb 5, 2021 at 4:00 AM
    Professional Hand Model
    Fred
    Hand Protectors
    I have some Aftermarkets (unsure of brand) that a 4wheel Place installed about 2.5 years ago. They are holding nicely considering the OEM ones that warped on me in less than a year. Drove for 15 years on warped OEM rotors. :rofl:
    Jack McCarthy likes this.
  5. Feb 5, 2021 at 4:16 AM
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    For my driving habits, OEM is plenty good for me BUT.... one of my neighbors gave me one heck of a deal on a front set of Powerstop drilled and slotted rotors the other day. I was tempted to change the stock rotors when I changed the brake pads 2 years ago but didn't. Now I figure its time so I ordered the back set and am getting that done today. At 149,000 miles and being turned twice, the original ones (I assume) did their job and earned a brake.
  6. Feb 5, 2021 at 4:37 AM
    DJS Tundra
    South Alabama
    2002 White Lmt 4x4
    $134 for a front pair.
    But sounds like you guys are having good luck with aftermarket so I’ll just save the extra money for other stuff and go aftermarket.
    Just wanted to make sure this wasn’t an OEM only item recommendation.
  7. Feb 5, 2021 at 4:40 AM
    DJS Tundra
    South Alabama
    2002 White Lmt 4x4
    Yea my steering wheel has had a slight shimmy when I initially hit the brakes for 6months of ownership but otherwise stops fine .
  8. Feb 5, 2021 at 4:46 AM
    Fred
    Hand Protectors
    The high speed shimmy at brake tap and the slow pulse coming to a slow stop were my symptoms.
    New equipment was a nice change. One thing the shop didn’t do was remove the paper/corrosion from the wheel mating backing. I read that it was highly important to do so even with the little I had and thought this is bs!
    Ended up wire brushing all 4’s and used a Torque Wrench on the Lugs, too. Hey it really does make a difference!
  9. Feb 5, 2021 at 9:48 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Been happy with my aftermarket rotors, drums are more finicky
  10. Feb 5, 2021 at 9:51 AM
    Riverdale21
    OTP ATL
    True that. When I installed my Powerstop Z32 front kit last year I did new aftermarket rear drums, shoes, and cylinders. Had a wicked shake. Had to get the new drums machined out to get good even braking performance. I had never had to get brand new stuff machined before.
  11. Feb 5, 2021 at 10:31 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    I've had good luck with Maxbrakes.com. I got the Premium XDS with the rust coating, free shipping too!
    Try R1 Concepts Geomet as well.
  12. Feb 5, 2021 at 2:16 PM
    Fred
    Hand Protectors
    A quick tip: The OEM Drums come ‘balanced’. Most of our Rear Drums come with a little weight welded to the side of them.
  13. Feb 5, 2021 at 3:17 PM
    SouthPaw
    2000 Limited 4x4 AC
    I replaced my rear drums, shoes and hardware with all Napa stuff and so far, smooth sailing.
    Prior to this, brakes worked ok but when I was coming to a stop, it always pulled left. Not terrible, but enough you that you had to counter steer to keep it going straight. I got used it it but now that everything has been replaced, I can mash the brakes with my hand off the steering wheel and it’s as straight as an arrow.
    speedtre likes this.
  14. Feb 13, 2021 at 6:41 AM
    Rjlman
    Rjlman New Member
    Ray
    2018 Tundra Limited Crewmax
    None - cleaned up all the badges
    Punny!
  15. Feb 15, 2021 at 4:15 AM
    10TundraSR5
    Tennessee
    Rjlman[QUOTED] likes this.
