RRW Rock Sliders
Discussion in '2.5 Gen Tundras (2014-2021)' started by YotaBro, Jan 14, 2021.
  1. Feb 11, 2021 at 8:53 AM
    #211
    The Patriot 1776
    The Patriot 1776 Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    This is why I haven't altered them yet. If they'd answer my email then I could quit "whining" about it & get to fixing them.
  2. Feb 11, 2021 at 9:09 AM
    #212
    Nickj619
    Nickj619 New Member
    San Jose, ca
    2014 tundra trd crew max
    You guys paid 1k+?!
    Hoologan likes this.
  3. Feb 11, 2021 at 9:11 AM
    #213
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I didn't buy these sliders (and won't) but they're listed on the RRW website at $1200 retail, on sale for $900 for the bare metal version. After taxes and shipping, you'd still be well north of $1k.
    BravoDeltaRomeo likes this.
  4. Feb 11, 2021 at 9:19 AM
    #214
    Nickj619
    Nickj619 New Member
    San Jose, ca
    I paid 825 shipped to me...I would’ve probably went with another brand if I was paying 1000+ To be honest
    300BLK and BravoDeltaRomeo like this.
  5. Feb 11, 2021 at 9:22 AM
    #215
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Was that for the weld-it-yourself kit or the assembled one? Looks like the V4 pre-welded set is $850 before shipping. I was looking at the V1 earlier, which is more comparable to the White Knuckle sliders I ordered.
    saybng and BravoDeltaRomeo like this.
  6. Feb 11, 2021 at 11:04 AM
    #216
    Nickj619
    Nickj619 New Member
    San Jose, ca
    No that was for the v3 sliders but during their sale I ordered on 11/30
  7. Feb 11, 2021 at 3:41 PM
    #217
    MentalBill
    MentalBill Mental in every state.
    Oahu
    2015 Tundra Limited and 2018 Honda Civic
    Back on subject people. Michael from RRW has stated that their engineers has said the sliders are acceptable. I don't remember the exact wordage.
    I have a problem calling them sliders at this point. I bought sliders and got side steps.
    We all (that bought them) have a choice to make....
    IF you keep them do you?
    A. Make them fit your truck? Cut/drill the sliders(steps)
    or
    B. Make your truck fit the sliders(steps)? Cut/drill frame of truck.
    Then are these changes safe?
  8. Feb 11, 2021 at 4:27 PM
    #218
    realprotundra
    realprotundra Always Skeptical
    Gilbert, AZ
    2021 Lunar Rock TRD Pro DC
    Are you rock crawling to the point where you’re going to drop the entire weight of the truck on the slider? If not, you’re fine.
    You also don’t need to cut/drill the frame of the truck. Enough photos have been posted here that it is clear that the slider can be slotted/ground/reamed to the point where it will mate up. Not ideal, shouldn’t have to do that, but you didn’t buy sidesteps. You bought frame mounted rock rails that need some slight modification.
    Backslider likes this.
  9. Feb 11, 2021 at 4:48 PM
    #219
    MentalBill
    Oahu
    Not rock crawling.
    But I am rather fat. Wouldn't want all of my weight to fold the slider(step) down.
    I would like to have more than the sliders(steps) just bolted with 4 bolts only to the side of the frame.
    For the sliders(steps) to sit flush onto the frame you need to cut the bracket to get around the rivet.
    Having the brackets bolted on the bottom of the frame would require drilling the frame. If the sliders(steps) bracket was an inch or two back (maybe it was forward, I forget) this thread would be dead already.
    I didn't buy steps, but that is what I got. By RRW's own description they a sliders.
  10. Feb 11, 2021 at 4:54 PM
    #220
    The Patriot 1776
    '16 TSS CM 4x4
    There’s at least 4 bottom holes of mine that won’t work without drilling the frame. Possibly all 6 bottom holes.
  11. Feb 11, 2021 at 5:00 PM
    #221
    realprotundra
    Gilbert, AZ
    Yeah that’s no good. When I build sliders there is 1 bottom bolt and 2 side bolts for each leg. I do drill the frame though.
  12. Feb 11, 2021 at 5:01 PM
    #222
    realprotundra
    Gilbert, AZ
    With only the 4 side bolts on the frame you aren’t going to hurt anything. You didn’t buy steps. Steps bolt to the body and they still manage to hold fat people up just fine.
  13. Feb 11, 2021 at 5:13 PM
    #223
    Nickj619
    Nickj619 New Member
    San Jose, ca
    Have you looked at installation instructions of other sliders and noticed bolts in the bottom of the frame? I would think most bolt horizontally or wrap the frame. Some you have to get welded to the frame if you want it strong
    MentalBill likes this.
  14. Feb 11, 2021 at 5:18 PM
    #224
    Nickj619
    Nickj619 New Member
    San Jose, ca
    The wkor sliders also bolt horizontally but can’t be drilled into the bottom if desired
  15. Feb 11, 2021 at 5:39 PM
    #225
    The Patriot 1776
    '16 TSS CM 4x4
    I can either drill the frame or weld the bracket to the frame. Both are easily done but both were reasons I bought these particular sliders., they didn’t need either to be done.
