  1. Feb 10, 2021 at 10:36 AM
    Tundra Bob
    Tundra Bob New Member
    Bob
    Western PA
    2018 Tundra SR5 Doublecab MGM 4x4
    Havoc HS3 Polished Hoop Steps , bed liner , bed rails, mud flaps , all weather mats
    Holding up great . Looks the same as new .
    SimpleMan[QUOTED] likes this.
  2. Feb 10, 2021 at 10:57 AM
    CorsoTundra
    CorsoTundra This is the way
    North GA
    2021 Cement Trail Edition
    Toytec Aluma 3/1.5, Pro headlights, OEM LED fog lights, AJT chrome delete, interior/exterior LEDs, front TRD sway, 18x9 Method Roosts, 285/75/18 Toyo A/T 3, RCI engine skid,
    Ordered the RCI transmission skid this morning. It just shipped. Love that lead time.
  3. Feb 10, 2021 at 11:09 AM
    RobertD
    Robert
    DFW, Texas
    It's the small things in life.
    Came across some of the threads for changing your start up image and couldn't pass up the chance.
  4. Feb 10, 2021 at 11:11 AM
    SAGE63
    San Diego County
    Thanks
    new to thid how do you PM...
    CappyKD[QUOTED] likes this.
  5. Feb 10, 2021 at 11:14 AM
    Click on start a conversation to whoever you want to send it to.
    CappyKD likes this.
  6. Feb 10, 2021 at 11:19 AM
    SAGE63
    San Diego County
    thanks I figured it out... easy to miss lol
    CappyKD likes this.
  7. Feb 10, 2021 at 11:49 AM
    jefroshm0
    jefroshm0 New Member
    Elk Grove, CA
    2018 Cement Tundra Crew 4x4 SR5
    My 3D printed switch adapter came in. Installation took less than 20 min counting the cutting and drilling. The guy included a template to help guide your cuts and drill locations. Good product and fit like a glove in that useless business card slot.
    Relocating the rear window switch, the front/rear camera switch, and compressor switch this weekend (I hope).
  8. Feb 10, 2021 at 11:59 AM
    SimpleMan
    SimpleMan New Member
    Chuck
    2021 SR5 TRD OR 4x4
    Diamondback HD
    Installed new Toyo Open Country AT3's. Headed on a trip from Western WA through ID, MT, WY, UT, & OR over the next week. It will be a great test of the tires for highway snow & ice driving.
  9. Feb 10, 2021 at 12:00 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Based on your pictures, you'll need to open up that hole in the business card slot a bit for your switches to fully clear. But looks good!
    If you want to doll it up to get rid of the print lines, then here's how I did mine:
    1. Wet sand the top with 220 grit on a flat surface to just remove the printer lines,
    2. Wet sand again with 320 grit to remove the 220 grit lines
    3. Thoroughly dry after rinsing the wet sand slurry off
    4. Three coats of high-build primer (follow the directions on the can) - SEM or Duplicolor High-Build primers work great
    5. Lightly wet sand with 320 grit just to remove any rough spots or globs from the primer (the high build stuff can sometimes sputter)
    6. Thoroughly dry after rinsing the wet sand slurry off
    7. Three to five coats of bumper/trim paint (follow directions on can) - SEM or Duplicolor trim/bumper paint
    8. Let fully dry/cure before assembly
  10. Feb 10, 2021 at 12:25 PM
    CappyKD
    CappyKD New Member
    Kirk
    2025 Limited 4x4 TRD Off Road CC 6.5 Lunar Rock
    I see you figured it out! Replied.
  11. Feb 10, 2021 at 12:38 PM
    Sean492
    Sean492 New Member
    Winston Salem, NC
    2018 MGM Tundra Sport
    Go ahead and put it on. It'll motivate you to get the rims done.
  12. Feb 10, 2021 at 1:08 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    They block a couple inches from the top, but it’s not really noticeable. They do look slick as hell on the truck, but the fitment was just plain bad. They’ve settled a bit now and the drivers window opens and closes but it’s so close to catching. I hope a summer of it being outside fixes all.
  13. Feb 10, 2021 at 1:19 PM
    tundraatx
    tundraatx 2008 Limited Double Cab, 5.7L
    Austin, TX
    1) Bought with 225k miles on it, a Westin bullnose bumper, and OEM tundra steps 2) Current Mileage 238k Mods: 1) Dirty Deeds BA Mufflers 8 inch with resonator (as of Feb 2021) - Had the 10 inch with resonator - Prefer the 10 inch without resonator - deeper sound hear it more in the cab 2.) Ranch Hand Summit Front Bumper/Guard 3) Ranch Hand Summit Bumper 4) Billstein 5100s all around 5) TRD front and rear sway bars 6.) Rough Country wheel to wheel steps 7) Pioneer 8400 NEX Wireless ApplePlay 8) Backup Camera: e-raptor 9) LED white lights replaced in headlights, fog lights, inside cabin, and exterior lights 10) Linex (unbranded by Central Texas Truck Coatings) 11) OEM Toyota side panels and generic panel on tailgate Maintenance/Repairs: 1) Valve covers, belt tensioner, alternator belt - $415 2) Evaporation fuel canister and filter replacment $1547 *This was a Toyota TSB for 07-08 AFAIK. Toyota covered in first 3 years of ownership. Mine failed after 13 years of daily regular driving use. Not bad at all. 3) Pioneer Unit - had to ship to Pioneer to replace Output IC - $45 (shipping) free under 1 year warranty fix 4) Pioneer Unit - Electrical feed back coming through speakers when accelerating. Fix was to check all wiring/tighten up/ make connections good again $42. 5.) Rear passenger door actuator replaced. Part was $287 with tax on ebay from Toyota dealer free shipping. 6.) Rack and Pinion, tow mirrors, shocks install, lifetime alignment - $1884.36
    Did you notice the sound being fuller snd throatier after exhaust tip install?
