Tire Size Q (not will it fit)
Discussion in 'Wheels & Tires' started by timsp8, Feb 13, 2021.
  1. Feb 13, 2021 at 12:08 PM
    timsp8
    timsp8 [OP] Former Tundra owner for 13 years
    NY
    This isn’t a will it fit question. I’m aware of this thread:
    https://www.tundras.com/threads/largest-tire-you-can-run-stock-for-all-generations.9762/
    I currently have Nitto Ridge Grapplers 285/70R18 tires, which have an overall diameter of 33.98” (or 33.7” using a converter) according to their website. However, when I measure with the tape measure they are about 32.5”. That’s a pretty big difference.
    Im looking at new tires, mostly 295/70R18, which are 34.3” or 305/70R18 which are 34.8”. How accurate are these specs or online tire size converters? Does 34.8” drop an inch or more like mine did when mounted? Can someone with those sizes measure your tire with a tape measure for me?
    This is on 18x9 wheels. Tires are around 35-40 psi depending on temp.
  2. Feb 13, 2021 at 12:15 PM
    timsp8
    NY
    NM. I think I found my answer. I can’t find how to delete the thread though.
  3. Feb 13, 2021 at 12:26 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Talk about Covid. :anonymous:
    You can't delete a thread, only a Mod can. You can delete any post of your own, except your initial thread starting one.
  4. Feb 13, 2021 at 12:41 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Cough, cough..
