Hide-a-Key ?
Discussion in '1st Gen Tundras (2000-2006)' started by HBTundra, Feb 10, 2021.
  1. Feb 10, 2021 at 9:00 AM
    HBTundra
    HBTundra [OP] New Member
    2006 DC 2wd
    I've had magnet ones rust-out / fall.
    Tried heavy duty zip-ties wear away and fail also.
    Thinking about using some stainless steel 'tie-wire'.
    What say you?
  2. Feb 10, 2021 at 9:16 AM
    speedtre
    speedtre New Member
    Inland Northwest
    I've got one of these and store a flip-key remote in it. I'm not the weakest or strongest person out there, but this thing is not easy to get off the frame rail. It's virtually impossible for it to fall off accidentally. It's very stout and well-made. I would recommend it for sure.
    https://www.ebay.com/itm/Magnetic-Hide-A-Key-Fob-Waterproof-Magnet-Stash-Box-Under-Vehicle-GPS-Holder/282309033775?ssPageName=STRK%3AMEBIDX%3AIT
  3. Feb 10, 2021 at 11:21 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    I bought one of the cheap magnetic ones they sell in the grocery store on that one section of the aisle where they have random stuff like a tire pressure gauge, air freshener, etc. It's lasted 14 years on 3 different trucks.
  4. Feb 10, 2021 at 11:27 AM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    05 DC SR5 / 06 SEQUOIA LTD
    I have an old one as well that is at least 8 years old, probably older. No issues with it. Just put it in a good spot where you aren't just relying on just the magnet to hold it. Like inside frame rail.
    Suppose wire tying it up somewhere where would work as well. But the key would be more exposed...
    HBTundra[OP] likes this.
  5. Feb 10, 2021 at 11:37 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Get a carabiner clip and find a hole in the frame to clip it on. I had a spare house key clipped above a rear fender for years. Reminds me I should get a spare house key for my current house.
    They only cost a few bucks.
  6. Feb 10, 2021 at 11:47 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    My last truck had a spare key in a ziplock bag duck taped around the outer tie-rod. It had to have been there for at least 5-7 years.
  7. Feb 10, 2021 at 12:03 PM
    CourtJester
    CourtJester New Member
    Alabama
    2019 Tundra TRD Pro, 2015 Tacoma
    I have one taped to the bed under my bedrug.
    One of the very few things I miss about my F-150 is the key pad to unlock the doors.
    FrenchToasty and xdmelarton like this.
  8. Feb 10, 2021 at 2:01 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I had a 96 exploder with that. 3-7-9-5-1 was the code, so easy to remember because of the pattern. That was a nice feature but I wished it was more discreet. A plastic number pad looks funny when you shaved your badges for the clean look.
    CourtJester[QUOTED] likes this.
  9. Feb 10, 2021 at 2:12 PM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    The key I have under my 2016 does not have a chip so it only unlocks the door. My ignition spare is hidden inside the truck.
    BravoDeltaRomeo and Aggieddad02 like this.
  10. Feb 10, 2021 at 3:08 PM
    Professional Hand Model
    Fred
    Hand Protectors
    My Hide a Key is going on 25 Years. :bananadance:
    Schcoman and Sunnier like this.
  11. Feb 10, 2021 at 3:16 PM
    SMILE
    SMILE Drink, Smoke, and Smile!
    SOUTHEAST PA
    2016 TUNDRA CREWMAX SR5 5.7L V8
    Weather tech mats, to be continued.........
    I duct tape a door only key (no chip) to the back of my license plate. Make sure to use flat head screws so you can use a quarter to unscrew it in a situation.
    jerryallday likes this.
  12. Feb 10, 2021 at 4:04 PM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    I have a copy of my key in my wallet, it comes in handy when you have a pop lock installed in your tailgate and bed cover.
  13. Feb 10, 2021 at 4:14 PM
    Gman8P0W1
    Gman8P0W1 New Member
    Utah
    21 Lunar Pro
    ADD Venom w/Rigid 30” AT Overland Summit KMC: 315/70/17 KO2
    Sampson, Darkness and HBTundra[OP] like this.
