And the journey continues.. rear shock mount
Discussion in '1st Gen Tundras (2000-2006)' started by allmotor, Feb 13, 2021.
  1. Feb 13, 2021 at 10:27 AM
    allmotor
    allmotor [OP] New Member
    tim
    2000 Tundra Access Cab TRD Limited
    Wheels
    Hey guys still sorting out all the issues with the recent purchase. Found out I'm missing a rear shock and no mounting points to be found.. is there a replacement for this?
  2. Feb 13, 2021 at 10:47 AM
    chunk
    chunk New Member
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
  3. Feb 13, 2021 at 10:49 AM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
  4. Feb 13, 2021 at 10:51 AM
    allmotor
    tim
    Wheels
    Rusted out mounting point. Saw a thread of someone having same issues but looking for parts to fix
  5. Feb 13, 2021 at 10:51 AM
    allmotor
    tim
    Wheels
    Looks like ther "cross" that holds the gas tank too is rusted out
  6. Feb 13, 2021 at 11:08 AM
    TILLY
    Massachusetts
    I'm sure some 1'st Gener's will chime in and help you out if they can.
  7. Feb 13, 2021 at 4:14 PM
    allmotor
    tim
    Wheels
    Took this truck to the dealership... this truck was in indiana... cold weather state... it has an open case for the corrosion frame recall... so they are working with cooperate and the toyota rep to address the recall.. it is in washington state which is not cold weather but the birth of selling was in cold weather state... cross my fingers on an OK outcome..
  8. Feb 13, 2021 at 6:24 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    That would be fantastic if they can pull this under the Recall umbrella..
    Keep us posted...
  9. Feb 13, 2021 at 7:36 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    That cross member is right where I had a big hole in my frame as well. They should replace it.
  10. Mar 6, 2021 at 8:05 PM
    allmotor
    tim
    Wheels
    UPDATE!! Local dealership is replacing my frame!!!!!!! Pulling the cab and drive train.. i'm sending them the 3" lift kit for a free install and LBJ too. I want to do some headers since the cast iron ones "sound" like they are leaking... any recommendations? want to keep the cost low.. used is fine.. I'm so happy with toyota. been a nissan fan boy for 20 years... great service!
  11. Mar 7, 2021 at 4:37 AM
    Are they offering to install headers for free? I thought they would only do that with parts they had to remove anyways. Maybe they will give you a discount if the engine is out.
    I replied to your other thread with some reading for you.
  12. Mar 8, 2021 at 5:23 AM
    Bad Beagle
    Bad Beagle New Member
    2003 Tundra 4.7 extended cab4x4
    Leveling kit
    Good luck with the frame. My 03 has been at a dealership in Muncie IN since 1-11-21. They have NO repair schedule. Toyota has provided me with a 'loaner ' truck,2020 Dodge Laramie 4x4 which is a pretty truck but quite the wussy. I have contacted the Toyota complaint site, customer experience. I have also contacted the recall people that sent me here. Believe me it is a huge runaround .March 5th I escalated my complaint up to the national highway and traffic safety administration.
  13. Mar 8, 2021 at 5:26 AM
    allmotor
    tim
    Wheels
    wow that sounds terrible! Local dealer didn't offer a truck as a loaner..
  14. Mar 8, 2021 at 10:11 AM
    Bad Beagle
    Leveling kit
    They provide loaner "car". What burns me I took it in for a airbag recall. Service tech advised me of the frame recall. Inspected it and found rust damage. Would not let me have my truck back, " by law we have to keep your truck, you can't have it back until fixed ". I am very interested on the rest of your journey.
