Undercover Ultra Flex
Discussion in 'Tonneau Covers, Caps and Shells' started by PonyMan, Feb 7, 2021.
  1. Feb 7, 2021 at 7:20 PM
    PonyMan
    PonyMan [OP] Old Man
    Central, Louisiana
    2021 Tundra CrewMax 4WD Limited Nightshade Special Edition MGM
    Well hell, pulled the damn trigger on one of these for my 2021 CM. Read through a lot of threads on tonneau covers and came to this conclusion. We’ll see how it turns out! LOL
    1rooster likes this.
  2. Feb 13, 2021 at 6:52 PM
    Velocity72
    Velocity72 New Member
    Upstate SC
    2021 Platinum
    Headed in this direction, also. I’ve looked at all of the options. The engineering on this one looks well done. I need the flexibility of using the full bed (minus the 8” at the top) without having to remove a tonneau. I had a Retrax on a former Tundra, and liked it. It leaked at the tailgate like most, but I got tired of the space that the box took up. Let me know how the install goes.
    PonyMan[OP] likes this.
  3. Feb 13, 2021 at 8:26 PM
    PonyMan
    Central, Louisiana
    Installed mine tonight. Went pretty well. I ended up putting the drain tubes just to the side of where they hang from the drain on each rail. There’s already a small hole there from the factory. I took a step bit and drilled the hole out a tad larger, just where the drain hose can be fit through. You have to twist and push through at the same time but I’d rather it not be loose. Keeps it up and out of the way of stuff you may be hauling in the bed so it doesn't get knocked loose or damaged. I can get a pic tomorrow of the drain tube ran through the hole I’m referring to. Here’s the cover installed. So far I’m liking it.
    Also I’m playing around with some TSS vinyl decals for the wheels (you can see them in the same pic). Don’t know if I’m feeling those yet though.
  4. Feb 13, 2021 at 8:33 PM
    PonyMan
    Central, Louisiana
    Better pic of the TSS wheels. They’re not straight, I was just throwing them on there to see if it’s something I want to go with. I’ll cut some more and install them better if I decide I like them.
    hillbillytoyo and Boerseun like this.
  5. Feb 13, 2021 at 8:36 PM
    Velocity72
    Upstate SC
    2021 Platinum
    Looks great. Really low profile and smooth looking.
    The decals are slick!
  6. Feb 14, 2021 at 7:33 AM
    I_Am_Thee_Walrus
    I_Am_Thee_Walrus New Member
    ‘21 Tundra TRD Off-Road
    Those are the best wheels and the decal looks sharp
  7. Feb 14, 2021 at 8:29 AM
    PonyMan
    Central, Louisiana
    Thanks! The decals are growing on me.
  8. Feb 23, 2021 at 3:50 PM
    2021 TRD PRO
    2021 TRD PRO New Member
    Looks great I just ordered the same one today
    PonyMan[QUOTED][OP] likes this.