  14. Feb 10, 2021 at 5:16 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
  15. Feb 10, 2021 at 5:44 PM
    Nick T
    Nick T New Member
    Use a trimax hitchlock if you have the bike rack on, in either case tape your key inside the hitch
    https://www.amazon.com/Trimax-MAG200-Resettable-Combination-Receiver/dp/B000W0OFXG
  16. Feb 10, 2021 at 5:47 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    How often are you guys needing to use this hidden key?
    In my 30y of owning a vehicle, I've never locked myself out or lost a key when I wasn't at home, where my second key is already located.
  17. Feb 10, 2021 at 5:48 PM
    There was no key, but when I did bumper work I found a screw holding a clamp, that encompassed a key ring; back near the rear crossmember.
  18. Feb 10, 2021 at 6:16 PM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    I just use steel wire and tuck the key up somewhere
  19. Feb 11, 2021 at 3:48 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    I think the problem is where/how you're putting it. Like others have said, I have a cheap plastic/magnetic hide-a-key box that's lasted for three vehicles and still going strong through Maine winters. I can't imagine a zip tie ever failing to hold a key unless it's attached to the driveshaft. :rofl:
  20. Feb 11, 2021 at 4:37 AM
    Fred
    Hand Protectors
    270Fan, Darkness, jimf909 and 4 others like this.
  21. Feb 11, 2021 at 4:41 AM
    speedtre
    speedtre New Member
    Inland Northwest
    Used mine last week.....I left my truck somewhere then when I went back to get it, I forgot my keys. No problem, just grabbed the spare....:thumbsup:
    Can't remember the last time before that though, and I've been using one for at least 15 years.
  22. Feb 11, 2021 at 6:40 AM
    HBTundra
    2006 DC 2wd
    One situation I saw happen, was a friends boat had broken down a long way from the launch ramp on the Colorado River. He had cell service and someone willing to drive his truck/trailer down to pick him up, but no key to the truck . . . so someone had to tow him all the way back to the launch ramp.
    Darkness likes this.
  23. Feb 11, 2021 at 7:22 AM
    Cheapy magnetic key holder stuffed way up inside the space between my toolbox and inner bedside. Not visible, not exposed to any water or potential damage. Used a couple of times, mostly out of laziness so I didn't have to go back in the house and find my keys to get something out of my truck.
    Pucks18 and HBTundra[OP] like this.
  24. Feb 12, 2021 at 7:26 AM
    I have one of these tucked up safely under the truck but this thread inspired me to get another key made. I only have 2, and it leaves my wife without a copy. I didn't realize how inexpensive it would be. A local shop will make me a new one for $5.95.
    Darkness, Kimosabe and HBTundra[OP] like this.
  25. Feb 12, 2021 at 11:33 AM
    Pucks18
    Exactly, I have 3 spares for my truck, only 15 bucks, whereas if u had one of these new age toyotas I bet you'd need a dealer key with their dumb micro chips
  26. Feb 12, 2021 at 12:38 PM
    RR60
    RR60 New Member
    2003 SR5 Tundra long bed
    After I had my truck for a few years I actually found one.
    I was running my hand along the inside of the bed rail and felt something. Turns out the old owner had one of the key cases under there.
    I had done a lot of work on the truck and never noticed it before. Even had the LineX spray on bedliner installed. They never noticed it either. Since they had sprayed right over it with the spray on bedliner.
  27. Feb 12, 2021 at 12:43 PM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    same thing here but rest assure we both are going to have it happen this week after professing our clean records. lol
  28. Feb 12, 2021 at 12:48 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    If I do, I'm creating a new screen name and I'll start a thread asking for suggestions of how to hide a key on my truck ...then you'll never see that member again. :anonymous:
  29. Aug 12, 2021 at 6:35 AM
    clarkritchie
    clarkritchie New Member
    Is the Hitch Safe meant to be left installed, or only installed when needed?
    I recently got one (it's a clever design), and I am quite certain I had it installed correctly, however, I still managed to lose one of the two pins within the first few hundred miles or so. So now replacement pins are on order. I'm glad I did not lose the entire thing! Needless to say, this rattled my confidence in the product some.
    Being able to stash a key like that is incredibly handy for how I use my truck. I would prefer to leave it in and only remove it when towing.
  30. Aug 12, 2021 at 6:54 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I have one of the cheapo ones like alot of guys on here. I JB welded it on the inside "C" of the frame rail channel when i installed my sliders.
