How many of you DON'T have leaking cam towers?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Sumo91, Dec 17, 2020.
Does your cam tower leak?
  1. Yes, my cam towers leak
    25 vote(s)
    9.5%
  2. No, my cam towers don't leak
    238 vote(s)
    90.5%
  1. Jan 2, 2021 at 3:25 PM
    #61
    ffej50
    ffej50 New Member
    14 5.7 FFV 116k no leaks
  2. Jan 2, 2021 at 3:31 PM
    #62
    J.A.T.O.
    J.A.T.O. New Member
    Hawaii
    2013 Tundra SR5 Crewmax 4x4
    Bud Built skid plates, Fox TRD Pro suspension, Nitto terra grapplers
    My 2013 started leaking at 95k. It stopped when i switched back to oem Toyota oil from mobil 1 synthetic. My engine got quieter also. Don't ask me why lol!
    Sumo91[OP] likes this.
  3. Jan 2, 2021 at 5:09 PM
    #63
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    2018 5.7 CM with 22k on the clock and no cam tower leak so far..... Hopefully it will stay that way.
  4. Feb 10, 2021 at 11:33 AM
    #64
    turkeycreek29010
    turkeycreek29010 New Member
    Chuck
    Bishopville SC
    2019 Cement Tundra Crew Max
    3/1 Level Kit, 20 inch Gear Wheel, 285/65/20 BFG
    Looks like I may have just joined the club. 2019 with 18,800 miles
  5. Feb 10, 2021 at 5:49 PM
    #65
    Nighthawk
    Nighthawk New Member
    Keith
    Frederick Md.
    2018 Tundra Limited crewmax
    linex bed Truxedo Pro F-15 Tonneau,Weathertech mats,TRD exhaust,Matt Geckco bed lights,hood light,shorty antenna, all LED lights inside, Fomoto oil drain valve,
    3 yrs old 28,000 no cam tower leaks. I do have a rear diff. Sipage. They clean off and hasn’t come back.
  6. Feb 10, 2021 at 6:03 PM
    #66
    14 with 119K. Still no cam tower issue...
  7. Feb 10, 2021 at 6:15 PM
    #67
    LuvniForce
    LuvniForce New Member
    2008 Silver Crewmax 2wd ARE topper
    Ok, so I know quite a bit about these trucks... but what is a cam tower? I’ve never heard of such? Is it a different word for valve cover gasket?
  8. Feb 10, 2021 at 6:20 PM
    #68
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Its the gasket below the V/C, against the block. Its basically a cradle assembly that holds the cams in place.
    LuvniForce[QUOTED] likes this.
  9. Feb 10, 2021 at 6:22 PM
    #69
    LuvniForce
    I’ll look tomorrow in the daylight and let y’all know. Thanks!
    TILLY and Black Wolf like this.
  10. Feb 10, 2021 at 6:25 PM
    #70
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    56k all good!
    Sumo91[OP] and Black Wolf like this.
  11. Feb 10, 2021 at 6:30 PM
    #71
    socaltundra951
    socaltundra951 Gentlemen Prefer Black Tundras
    Southern California
    Black CrewMax 5.7
    '14, 5.7, 62k and so far so good. :fingerscrossed:
  12. Feb 11, 2021 at 8:29 AM
    #72
    LuvniForce
    2008 with 132k. Engine clean as whistle, DOHC heads so big I didn’t see the exact “cam towers” but I’ve been under the truck a couple times and she clean still.
  13. Feb 11, 2021 at 8:29 AM
    #73
    LuvniForce
    Oh I forgot, mine is the 5.7
  14. Feb 11, 2021 at 8:46 AM
    #74
    NWPirate
    Zach
    WA
    You can't necessarily see any leaks from underneath. Look through your wheel well towards the back of the engine.
    This was my leak that got fixed @18k.
    HulkSmurf14 likes this.
  15. Feb 11, 2021 at 11:33 AM
    #75
    turkeycreek29010
    Chuck
    Bishopville SC
    So I ran mine to the dealership @ lunch today. Confirmed leak on the drivers side. They also found that the rear main seal was also leaking. Not real happy right now.
  16. Feb 11, 2021 at 11:39 AM
    #76
    LuvniForce
    Oh goodness, you guys are making me jumpy now! lol, I’m going to have pull it back in my shop and look things over more thoroughly....
  17. Feb 11, 2021 at 11:41 AM
    #77
    LuvniForce
    Toyota tech balanced wheels and had him look under it while he had it in the air, and he never said anything. But it was a somewhat less experienced guy. Jace (my Toyota tech) is a pro and he was out sick that day....
  18. Feb 11, 2021 at 11:48 AM
    #78
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Right at 80,000 on my 2018 now and no leaks.
  19. Feb 11, 2021 at 11:58 AM
    #79
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    Nothing here. Gave both sides a good inspection last week while I was working on brakes
    2015 80k
    Sumo91[OP] and LuvniForce like this.
  20. Feb 11, 2021 at 12:14 PM
    #80
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    At least you're still under warranty...same deal on my side...confirmed I'm out of warranty and "give a sh!t" from Papa Toyota
  21. Feb 11, 2021 at 1:22 PM
    #81
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    Is there a holy grail of number of miles or years one could get to safely say their truck won’t be impacted?
  22. Feb 11, 2021 at 1:51 PM
    #82
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    Mine had a leaking cam tower around 30k miles. It was repaired by Toyota and has not leaked for about 35k miles. The process for them to diagnose and repair was one big headache. I went into the dealership telling them that it was my cam tower (because of helpful people on this forum) and their response was "you can't trust internet diagnostics". After multiple trips where they replaced my valve cover gasket a couple times, they admitted it was my cam tower. It was a sh*&show.
    Fotnot and NWPirate like this.
  23. Feb 19, 2021 at 8:53 PM
    #83
    WesternFlyer
    WesternFlyer New Member
    2019 4x4 CrewMax, SR5, TSS
    No leaks so far on my 2019 with about 22k on it. My 2009 had 190,000-ish on it when I traded it and no leaks.
    TheBeast likes this.
  24. Feb 22, 2021 at 6:42 PM
    #84
    db52282
    db52282 New Member
    Georgia
    2017 Silver Tundra Limited
    110,000 miles on my 2017 and no leaks.
  25. Feb 23, 2021 at 5:00 AM
    #85
    Dano50
    Dano50 New Member
    2020 Tundra Crew Max Platinum - Silver Sky Metallic
    2020 CM Plat 4x4 - 16,353 miles - knock on wood no leaks.
  26. Mar 4, 2021 at 4:55 PM
    #86
    ohmyheck
    ohmyheck New Member
    2016 DC SR 5 w/ sweet valve stems
    Driver side handle, Shift knob, sway bar tonneau cover, leveled, 2018 OEM fogs, 275/70 KO 2's and sweet valvestems
    2016 5.7 36k miles dealer confirmed NO LEAKS
  27. Mar 4, 2021 at 4:57 PM
    #87
    @ 120K now. Still no leaks. Dry as a bone.
  28. Mar 5, 2021 at 4:19 AM
    #88
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    Still have my fingers crossed, but my 2019 with a tad over 40,000 miles on the clock is still bone dry on both sides.
  29. Mar 5, 2021 at 4:28 AM
    #89
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    I haven't looked. Ignorance is bliss.
    Tyman and Roborob70 like this.
  30. Apr 9, 2021 at 6:44 PM
    #90
    Glennjc1978
    Glennjc1978 New Member
    Glenn
    2021 trd pro lunar rock
    2016 limited 64k no leaks so far