    LarryDangerfield likes this.
  16. Feb 11, 2021 at 5:48 PM
    #226
    Backslider
    Backslider Thirsty...
    Tooele, UT
    2022 GMC Sierra AT4 L5P - 2017 4runner SR5P - 2023 Tesla Model 3 LR
    You are not meant to attach any bottom bolts. All bolts are horizontal through the frame.
    The bottom holes should be left open so that liquids can drain should they get inside the frame, which they will.
  17. Feb 11, 2021 at 5:56 PM
    #227
    Backslider
    Tooele, UT
    You got sliders. Assuming they are grade 5 3/8" bolts, each bolt is rated to hold up to 6600lbs. x5 = 330000 lbs. I literally jump on mine.
    The design of the steps is such that an upward force would be absorbed primarily by the bottom and side supports on the slider. Downward force, as if someone was standing on them, is still partially absorbed by the frame attachment brackets. You shouldn't have anything to worry about.
    Nickj619 and BravoDeltaRomeo like this.
  18. Feb 11, 2021 at 6:51 PM
    #228
    The Patriot 1776
    '16 TSS CM 4x4
    There is zero point in having the tabs on the bottom if you don’t put bolts in them. In fact, they make you more likely to hang up on rocks. This isn’t my first set of sliders. I’ve had a set on 3 of my Jeep’s (1 TJ and 2 XJ’s) my LC, my Taco and now my Tundra. I’m not new to off roading and have been rock crawling one rig or another for over 20 years. Somebody who is new to this game might believe you but I don’t so you’re pissing in the wind talking to me about rock sliders.
  19. Feb 11, 2021 at 6:54 PM
    #229
    Backslider
    Tooele, UT
    From an engineering perspective, there is a lot of point. They absorb impact forces.
    I'm not new to engineering. There is zero point in putting bolts through the holes that are there to let water escape.
    Adding bolts is going to make an even more obstructive surface if your concern is getting caught up on rocks.. Unless you use a panhead or countersunk bolt, at which point you are greatly weakening the surface your attaching to..
  20. Feb 11, 2021 at 6:58 PM
    #230
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
  21. Feb 11, 2021 at 7:03 PM
    #231
    The Patriot 1776
    '16 TSS CM 4x4
    An a student of engineering you should clearly see that when the rub tube is on a rock, the force isn’t straight upward but in an arc. That arc force will try to swing the plate that’s against the frame down and out, not up. The bolts on the bottom aren’t the greatest idea but they add much needed strength. I will weld a 1/4” nub of round tubing that the bolt heads will be protected by. Will that hang up? Yep, but not anymore so than they will already. I didn’t get a Tundra to bang in the rocks. I’ll use it for mild rock crawling, logging roads, deer lease work and the like. The sliders also work great for protecting from door dings.
    saybng likes this.
  22. Feb 11, 2021 at 7:04 PM
    #232
    realprotundra
    Gilbert, AZ
    This guy with “20 years of rock crawling experience” thinks you can flush your brakes by changing the fluid in the reservoir over and over....
    This guy thinks bolts though the bottom of the frame on rock sliders don’t do anything....
    I never thought I would miss Tacomaworld!
    TRDFerguson and saybng like this.
  23. Feb 11, 2021 at 7:05 PM
    #233
    Backslider
    Tooele, UT
    :thumbsup:
  24. Feb 11, 2021 at 7:08 PM
    #234
    Backslider
    Tooele, UT
    I didn't say they don't do anything. I said these designs, and most designs for Tundra sliders, do not have upward bolts. His complaint is that the holes don't line up. I'm saying they're not supposed to.
    And yes, if the design is proper the bottom bolts are not at all needed. =D
    I just reviewed several install guides for Tundra sliders, the majority of them aren't using bottom bolts. The ones that do require that you drill the frame. The desire to perform zero drilling/modification is the entire reason this thread exists.
  25. Feb 11, 2021 at 7:12 PM
    #235
    realprotundra
    Gilbert, AZ
    If you’re going to lift the truck by the sliders or will be in a position where the weight of the truck may be dropped on a slider, you MUST have bottom bolts (edit: or some type of wrap around on the bottom of the frame). What companies are selling sliders without bottom bolts (even optional ones) or some sort of bottom wrap around the frame?
    TRDFerguson likes this.
  26. Feb 11, 2021 at 7:15 PM
    #236
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  27. Feb 11, 2021 at 7:15 PM
    #237
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    RRW.Michael was last seen:
    Today (now Yesterday) at 12:36 AM
  28. Feb 12, 2021 at 2:31 PM
    #238
    hinow41
    hinow41 New Member
    Rob
    Anyone get a reply from RRW?
  29. Feb 12, 2021 at 3:06 PM
    #239
    YotaBro
    YotaBro [OP] This forum will make me broke
    Calvin
    FL
    2017 Cement Grey Tundra TRD PRO
    Lots of shenanigans.
    Doesn't sound like it :rofl:
  30. Feb 12, 2021 at 4:15 PM
    #240
    Nickj619
    Nickj619 New Member
    San Jose, ca
    I did, I really didn’t experience bad customer service at all. They refunded me $100 of my purchase price to make up for having to modify the sliders
