Body Mount Chops
Discussion in '2.5 Gen Tundras (2014-2021)' started by pvn.beluga, Feb 13, 2021.
  1. Feb 13, 2021 at 5:44 AM
    pvn.beluga
    pvn.beluga [OP] New Member
    Phuc (Phooc)
    Connecticut
    Not sure if this is the right place to ask this, but does anyone have any recommendations for a BMC shop that is reputable in the Connecticut area?
    What’s the average price one spends on a BMC? What’s a fair price?
  2. Feb 13, 2021 at 9:10 AM
    BigAl
    BigAl New Member
    2014 SR5 Magnuson SC
    I can't recommend a shop in your area but will say you should expect to pay $200 on the very low end to as much as $500. Try to go to some place that has experience with them on our trucks (or at least Toyota's in general). Some shops just don't like doing them, or don't have a competent welder to install the plate.
  3. Feb 13, 2021 at 9:26 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Before going with the CMC, post your setup so people can comment if you really need it or not.
    Lift height?
    Which control arms?
    Wheel width, offset?
    Tire size?
    saybng, TRDFerguson and Black Wolf like this.
  4. Feb 14, 2021 at 5:51 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    That’s probably some important information I should have shared, huh?
    • Looking at 2.5-3in of lift
    • Any ball joint UCA, don’t think I want to play around with heims
    • Currently have my eyes on the NV305 for 18s, or 703 for 17s
    • 35x12.5
  5. Feb 14, 2021 at 6:57 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    I'm running 2.75" of lift, 35x12.5s on 8 wide with 50mm offset, aftermarket arms and I do not rub nor do I have the cab mount chop.
    35s fit no issue with proper wheel offset and a good alignment. Ideal wheel offset is about 25mm. Icon makes wheels specifically for fitting 35s.
  6. Feb 14, 2021 at 10:48 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    I think I’ve seen many 18s at +25.
    My ideal look would either be erichudgins build or joonbugs build with the 37s later on
  7. Feb 14, 2021 at 2:18 PM
    ptat
    ptat New Member
    Following. I'm in CT too and currently looking for a shop to do my ReadyLIFT 4/2 and BMC. If I can't find a shop I'll rent out a bay in a DIY garage in Colchester and do it myself. I did my Tacoma and am pretty confident I can do my Tundra too.
    pvn.beluga[OP] likes this.
