Lift/Level
Discussion in 'Suspension' started by AJ5, Jan 18, 2021.
  1. Jan 18, 2021 at 2:46 PM
    AJ5
    AJ5 [OP] New Member
    AJ
    2012 Tundra Crew Max
    A lot
    Hey guys, my truck sits lower in the front as many of your tundra's probably do/did too. How many inches did you guys put in the front to level out your truck? Also, did anyone do a lift and a level? Trying to research some options. My truck definitely needs a level but I was considering a lift as well. I want to see what you guys have to say. Thank you.
  2. Jan 18, 2021 at 2:54 PM
    Blueknights75
    Ron
    Clayton, NC
    Have my billstein 5100s set at top perch which is 2.24 inches of lift in the front. Makes the truck perfectly leveled which is what I was going for since I do not tow anything.
    AJ5[OP] likes this.
  3. Feb 11, 2021 at 7:56 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2" in front is pretty level. A 3/1 lift is also a really common lift/level
    AJ5[QUOTED][OP] likes this.