  14. Feb 10, 2021 at 2:02 PM
    jfcampbell485
    jfcampbell485 New Member
    2018 MGM SR5 CM TRD OR
    Do you have a link?
  15. Feb 10, 2021 at 4:15 PM
    manhster
    manhster New Member
    Richmond, VA
    '17 Black CM 4x4 Ltd TRD OR
    @RyRy1Thx for the help
    RyRy12, Jcmf52, Fotnot and 3 others like this.
  16. Feb 10, 2021 at 4:29 PM
    HighonFirewood
    HighonFirewood Everything can be fixed with a hammer.
    Stage Left. Colorado
    2019 Tundra
    Cheap and
    Where did you get the switch panel? I need two more spots and I’m out of space on the dash...looks perfect
    Rocfrog likes this.
  17. Feb 10, 2021 at 4:30 PM
    HighonFirewood
    2019 Tundra
  18. Feb 10, 2021 at 5:03 PM
    jefroshm0
    Elk Grove, CA
    Here is his Facebook business page. He communicates through FB messenger, and maybe his email. Very nice guy and very easy to buy from. Uses PayPal for payments.
  19. Feb 10, 2021 at 5:14 PM
    I have the same setup. What tire size are you running?
  20. Feb 10, 2021 at 5:15 PM
    HighonFirewood
    2019 Tundra
    I don’t have Facebook or messenger...or Twitter or all the other online things..just Tundras.com
    Rocfrog, jpod, ZappBrannigan and 2 others like this.
  21. Feb 10, 2021 at 5:18 PM
    HighonFirewood
    2019 Tundra
    I’m at the end of the life of what tire is shown (also pre-lift 275/70’s)..I’ve been debating between 285/75/18, 295/70/18 or 35x12.5..most likely 285/75’s. I want 35s without the 12.5 width..either Nitto RG’s again or Falken M/Ts.
    my truck looks silly currently with the lift and such small tires.
    CorsoTundra likes this.
  22. Feb 10, 2021 at 5:21 PM
    RobertD
    Robert
    DFW, Texas
    If you want a similar product from Amazon, mictuning has a similar sized switch that comes with 3 switches. Other brands out there too. Might be able to find one that is just a blank.
    https://www.amazon.com/dp/B07QCWJSS...colid=EE42AJHADBEF&psc=1&ref_=lv_ov_lig_dp_it
  23. Feb 10, 2021 at 5:24 PM
    HighonFirewood
    2019 Tundra
    Nuts..I looked and googled. Switch bank..Toyota console switch bank, and couldn’t find this. Looking for a Toyota small Switch. This will work . Thanks!
    RobertD[QUOTED] likes this.
  24. Feb 10, 2021 at 5:24 PM
    I just got my 2nd set of RG's on Saturday. I'm on 285/70/18's. The 295 is only 3/8 bigger and 10 pounds heavier. I can't run 35x12.50's on mine because of a 0 offset.
  25. Feb 10, 2021 at 5:27 PM
    HighonFirewood
    2019 Tundra
    I have Ray 10s so I’m +25 with 6” BS. So I can fit em. Plus I have an aftermarket front bumper so room isn’t a problem. 285/75 is taller than the 295/70 (34.8”) and I think 11 and change width.
  26. Feb 10, 2021 at 5:29 PM
    Yep that sounds right. I wish the 285/70 was a tad wider based on the lift but some say it looks fine.
  27. Feb 10, 2021 at 5:31 PM
    HighonFirewood
    2019 Tundra
    Did you go 3”? I’ve seen your truck (nice rig!) but can’t remember your stats. I went 3/1 but with my 33’s now it’s not enough
    You can kinda see in this photo, but it looks straight up silly currently.
  28. Feb 10, 2021 at 5:39 PM
    I don't think it looks bad at that angle. I'm on the Alumas and TT shackles. I'm on a 3/2.
  29. Feb 10, 2021 at 5:43 PM
    HighonFirewood
    2019 Tundra
    Appreciate that...but. How bout now?
  30. Feb 10, 2021 at 5:46 PM
    jefroshm0
    Elk Grove, CA
    His email is listed. Just send him email. Asking for 3 switch for tundra.
