Door speaker protection
Discussion in 'Audio & Video' started by jwatt, Feb 7, 2021.
  1. Feb 7, 2021 at 5:48 PM
    jwatt
    jwatt [OP] I heart men
    Jack
    Oregon
    Salsa Red 2007 Tundra DC @91k.
    7" BDS Coilover Suspension Lift/BDS UCAs/XB LED Headlights/Nitto trail Grappler tires on Black Rhyno Armory wheels
    I ve been hearing a busted speaker sound for some time that slowly gotten worse, and today I took off door panels, and found the problem. Water from rain has been dripping onto speaker for some time cause there s a good amount of rust. I remember when first installing these components I tried it with a speaker baffle which was supposed to protect speakers from situations like this, but they made speakers sound like crap. I ended up not using them. Has anyone ran into this, and if so how did you solve it?
    Rica25 likes this.
  2. Feb 7, 2021 at 5:53 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    When I used to install new systems in my own car, I used to buy these 1/2 round plastic shields. They deflected any water that would run down the door channels. They looked kind of like these that are sold by Amazon.
    Darkness likes this.
  3. Feb 7, 2021 at 6:10 PM
    jwatt
    Jack
    Oregon
    You know, when I decided not to use the foam baffles I was thinking of carving them up like the ones you show, but I didn t want to pull out the speakers out again, and reinstall them. In hindsight I should have:annoyed:
    Oh well. Now I have good reason to get those 300 watt Def Bonce mid range woofers I ve been eyeing:D
    Rica25 and Darkness like this.
  4. Feb 7, 2021 at 6:28 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Thats a good idea with those half cutouts. I might have to try that.
    Rica25, Tundyfundy and bleach like this.
  5. Feb 7, 2021 at 6:38 PM
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    Katzkin Leather seats, JRI shocks, Rival aluminum skids, 285/70/17 outpost nat, Berger catch can, icon rear +.5 springs, gator trifold bed cover, Perry parts bump stops, switchback turn signals,
    These are for 6x9’s..they have them for most sizes.
    exact reason I purchased them
    Rica25 likes this.
  6. Feb 9, 2021 at 12:50 PM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    Make our own. Go to Home Depot and buy a black grate. Cut the center grille off and cut it in half. Install to speaker adapter.
    aparker813, Rica25, PWMDMD and 3 others like this.
  7. Feb 10, 2021 at 8:30 PM
    jwatt
    Jack
    Oregon
    Nice!
    Rica25 and Tundyfundy like this.
  8. Feb 10, 2021 at 9:04 PM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    2015 Platinum Super White Crewmax 4X4
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    XTC baffles work well.
    MTRock and Rica25 like this.
  9. Feb 10, 2021 at 9:06 PM
    jwatt
    Jack
    Oregon
    Are those Tech12volt adapters?
    Rica25 likes this.
  10. Feb 10, 2021 at 9:10 PM
    aresenalgunner007
    aresenalgunner007 New Member
    San Diego
    2019 Black TRD PRO
    BFG KO2’s
    I used this and cut a half circle out of the back for airflow and it sounds awesome. Before that water would drip and it corroded the speaker wire.
    MTRock, Rica25 and 1lowlife like this.
  11. Feb 10, 2021 at 9:22 PM
    jwatt
    Jack
    Oregon
    Yea. I tried baffles before, and it took a whole lot of bass away. I ended up not using them. I think they provide too small of an enclosure. Running them free air in the door sounded great, but now I need to rig something up to keep the rain water off of them. Maybe some foil backed deadener stratigically placed above the speaker:monocle:
    619Tundra likes this.
  12. Feb 10, 2021 at 9:27 PM
    aresenalgunner007
    San Diego
    2019 Black TRD PRO
    BFG KO2’s
    Did you cut the backs out? I can imagine having it sealed mostly would do that, but after cutting them and just leaving the top and maybe less than half of the back on, it made the bass tighter and the mids sound much better. I have two 10tw3s so I let that take care of most of the lower frequencies anyways.
    Rica25 likes this.
  13. Feb 10, 2021 at 9:30 PM
    Rica25
    Ricardo
    Tulare
    I have the same issue
  14. Feb 10, 2021 at 9:32 PM
    jwatt
    Jack
    Oregon
    No. I did think about cutting out the back, but I didn t want to pull the speakers out again to reinstall baffels. I just left them without anything. I think deadner will work though. I still have plenty of that, so I won t have to buy baffles.
    Rica25 likes this.
  15. Feb 10, 2021 at 9:42 PM
    aresenalgunner007
    San Diego
    2019 Black TRD PRO
    BFG KO2’s
    I put that kilmat inside and out and did the baffles after because water was getting in there and actually caused the speaker to stop working because the wire corroded so much. That’s the reason I did the baffle and it was a bonus with the added sound quality. It was cheap and well worth it. Deadening won’t stop the water.
    Rica25 likes this.
  16. Feb 10, 2021 at 9:53 PM
    jwatt
    Jack
    Oregon
    What I mean by using deadner is to adhere it above the speaker like a roof. If it does drip down in that area the foil backed deadener will divert it away from the speaker.
  17. Feb 10, 2021 at 10:02 PM
    aresenalgunner007
    San Diego
    2019 Black TRD PRO
    BFG KO2’s
    Gotcha. You can never have enough deadener. Even after I installed the baffle I put more deadener around the outside of the speaker mount all the way around haha.
    Rica25 likes this.
  18. Feb 10, 2021 at 10:41 PM
    TXTundra2722
    2015 Black Tundra
    This seems like a perfect time for the OP to upgrade speakers!
    619Tundra and Rica25 like this.
  19. Feb 11, 2021 at 5:30 AM
    619Tundra
    No. These are from a company from Texas. TT. They have some crappy service and are not allowed to mention their name on this site. I routered the back to create a chamfer. This is very important.
    Rica25 likes this.
  20. Feb 11, 2021 at 5:37 AM
    619Tundra
    I can only imagine how this speaker sounds. It's a shame you are killing sound. Do not use a speaker gasket thicker than 1/16 between the Driver and mounting bracket. Secondly, don't block the back of the driver by using this baffle. You are creating distortion.
    Rica25 likes this.
  21. Feb 11, 2021 at 1:58 PM
    jwatt
    Jack
    Oregon
    Was thinking the same thing. I would really like to get the speakers out of the doors, and mount them inside some where. There s not much in the way of locations in front though.
    Rica25 likes this.
