What on earth did I miss??
Discussion in 'Suspension' started by fisherman951, Feb 10, 2021.
  1. Feb 10, 2021 at 8:15 PM
    fisherman951
    fisherman951 [OP] MT dreams
    Tony
    2017 crewmax 4x4
    Soo some one on Facebook is selling this?? Rear shocks with springs?? What on earth is this or did I miss? Never seen such a thing. Am I the only one?
    Ryuu and Rica25 like this.
  2. Feb 10, 2021 at 8:22 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    This was obviously invented to eliminate the dreaded bed bounce, and make it into a more tolerable and superior bed launch.
  3. Feb 10, 2021 at 8:35 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Just methin around
  4. Feb 10, 2021 at 9:06 PM
    TILLY
    Massachusetts
    On a side note, wearing dishwashing gloves while working on a truck makes me think this might be some sort of prank.
  5. Feb 10, 2021 at 9:13 PM
    ricky_spanish
    ricky_spanish New Member
    Commerce, Ga
    2020 Tundra SX
    I was literally just looking on craigslist for an a pillar grab handle and found a listing for these.
  6. Feb 10, 2021 at 9:47 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    There is a tundra ive seen driving in Huntington with this exact setup. I had to double take when i saw it. Maybe it helps add carrying capacity?
    i would want to reinforce the shock mounts though adding a spring is a lot more resistance on them
  7. Feb 10, 2021 at 10:58 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    It’s very Dodge-y.
    Never mind I’ll see myself out.
    landphil, Hbjeff, GODZILLA and 2 others like this.
  8. Feb 10, 2021 at 11:30 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
  9. Feb 11, 2021 at 10:43 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    coil over shocks- Been around a long time, not seen one in years. They used to be much more popular back in the 70s/80s. Back then I saw them used on everything from VW Bugs/Buggies, to 4wds to musclecars. It was back in the day when air shocks were popular, as was the JC Whitney catalog! Coil overs gave some added support but didnt ride like a brick like air shocks did.
    I actually ran them on a 72 Nova. The Novas had weak rear springs already. When I needed to replace the shocks I installed some coil over shocks and presto- the added support eliminated the rear sag I had (likely from hard launches and driving like the Dukes) and gave a great stance and improved drive-ability of the car.
  10. Feb 11, 2021 at 10:47 AM
    fisherman951
    Tony
    2017 crewmax 4x4
    I figured it was some
    Tundyfundy likes this.
