New to Tundra family, got a little rub....
Discussion in 'Wheels & Tires' started by bpkey1580, Feb 9, 2021.
  1. Feb 9, 2021 at 1:39 PM
    bpkey1580
    bpkey1580 [OP] New Member
    Folks,
    I'm a newbie to the Tundra family. I got rid of my 2002 F150 and upgraded to a 2015 Tundra. The truck came with a 4.5 BDS lift with new 35/12.5/18 Toyos and I have a little rub at full lock in reverse on the metal frame with the outside of the tire. I have been scouring forums to see what the best solution to the rub is. I have seen posts about a body chop, like this forum member posted. I'll be honest, I don't think I have the testicular fortitude or the skill to pull off a mod like this. Do you all have any other suggestions? Do you just live with the rub? If a body chop is the only option, do any of you know of a shop or guy in New Mexico (long shot here) to do the cut and weld? Thanks for any tips and advice!
  2. Feb 9, 2021 at 2:16 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Check and confirm yours is rubbing there. The BMC (body mount chop) is a common need for 35x1250 tires. Shops typically charge a couple hundred to perform it. Cant help with a shop in your area but I would say make sure they can do a decent weld. I have seen some pretty ugly weld jobs and look like rust magnets.
    Another option- move to a 285/75/18, as tall or taller than your tires but narrower, so less likely to rub. 295/70s are another option, little thicker, but little shorter than the 285.
  3. Feb 9, 2021 at 2:39 PM
    T500
    T500 # The Dark Side
    Alfie
    Neptune, NJ
    2020 Black
    Nothing wrong with a rub every now and then
    :anonymous:
    saybng, Ely010606 and frichco228 like this.
  4. Feb 9, 2021 at 2:44 PM
    bpkey1580
    I knew I set myself up with that one....
    T500[QUOTED] likes this.
  5. Feb 9, 2021 at 4:23 PM
    T500
    Alfie
    Neptune, NJ
    2020 Black
  6. Feb 9, 2021 at 4:26 PM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    Do you happen to know your wheel offset?
  7. Feb 9, 2021 at 7:22 PM
    bpkey1580
    Im trying to find that out. The truck came with XD series wheels and I’ve been trying to track down which ones I have exactly to see if I can get some wheel specs
  8. Feb 9, 2021 at 7:36 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Welcome from CO. If you do need a BMC, I would just find a good shop and pay the couple hundred bucks. I wouldn’t be able to live with the rub. It would drive me nuts.
  9. Feb 9, 2021 at 7:46 PM
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    2016 Tundra 1794 DiamondBack ATV Tonneau Cover 7" BDS Lift 20" Fuel Krank Wheels 37X13.50X20 Toyo Open Country M/T
  10. Feb 10, 2021 at 5:59 AM
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    I'd live with it. I'd sooner shave off a quarter inch from my tires with an angle grinder than start chopping/welding the body. Or run a spacer.
  11. Feb 10, 2021 at 6:19 AM
    Welcome from NY.
