Best 295/70
Discussion in 'Wheels & Tires' started by TheBubbaDude, Feb 11, 2021.
  1. Feb 11, 2021 at 12:55 PM
    Badknees
    Badknees New Member
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    One of the few trucks that still looks good even with the Michelin tires :D
  2. Feb 11, 2021 at 1:03 PM
    TheBubbaDude
    TheBubbaDude [OP] New Member
    2020 Tundra TRD Pro
    AJT Blackout Kit 1.25" Wheel Spacers NRG 285/70/18 Meso Customs TRD Start Button
    Very much not complaining but I have to admit the spacers give it something it lacked for sure. I think, if my math is correct, that the 295/70 is going to basically give me the same stance if I take the spacers out. My biggest concern is any trimming. But from what I've read around here, the front flap is the only trimming most have done. I do have plans to do a level lift, but it might be a minute before I have time to do that
  3. Feb 11, 2021 at 1:14 PM
    Badknees
    Badknees New Member
    Even though mine isn't a Pro, I basically have the same truck as you. You should already be close to level, although some like a little rake so you might want to check out the Coach Builder +2, which I think is a great shackle and will provide about 1.25" of lift (They also have a +1 and +3). You already have extended length Fox shocks in the rear, so an inch or so lift won't hurt. Also, I know CB sells a Pro kit too, which includes a lot of "stuff" to put your Pro on steroids! For the 295s and 1.25" spacer, I had to trim the skid plate - but if you have the TRD skid that won't be necessary. Also, I removed the front flap and used a heat gun to shape the fender well about 1/2" toward the bumper. This work may not even be needed if you don't use the spacers. However, it's hard to know how much rubbing until you install as each truck/tire is a little different.
  4. Feb 11, 2021 at 1:22 PM
    TheBubbaDude
    2020 Tundra TRD Pro
    I had planned on the 295s since day one, and from reading the forums, found out about the front flap so that came off the day I installed the spacers. I recall another user from the area who had installed the 295 Terra Grapplers and said that he had some minor heat-gun work but also had 1.25 spacers and rubbing wasn't a terrible issue. However, I can't disagree a bit about each vehicle being different. I may pull the trigger with the 295s and see where it goes from there.
    The TRD does have a slight rake, but it also comes stock with a 2" lift. I really like the height now and the 295s will give me another 2" , so I'm not sure, aside from shims on the front end, that much more would be necessary.
    Badknees[QUOTED] likes this.
  5. Feb 11, 2021 at 1:26 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    295/70 Michelin Defender LT....
  6. Feb 11, 2021 at 1:34 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Price, reviews and the snowflake rating.
  7. Feb 11, 2021 at 1:48 PM
    My 285/70's were $330 per tire.
    TheBubbaDude[OP] likes this.
  8. Feb 11, 2021 at 1:54 PM
    Salt1972
    Salt1972 New Member
    Knoxville, TN
    2017 Tundra Crew Max Platinum
    I'm new to the Tundra / forum, but have Nitto Terra Grapplers G2's on 2 Jeep Wranglers and love those tires.
    Terndrerrr and Dc2015 like this.
  9. Feb 11, 2021 at 2:00 PM
    TheBubbaDude
    2020 Tundra TRD Pro
    From what I've found in my research, the 285s are across the board more expensive than the 295s... Whodathunkit
  10. Feb 11, 2021 at 2:09 PM
    Badknees
    Badknees New Member
    Think the higher prices reflect fewer players in this size market...
  11. Feb 11, 2021 at 2:22 PM
    TheBeast
    TheBeast The Beach
    Falken wildpeaks, Toyo at2/3, bfg KO2 , nitto RG
  12. Feb 11, 2021 at 2:30 PM
    TheBubbaDude
    2020 Tundra TRD Pro
    Agreed...
    You sold me on the Coopers. After a long discussion with Discount Tire, decided to run with them and should be here next week
  13. Feb 11, 2021 at 3:10 PM
    Badknees
    Badknees New Member
    Good luck and please send us some pics and update your results once you’re done. I’d like to see these on your truck to see how good these look on the TRD Pro wheels...I’m sure they will look great.
  14. Feb 14, 2021 at 8:54 AM
    HighonFirewood
    HighonFirewood Everything can be fixed with a hammer.
    Stage Left. Colorado
    2019 Tundra
    toyofan87 likes this.
  15. Feb 14, 2021 at 8:56 AM
    HighonFirewood
    2019 Tundra
    Just read till the end and saw you got coopers already
  16. Feb 14, 2021 at 10:15 AM
    CTB Mike
    CTB Mike It's RED? My rods and cones must be screwed up!
    Southern Arizona
    2011 Red Rock Warrior
    +1 on the Defenders. Very quiet, good traction. I also had them on my 2008 4Runner. Love them!
  17. Feb 14, 2021 at 9:44 PM
    Rodtheviking
    Vancouver, WA
    Sequoia
    I saw that, thank you. I am watching the 295's and they are at 244 each right now.
  18. Feb 15, 2021 at 3:16 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Falkens Wild Peaks AT3 are solid and true.
  19. Feb 15, 2021 at 4:55 AM
    Bigbird57
    Bigbird57 New Member
    I want the Toyo Open Country R/T
  20. Feb 15, 2021 at 5:14 AM
    #50
    HighonFirewood
    2019 Tundra
    Just saw $227 this morning. Damn!
  21. Feb 15, 2021 at 6:23 AM
    #51
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Those were incredible on my old 4Runner. E load. I got 50k miles out of them with no issues. Tread still looked good when I traded it in.
  22. Feb 15, 2021 at 7:49 AM
    #52
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    I’m guessing proper alignment and rotations are very important for this tire. I’ve heard lots of lifted trucks and Jeep’s driving next to me with screaming loud tires and when we get to the next red light, they have been the Ridge Grapplers many times.
  23. Feb 16, 2021 at 7:15 AM
    #53
    Bigbird57
    That would save$400 per set over theR/T's
  24. Feb 22, 2021 at 9:33 AM
    #54
    tbutler
    tbutler Team Toyota
    2021 Land Cruiser HE - Black
    Are those tire the Michelin LTX AT2s? If so, how are you liking them in the larger size?
  25. Feb 22, 2021 at 10:01 AM
    #55
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    They are not AT2s, they are Michelin Defender LTX M/S. Really liking it.
    Saltyhero13 likes this.
  26. Feb 22, 2021 at 10:06 AM
    #56
    tbutler
    tbutler Team Toyota
    Thank you! I appreciate the reply and recommendation.
  27. Feb 22, 2021 at 11:44 AM
    #57
    Dc2015
    Dc2015 New Member
    Danny
    2020 limited
    I love my Nitto Terra super quiet and a great ride
  28. Oct 26, 2023 at 7:32 AM
    #58
    txtundra311
    txtundra311 New Member
    Any clearance or rubbing issues with Michelin defenders in 295/70/18?
  29. Oct 26, 2023 at 11:30 AM
    #59
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Not with my lift. :)
    txtundra311[QUOTED] likes this.
  30. Oct 27, 2023 at 5:40 AM
    #60
    txtundra311
    I’m on a stock trd pro, what lift modifications do you have?
